Can't put my Wireless adapter to work
So, I bought this new engine cause my dongle had a very slow internet connection and that of the pic is very fast. The thing is I could not put this to work in Endeaveur, since I am a newbie i have no clue where to go in order to make this work. Any ideia? I don’t know how to update the drivers manually or something like that.
My lsusb:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 1ea7:0064 SHARKOON Technologies GmbH 2.4GHz Wireless rechargeable vertical mouse [More&Better]
Bus 001 Device 003: ID 8087:0032 Intel Corp. AX210 Bluetooth
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0e8f:0022 GreenAsia Inc. multimedia keyboard controller
Bus 003 Device 003: ID 248a:8367 Maxxter Telink Wireless Receiver
Bus 003 Device 004: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
[pedro@loopz ~]$
I guess this is called Maxxter Telink Wireless Receiver in terminal for some reason. The other dongle (realtek’s one) is the old one I’m using to make this post.
I read that it shares the same drive as intel AX 210 but no idea on how to make it work.
Model: Fenvi Fv-axe3000 Rgb
Chipset: apparently AX210 (Gig +)
Thanks for the help, beforehand.
The AX210, if that’s what it is based on, has been supported in Linux since kernel 5.10.
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
With your new adapter installed, boot, run and share the output of:
inxi -Fxxc0z | eos-sendlog
Since it only generates the information with the internet on, I put the dongle so I could have internet. But as you see there are two informations about wireless there
  Kernel: 6.6.38-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
  Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Desktop Mobo: ASRock model: X370 Pro4 serial: <superuser required>
    UEFI: American Megatrends v: P10.08 date: 01/22/2024
  Info: 8-core model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+
    rev: 2 cache: L1: 512 KiB L2: 4 MiB L3: 96 MiB
  Speed (MHz): avg: 2621 high: 3590 min/max: 2200/4148 boost: enabled cores:
    1: 3590 2: 3590 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2843 9: 3578
    10: 2200 11: 2200 12: 2200 13: 2200 14: 3473 15: 2863 16: 2200
    bogomips: 95855
  Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: CardExpert
    driver: nvidia v: 555.58.02 arch: Ampere pcie: speed: 8 GT/s lanes: 16
    ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0c:00.0
    chip-ID: 10de:2488
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
    alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
  Monitor-1: HDMI-A-1 res: 2133x1200 size: N/A
  API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: swrast
    gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11:
    drv: zink inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
    display-ID: :1.0
  API: Vulkan v: 1.3.279 surfaces: xcb,xlib,wayland device: 0
    type: discrete-gpu driver: nvidia device-ID: 10de:2488
  Device-1: NVIDIA GA104 High Definition Audio vendor: CardExpert
    driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
    bus-ID: 0c:00.1 chip-ID: 10de:228b
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    bus-ID: 0e:00.4 chip-ID: 1022:1487
  API: ALSA v: k6.6.38-1-lts status: kernel-api
  Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: ASRock driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 0b:00.0 chip-ID: 10ec:8168
  IF: enp11s0 state: down mac: <filter>
  Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter
    driver: rtl8xxxu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-4:4
    chip-ID: 0bda:8179
Bluetooth:
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 bus-ID: 1-9:3 chip-ID: 8087:0032
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
  Local Storage: total: 1.84 TiB used: 14.78 GiB (0.8%)
  ID-1: /dev/nvme0n1 vendor: XrayDisk model: 1TB PRO size: 953.87 GiB
    speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 28.9 C
  ID-2: /dev/sda vendor: SanDisk model: SSD PLUS 1000GB size: 931.51 GiB
    speed: 6.0 Gb/s serial: <filter>
  ID-1: / size: 902.97 GiB used: 14.32 GiB (1.6%) fs: ext4 dev: /dev/nvme0n1p2
  ID-1: swap-1 type: partition size: 34.4 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3
  System Temperatures: cpu: 42.9 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 32 GiB available: 31.27 GiB used: 3.59 GiB (11.5%)
  Processes: 350 Power: uptime: 1h 52m wakeups: 0 Init: systemd v: 256
    default: graphical
  Packages: pm: pacman pkgs: 1069 Compilers: gcc: 14.1.1 Shell: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.35
It’s picked up the AX210 as a Bluetooth device, but no WLAN. Only your Realtek USB dongle shows up there.
