Choices, choices
These are our normal prices here from a computer parts store. They are the largest distributor with stores all across Canada since 1991. Everything on Amazon is a rip off.
Edit: Just use the drop down menu and select computer components. See for yourself.
Oh wow. Okay that’s it, I’m moving to Canada :smiley:
Anything you need! They have it. They have a lot of stores & Head office is also close in another city.
I’m wistfully browsing their site, very impressive.
They are the best prices in Canada usually. There is also https://www.newegg.ca/
Edit: newegg also have a US site .com/
This is the video card i was looking at because they had it in stock.
57308
Ah yes, that’s the beauty in the PCSpecialist prebuilt rig.
AMD is supposed to have a RX 6500XT coming out soon.
I have this GPU, it’s pretty good for 1080p…
But it’s the red devil from powercolor
I think Asrock is Asus’s cheaper line?
So much food for thought. Honestly I think I’ll take the leap of faith and order the prebuilt PCSpecialist rig. Seems to tick all the boxes and has a degree of future proofing too.
I really don’t know.. What I heard is that Saphire and Powercolor are known to make better cards, but this may be a rumor..
What I know is that the 6600xt is really simple and doesn’t get hot compared to the stronger GPUs, so I would pick the cheaper one.. I think that’s ok.
I would also watch a review before buying just to be sure
Not sure. I know the name but that’s about all. It did remind me of Ad-Rock from the Beastie Boys though :laughing:
Thanks, yes I’ll be taking in as much info as possible before buying.
  • he says knowing he’s the most impulsive tech gadget shopper ever *
I can play Battlefield 2042 @ 1080p @ high settings at 100 fps.
I enabled that feature Smart Memory Access.
Sounds interesting. Will those settings be available if I’m using it on EndeavourOS Plasma?
That is a good question, using Windows to play games and EnOS for everything else…
I’m sure it will give good performance, I’ve had nothing but that since I started gaming on Linux.
It will, don’t worry…
You will need a 550 or 600W PSU to power that card.
My CPU is a 5600x, and it pushes that GPU to it’s limit…
The price is that it’s not good, the market is broken right now…
No problem there, the prebuilt rig comes with that and the RX 6600 xt
This beauty
