Chromium may not support them. But i don’t have any issues. Not sure what you are doing that require these in Chromium? Maybe need do something different then? Using a player that supports that? ![]()
Also check here for support.
I’ll be using Chromium for now, but this issue still exists and needs to be solved.
Okay i installed Vivaldi on my KDE desktop.
It loads acceptable to me.
And to me it’s not. That’s why it should be considered an issue
I can’t fix it! It’s an Arch issue or a Vivaldi issue. Or an issue on your setup or hardware. As i said it works fine on my system. I have the same EndeavourOS …same KDE.
Edit: I only try to help you figure it out. But it’s mostly you’ll have to do try things on your end.
If it works in arch then it’s not arch issue, right? And it works. The fact that Chrome has the same problem makes me believe it’s not Vivaldi problem as well. Who’s left? EndeavourOS
But it works fine on my system so I guess it’s your hardware?
Edit: Or it’s an issue with the installed system. Software!. ![]()