Perhaps a boot log to see if a useful error is thrown:
journalctl -k -b -0 | eos-sendlog
Part 1
jul 11 19:42:21 loopz kernel: Linux version 6.6.38-1-lts (linux-lts@archlinux) (gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Tue, 09 Jul 2024 11:08:50 +0000
jul 11 19:42:21 loopz kernel: Command line: initrd=\4d62d1150d234f04bd9d991e0216a4fd\6.6.38-1-lts\initrd nvme_load=YES nowatchdog rw root=UUID=2fa1c21f-8991-4be8-a4e7-0ac469e17972 resume=UUID=0619913a-9aad-4f73-8f6f-56f5c815c99f nvidia_drm.modeset=1 rw root=UUID=2fa1c21f-8991-4be8-a4e7-0ac469e17972 resume=UUID=0619913a-9aad-4f73-8f6f-56f5c815c99f nvidia_drm.modeset=1 systemd.machine_id=4d62d1150d234f04bd9d991e0216a4fd
jul 11 19:42:21 loopz kernel: BIOS-provided physical RAM map:
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009bfefff] usable
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x0000000009bff000-0x0000000009ffffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20dfff] ACPI NVS
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x000000000a20e000-0x000000000affffff] usable
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x000000000b020000-0x00000000bb401fff] usable
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000bb402000-0x00000000bcb6cfff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000bcb6d000-0x00000000bcba5fff] ACPI data
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000bcba6000-0x00000000bd285fff] ACPI NVS
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000bd286000-0x00000000bddfefff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000bddff000-0x00000000beffffff] usable
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000bf000000-0x00000000bfffffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fd600000-0x00000000fd7fffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x0000000100000000-0x000000083f37ffff] usable
jul 11 19:42:21 loopz kernel: BIOS-e820: [mem 0x000000083f380000-0x000000083fffffff] reserved
jul 11 19:42:21 loopz kernel: The simpledrm driver will not be probed
jul 11 19:42:21 loopz kernel: NX (Execute Disable) protection: active
jul 11 19:42:21 loopz kernel: APIC: Static calls initialized
jul 11 19:42:21 loopz kernel: e820: update [mem 0xb64f2018-0xb6518857] usable ==> usable
jul 11 19:42:21 loopz kernel: extended physical RAM map:
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000000a0000-0x00000000000fffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x0000000000100000-0x0000000009bfefff] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x0000000009bff000-0x0000000009ffffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x000000000a000000-0x000000000a1fffff] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x000000000a200000-0x000000000a20dfff] ACPI NVS
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x000000000a20e000-0x000000000affffff] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x000000000b000000-0x000000000b01ffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x000000000b020000-0x00000000b64f2017] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000b64f2018-0x00000000b6518857] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000b6518858-0x00000000bb401fff] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000bb402000-0x00000000bcb6cfff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000bcb6d000-0x00000000bcba5fff] ACPI data
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000bcba6000-0x00000000bd285fff] ACPI NVS
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000bd286000-0x00000000bddfefff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000bddff000-0x00000000beffffff] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000bf000000-0x00000000bfffffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fd600000-0x00000000fd7fffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x0000000100000000-0x000000083f37ffff] usable
