Since about 2 months, more or less, my KDE EndeavourOS can’t retrieve the battery state and always show “fully charged”. This occurs in the system tray:
but also when I run upower -i upower -e | grep ‘BAT’` and I get at output:
Ok. Dell may also have a tool in the bios to test the battery and or recalibrate in case it turns out to be unrelated to kde. Let’s what other solutions/troubleshoot will be posted here.
I have just flash a Bios update, and check the Bios entries but could not find anything relevant. I have tweaked some settings as “Activate State-C” but can’t see any change in the battery behaviour (Not sure it is related to the battery anyway ). The system still can’t retrieve it.
Let’s wait and see for other possible solutions
No yet … I know it’s the next step but I need to open the laptop (don’t have an external removable battery) and I don’t want to make an error, so I still hope to find another solution before doing this. Anyway, I’ll soon get to try this if not other way.
Just talking out load here. It looks like the maximum capacity on the battery at this point is ~94%. In theory until you get the charge down below that it will report 100% (@94% total capacity). Just so I understand you are saying no matter how long you use the battery it never drops below 100% correct?
I have only come across one suggestion so far. It was to reset the bios to factory defaults. That would mean having to redo anything you had to do to get linux installed like disabling secure boot and so on.
Yes, well… I need to choose between this or leaving it in the actual state. I will get to this, I believe, I should not get into an issue but… well, I know by experience that issues are coming when they are not expected
Maybe next week, when I’ll have a few hours to play with “just in case…” Thanks for the suggestion. After trying this I’ll report if any change (or not)
A lot ! lol… It’s a rolling distro isn’t it .
But yes, it begun before the update to Plasma 5.21
I can’t say exactly when it begun as last year - and still now - I don’t travel a lot (I wonder why… something occurred in 2020 ?) - so I am at home and I usually keep the laptop plugged-in. So I didn’t pay attention when this occured the first time.
I didn’t reset the bios, but in the bios itself the battery status can be read with the correct values. So I have boot with the last EndeavourOS on USB, in a live session and the battery status is also correctly retrieved. (but I didn’t install plasma).
I also opened the laptop, disconnected the battery, pressed the power button 15 sec to discharge the laptop, wait 2 minutes, reinstalled the battery… no change.
So bottom line: it seems to me it is something related to my specific plasma installation. Not a bios or a specific laptop issue.
I could reinstall EndeavourOS from the beginning, but I really don’t want to do this (I would loose the option to found the answer to this issue).
