I am new Qtile and tried It out, because it is said, that the documentation is good and because it’s written in Python, which I use everyday.
Besides having a tiling manager I, want the bar to almost behave as on a normal Desktop.
So I added the following widgets to the bar:
- PulseVolume
- CPU
- Wlan
- Bluetooth
- Battery
The problem are:
- widget.PulseVolume(background="#2f343f") always shows wrong values.
- widget.CPU(fmt=f"CPU {load_percent:4.1f} %",background="#2f343f", foreground="#9bd689") does nor use the trailing white spaces I hoped for, which makes the widget change it width.
- Bluetooth and Wlan do not show anything.
At least Battery seams to work as expected.
My aim for Bluetooth widget is to start a Bluetooth control gui, instead of using bluetoothctl (all the time^^), and something similar for wlan to start a gui that allows to connect to a network and VPN.
Besides the problems with the Bar I have some additional problem with Qtile. How do I auto start fcitx on Qtile.
The documentation states i3 and Sway users should add “exec --start-up-id fcitx -d” in the configuration files. What should I do on Qtile?
The next questions how to use an second screen on a laptop properly. The problem is: with xrandr I got the second screen working, but:
- only when the laptop was started with the screen plugged in
- no bar on the second screen
- on a new start I to set up xrandr again
- when I unplug the second monitor the mouse can be lost?
- How do I set up to work automatically and that I can plugin the second monitor while the laptop is on?
Most function keys on the laptop do work, but I can not change the brightness of the display, which is Important for a laptop (saving energy).
So to sum it up, I do need to advice with the brightness setting, a second monitor config, autostart of fcitx and have some question about the QTile bar.