jul 11 19:42:21 loopz kernel: reserve setup_data: [mem 0x000000083f380000-0x000000083fffffff] reserved
jul 11 19:42:21 loopz kernel: efi: EFI v2.7 by American Megatrends
jul 11 19:42:21 loopz kernel: efi: ACPI=0xbd26f000 ACPI 2.0=0xbd26f014 TPMFinalLog=0xbd239000 SMBIOS=0xbdc22000 SMBIOS 3.0=0xbdc21000 MEMATTR=0xb7aaf518 ESRT=0xb39c3298 RNG=0xbcb77f18 INITRD=0xb6621398 TPMEventLog=0xb654b018
jul 11 19:42:21 loopz kernel: random: crng init done
jul 11 19:42:21 loopz kernel: efi: Remove mem314: MMIO range=[0xf0000000-0xf7ffffff] (128MB) from e820 map
jul 11 19:42:21 loopz kernel: e820: remove [mem 0xf0000000-0xf7ffffff] reserved
jul 11 19:42:21 loopz kernel: efi: Remove mem315: MMIO range=[0xfd200000-0xfd2fffff] (1MB) from e820 map
jul 11 19:42:21 loopz kernel: e820: remove [mem 0xfd200000-0xfd2fffff] reserved
jul 11 19:42:21 loopz kernel: efi: Remove mem316: MMIO range=[0xfd600000-0xfd7fffff] (2MB) from e820 map
jul 11 19:42:21 loopz kernel: e820: remove [mem 0xfd600000-0xfd7fffff] reserved
jul 11 19:42:21 loopz kernel: efi: Not removing mem317: MMIO range=[0xfea00000-0xfea0ffff] (64KB) from e820 map
jul 11 19:42:21 loopz kernel: efi: Remove mem318: MMIO range=[0xfeb80000-0xfec01fff] (0MB) from e820 map
jul 11 19:42:21 loopz kernel: e820: remove [mem 0xfeb80000-0xfec01fff] reserved
jul 11 19:42:21 loopz kernel: efi: Not removing mem319: MMIO range=[0xfec10000-0xfec10fff] (4KB) from e820 map
jul 11 19:42:21 loopz kernel: efi: Not removing mem320: MMIO range=[0xfec30000-0xfec30fff] (4KB) from e820 map
jul 11 19:42:21 loopz kernel: efi: Not removing mem321: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
jul 11 19:42:21 loopz kernel: efi: Not removing mem322: MMIO range=[0xfed40000-0xfed44fff] (20KB) from e820 map
jul 11 19:42:21 loopz kernel: efi: Not removing mem323: MMIO range=[0xfed80000-0xfed8ffff] (64KB) from e820 map
jul 11 19:42:21 loopz kernel: efi: Not removing mem324: MMIO range=[0xfedc2000-0xfedcffff] (56KB) from e820 map
jul 11 19:42:21 loopz kernel: efi: Not removing mem325: MMIO range=[0xfedd4000-0xfedd5fff] (8KB) from e820 map
jul 11 19:42:21 loopz kernel: efi: Remove mem326: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
jul 11 19:42:21 loopz kernel: e820: remove [mem 0xff000000-0xffffffff] reserved
jul 11 19:42:21 loopz kernel: SMBIOS 3.3.0 present.
jul 11 19:42:21 loopz kernel: DMI: To Be Filled By O.E.M. X370 Pro4/X370 Pro4, BIOS P10.08 01/22/2024
jul 11 19:42:21 loopz kernel: tsc: Fast TSC calibration using PIT
jul 11 19:42:21 loopz kernel: tsc: Detected 2994.232 MHz processor
jul 11 19:42:21 loopz kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
jul 11 19:42:21 loopz kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
jul 11 19:42:21 loopz kernel: last_pfn = 0x83f380 max_arch_pfn = 0x400000000
jul 11 19:42:21 loopz kernel: total RAM covered: 3071M
jul 11 19:42:21 loopz kernel: Found optimal setting for mtrr clean up
jul 11 19:42:21 loopz kernel:  gran_size: 64K         chunk_size: 64M         num_reg: 3          lose cover RAM: 0G
jul 11 19:42:21 loopz kernel: MTRR map: 7 entries (3 fixed + 4 variable; max 20), built from 9 variable MTRRs
jul 11 19:42:21 loopz kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
jul 11 19:42:21 loopz kernel: e820: update [mem 0xbcd10000-0xbcd1ffff] usable ==> reserved
jul 11 19:42:21 loopz kernel: e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
jul 11 19:42:21 loopz kernel: last_pfn = 0xbf000 max_arch_pfn = 0x400000000
jul 11 19:42:21 loopz kernel: esrt: Reserving ESRT space from 0x00000000b39c3298 to 0x00000000b39c32d0.
