hmm if you mind you can send me boot log in pm not posting it public (it includes serials and uuids)
journalctl -b -0 | eos-sendlog
I’m struggling to figure out how to send a PM lol
click on my avatar and there click “Message”
I did, that’s the first picture that I attached. Interesting that you see it and I don’t. Is it perhaps because I’m a new user?
Have you put the command that arandr produces into a terminal to see if you get any output?
No output is provided.
If I add the --verbose flag
crtc 0: 1920x1080 60.00 +0+0 "HDMI-0"
crtc 1: 1920x1080 60.00 +1920+0 "DVI-D-0"
So from here, go into the Layout menu. Click save, name the file what you want to call it. I’d save it to Downloads.
Open the script that arandr produced.
Can you please paste that here.
#!/bin/sh
xrandr --output DVI-D-0 --mode 1920x1080 --pos 1920x0 --rotate normal --output HDMI-0 --primary --mode 1920x1080 --pos 0x0 --rotate normal --output DP-0 --off --output DP-1 --off --output DP-2 --off --output DP-3 --off --output DP-4 --off --output DP-5 --off
Maybe removing all the cruft at the end may help.
Post that in a terminal and let me know if the monitors work correctly.
No output nor change
Post the output of xrandr please.
Actually, I see you have a nvidia card.
I used this package here to install nvidia drivers with great success.
Maybe you could give that a shot and then see what happens with arandr/xrandr?
does xrandr give an output for you when it doesn’t change anything and there’s no errors?
Running just xrandr for me gives this output:
Screen 0: minimum 320 x 200, current 3840 x 2160, maximum 16384 x 16384
DisplayPort-0 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 697mm x 392mm
3840x2160 60.00*+ 60.02 50.00 48.01 29.98
1920x2160 59.99
2560x1440 59.95
1920x1200 60.00
1920x1080 60.00 60.00 50.00 59.94
1600x1200 60.00
1680x1050 59.95
1280x1024 75.02 60.02
1440x900 59.89
1280x960 60.00
1280x800 60.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
I just want to see what resolutions etc you have available.
This might be a silly question, but is xrandr installed?
oh you wanted that thing
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
DVI-D-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+ 59.94 50.00 60.00 50.04
1680x1050 59.95
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 70.07 60.00
800x600 60.32 56.25
720x576 50.00
720x480 59.94
640x480 59.94 59.93
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 299mm
1680x1050 59.95
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1152x864 75.00
800x600 60.32 56.25
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
I should’ve specified with “when provided with arguments like mine” to my question I guess lol
This should have worked.
Just so I am caught up, you use nvidia? What drivers are you using?
I have had great success with the drivers from the link I added above, could be worth trying.
Ha! Yeah, it’s all good.
I believe your issue is driver related, though I must make it clear, I am not expert this is just from my experience.
Like I said, from Xorg’s perspective, everything is fine. I can move my mouse to the other monitor. I can send workspaces and windows over to it. Despite that, my monitor doesn’t get any signal from my computer.
https://archlinux.org/packages/extra/x86_64/nvidia/
I do think that is probably the case
I probably going to have to bow out at this point. I have exhausted my knowledge.
Other than purging all previous drivers and using the ones I linked above I have nothing else to offer I’m sorry.
I feel your pain, sorry I can’t be of more help. If I was in the first place lol.