jul 11 19:42:21 loopz kernel: e820: update [mem 0xb39c3000-0xb39c3fff] usable ==> reserved
jul 11 19:42:21 loopz kernel: Using GB pages for direct mapping
jul 11 19:42:21 loopz kernel: Secure boot disabled
jul 11 19:42:21 loopz kernel: RAMDISK: [mem 0xa7a48000-0xad9c6fff]
jul 11 19:42:21 loopz kernel: ACPI: Early table checksum verification disabled
jul 11 19:42:21 loopz kernel: ACPI: RSDP 0x00000000BD26F014 000024 (v02 ALASKA)
jul 11 19:42:21 loopz kernel: ACPI: XSDT 0x00000000BD26E728 0000C4 (v01 ALASKA A M I    01072009 AMI  01000013)
jul 11 19:42:21 loopz kernel: ACPI: FACP 0x00000000BCB97000 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
jul 11 19:42:21 loopz kernel: ACPI: DSDT 0x00000000BCB90000 00643E (v02 ALASKA A M I    01072009 INTL 20120913)
jul 11 19:42:21 loopz kernel: ACPI: FACS 0x00000000BD269000 000040
jul 11 19:42:21 loopz kernel: ACPI: SSDT 0x00000000BCB9D000 008CE9 (v02 AMD    AmdTable 00000002 MSFT 04000000)
jul 11 19:42:21 loopz kernel: ACPI: SSDT 0x00000000BCB99000 003CB6 (v02 AMD    AMD AOD  00000001 INTL 20120913)
jul 11 19:42:21 loopz kernel: ACPI: SSDT 0x00000000BCB98000 0000FC (v02 ALASKA CPUSSDT  01072009 AMI  01072009)
jul 11 19:42:21 loopz kernel: ACPI: FIDT 0x00000000BCB8F000 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
jul 11 19:42:21 loopz kernel: ACPI: MCFG 0x00000000BCB8E000 00003C (v01 ALASKA A M I    01072009 MSFT 00010013)
jul 11 19:42:21 loopz kernel: ACPI: AAFT 0x00000000BCB8D000 0000F1 (v01 ALASKA OEMAAFT  01072009 MSFT 00000097)
jul 11 19:42:21 loopz kernel: ACPI: HPET 0x00000000BCB8C000 000038 (v01 ALASKA A M I    01072009 AMI  00000005)
jul 11 19:42:21 loopz kernel: ACPI: TPM2 0x00000000BCB8A000 00004C (v04 ALASKA A M I    00000001 AMI  00000000)
jul 11 19:42:21 loopz kernel: ACPI: PCCT 0x00000000BCB89000 00006E (v02 AMD    AmdTable 00000001 AMD  00000001)
jul 11 19:42:21 loopz kernel: ACPI: SSDT 0x00000000BCB84000 004043 (v02 AMD    AmdTable 00000001 AMD  00000001)
jul 11 19:42:21 loopz kernel: ACPI: CRAT 0x00000000BCB83000 000F10 (v01 AMD    AmdTable 00000001 AMD  00000001)
jul 11 19:42:21 loopz kernel: ACPI: CDIT 0x00000000BCB82000 000029 (v01 AMD    AmdTable 00000001 AMD  00000001)
jul 11 19:42:21 loopz kernel: ACPI: BGRT 0x00000000BCB8B000 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
jul 11 19:42:21 loopz kernel: ACPI: SSDT 0x00000000BCB7E000 0037C4 (v02 AMD    MYRTLE   00000001 INTL 20120913)
jul 11 19:42:21 loopz kernel: ACPI: SSDT 0x00000000BCB7D000 0000BF (v01 AMD    AmdTable 00001000 INTL 20120913)
jul 11 19:42:21 loopz kernel: ACPI: WSMT 0x00000000BCB7C000 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
jul 11 19:42:21 loopz kernel: ACPI: APIC 0x00000000BCB7B000 00015E (v03 ALASKA A M I    01072009 AMI  00010013)
jul 11 19:42:21 loopz kernel: ACPI: SSDT 0x00000000BCB79000 0010AF (v02 AMD    MYRTLE   00000001 INTL 20120913)
jul 11 19:42:21 loopz kernel: ACPI: FPDT 0x00000000BCB78000 000044 (v01 ALASKA A M I    01072009 AMI  01000013)
jul 11 19:42:21 loopz kernel: ACPI: Reserving FACP table memory at [mem 0xbcb97000-0xbcb97113]
jul 11 19:42:21 loopz kernel: ACPI: Reserving DSDT table memory at [mem 0xbcb90000-0xbcb9643d]
jul 11 19:42:21 loopz kernel: ACPI: Reserving FACS table memory at [mem 0xbd269000-0xbd26903f]
jul 11 19:42:21 loopz kernel: ACPI: Reserving SSDT table memory at [mem 0xbcb9d000-0xbcba5ce8]
jul 11 19:42:21 loopz kernel: ACPI: Reserving SSDT table memory at [mem 0xbcb99000-0xbcb9ccb5]
jul 11 19:42:21 loopz kernel: ACPI: Reserving SSDT table memory at [mem 0xbcb98000-0xbcb980fb]
jul 11 19:42:21 loopz kernel: ACPI: Reserving FIDT table memory at [mem 0xbcb8f000-0xbcb8f09b]
jul 11 19:42:21 loopz kernel: ACPI: Reserving MCFG table memory at [mem 0xbcb8e000-0xbcb8e03b]
jul 11 19:42:21 loopz kernel: ACPI: Reserving AAFT table memory at [mem 0xbcb8d000-0xbcb8d0f0]
jul 11 19:42:21 loopz kernel: ACPI: Reserving HPET table memory at [mem 0xbcb8c000-0xbcb8c037]
jul 11 19:42:21 loopz kernel: ACPI: Reserving TPM2 table memory at [mem 0xbcb8a000-0xbcb8a04b]
jul 11 19:42:21 loopz kernel: ACPI: Reserving PCCT table memory at [mem 0xbcb89000-0xbcb8906d]
jul 11 19:42:21 loopz kernel: ACPI: Reserving SSDT table memory at [mem 0xbcb84000-0xbcb88042]
jul 11 19:42:21 loopz kernel: ACPI: Reserving CRAT table memory at [mem 0xbcb83000-0xbcb83f0f]
jul 11 19:42:21 loopz kernel: ACPI: Reserving CDIT table memory at [mem 0xbcb82000-0xbcb82028]
jul 11 19:42:21 loopz kernel: ACPI: Reserving BGRT table memory at [mem 0xbcb8b000-0xbcb8b037]
jul 11 19:42:21 loopz kernel: ACPI: Reserving SSDT table memory at [mem 0xbcb7e000-0xbcb817c3]
jul 11 19:42:21 loopz kernel: ACPI: Reserving SSDT table memory at [mem 0xbcb7d000-0xbcb7d0be]
jul 11 19:42:21 loopz kernel: ACPI: Reserving WSMT table memory at [mem 0xbcb7c000-0xbcb7c027]
jul 11 19:42:21 loopz kernel: ACPI: Reserving APIC table memory at [mem 0xbcb7b000-0xbcb7b15d]
jul 11 19:42:21 loopz kernel: ACPI: Reserving SSDT table memory at [mem 0xbcb79000-0xbcb7a0ae]
jul 11 19:42:21 loopz kernel: ACPI: Reserving FPDT table memory at [mem 0xbcb78000-0xbcb78043]
jul 11 19:42:21 loopz kernel: No NUMA configuration found
jul 11 19:42:21 loopz kernel: Faking a node at [mem 0x0000000000000000-0x000000083f37ffff]
jul 11 19:42:21 loopz kernel: NODE_DATA(0) allocated [mem 0x83f37b000-0x83f37ffff]
jul 11 19:42:21 loopz kernel: Zone ranges:
jul 11 19:42:21 loopz kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
jul 11 19:42:21 loopz kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
jul 11 19:42:21 loopz kernel:   Normal   [mem 0x0000000100000000-0x000000083f37ffff]
jul 11 19:42:21 loopz kernel:   Device   empty
jul 11 19:42:21 loopz kernel: Movable zone start for each node
jul 11 19:42:21 loopz kernel: Early memory node ranges
jul 11 19:42:21 loopz kernel:   node   0: [mem 0x0000000000001000-0x000000000009ffff]
jul 11 19:42:21 loopz kernel:   node   0: [mem 0x0000000000100000-0x0000000009bfefff]
jul 11 19:42:21 loopz kernel:   node   0: [mem 0x000000000a000000-0x000000000a1fffff]
jul 11 19:42:21 loopz kernel:   node   0: [mem 0x000000000a20e000-0x000000000affffff]
jul 11 19:42:21 loopz kernel:   node   0: [mem 0x000000000b020000-0x00000000bb401fff]
jul 11 19:42:21 loopz kernel:   node   0: [mem 0x00000000bddff000-0x00000000beffffff]
jul 11 19:42:21 loopz kernel:   node   0: [mem 0x0000000100000000-0x000000083f37ffff]
jul 11 19:42:21 loopz kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000083f37ffff]
jul 11 19:42:21 loopz kernel: On node 0, zone DMA: 1 pages in unavailable ranges
jul 11 19:42:21 loopz kernel: On node 0, zone DMA: 96 pages in unavailable ranges
jul 11 19:42:21 loopz kernel: On node 0, zone DMA32: 1025 pages in unavailable ranges
jul 11 19:42:21 loopz kernel: On node 0, zone DMA32: 14 pages in unavailable ranges
jul 11 19:42:21 loopz kernel: On node 0, zone DMA32: 32 pages in unavailable ranges
jul 11 19:42:21 loopz kernel: On node 0, zone DMA32: 10749 pages in unavailable ranges
jul 11 19:42:21 loopz kernel: On node 0, zone Normal: 4096 pages in unavailable ranges
jul 11 19:42:21 loopz kernel: On node 0, zone Normal: 3200 pages in unavailable ranges
jul 11 19:42:21 loopz kernel: ACPI: PM-Timer IO Port: 0x808
jul 11 19:42:21 loopz kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
jul 11 19:42:21 loopz kernel: IOAPIC[0]: apic_id 17, version 33, address 0xfec00000, GSI 0-23
jul 11 19:42:21 loopz kernel: IOAPIC[1]: apic_id 18, version 33, address 0xfec01000, GSI 24-55
jul 11 19:42:21 loopz kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
jul 11 19:42:21 loopz kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
jul 11 19:42:21 loopz kernel: ACPI: Using ACPI (MADT) for SMP configuration information
jul 11 19:42:21 loopz kernel: ACPI: HPET id: 0x10228201 base: 0xfed00000
jul 11 19:42:21 loopz kernel: e820: update [mem 0xb6fc9000-0xb7009fff] usable ==> reserved
jul 11 19:42:21 loopz kernel: smpboot: Allowing 32 CPUs, 16 hotplug CPUs
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0x09bff000-0x09ffffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20dfff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xb39c3000-0xb39c3fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xb64f2000-0xb64f2fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xb6518000-0xb6518fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xb6fc9000-0xb7009fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xbb402000-0xbcb6cfff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xbcb6d000-0xbcba5fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xbcba6000-0xbd285fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xbd286000-0xbddfefff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xbf000000-0xbfffffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xfe9fffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfea0ffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfea10000-0xfec0ffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfec2ffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfec30000-0xfec30fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfec31000-0xfecfffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc1fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfedc2000-0xfedcffff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfedd0000-0xfedd3fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfedd4000-0xfedd5fff]
jul 11 19:42:21 loopz kernel: PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xffffffff]
jul 11 19:42:21 loopz kernel: [mem 0xc0000000-0xfe9fffff] available for PCI devices
jul 11 19:42:21 loopz kernel: Booting paravirtualized kernel on bare hardware
jul 11 19:42:21 loopz kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
jul 11 19:42:21 loopz kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:32 nr_cpu_ids:32 nr_node_ids:1
jul 11 19:42:21 loopz kernel: percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
jul 11 19:42:21 loopz kernel: pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
jul 11 19:42:21 loopz kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
jul 11 19:42:21 loopz kernel: pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
jul 11 19:42:21 loopz kernel: Kernel command line: initrd=\4d62d1150d234f04bd9d991e0216a4fd\6.6.38-1-lts\initrd nvme_load=YES nowatchdog rw root=UUID=2fa1c21f-8991-4be8-a4e7-0ac469e17972 resume=UUID=0619913a-9aad-4f73-8f6f-56f5c815c99f nvidia_drm.modeset=1 rw root=UUID=2fa1c21f-8991-4be8-a4e7-0ac469e17972 resume=UUID=0619913a-9aad-4f73-8f6f-56f5c815c99f nvidia_drm.modeset=1 systemd.machine_id=4d62d1150d234f04bd9d991e0216a4fd
jul 11 19:42:21 loopz kernel: Unknown kernel command line parameters "nvme_load=YES", will be passed to user space.
jul 11 19:42:21 loopz kernel: printk: log_buf_len individual max cpu contribution: 4096 bytes
jul 11 19:42:21 loopz kernel: printk: log_buf_len total cpu_extra contributions: 126976 bytes
jul 11 19:42:21 loopz kernel: printk: log_buf_len min size: 131072 bytes
jul 11 19:42:21 loopz kernel: printk: log_buf_len: 262144 bytes
jul 11 19:42:21 loopz kernel: printk: early log buf free: 112560(85%)
jul 11 19:42:21 loopz kernel: Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
jul 11 19:42:21 loopz kernel: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
jul 11 19:42:21 loopz kernel: Fallback order for Node 0: 0
jul 11 19:42:21 loopz kernel: Built 1 zonelists, mobility grouping on.  Total pages: 8238462
jul 11 19:42:21 loopz kernel: Policy zone: Normal
jul 11 19:42:21 loopz kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
jul 11 19:42:21 loopz kernel: software IO TLB: area num 32.
jul 11 19:42:21 loopz kernel: Memory: 32582392K/33477580K available (16384K kernel code, 2136K rwdata, 13020K rodata, 3420K init, 3792K bss, 894932K reserved, 0K cma-reserved)
jul 11 19:42:21 loopz kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
jul 11 19:42:21 loopz kernel: ftrace: allocating 48907 entries in 192 pages
jul 11 19:42:21 loopz kernel: ftrace: allocated 192 pages with 2 groups
jul 11 19:42:21 loopz kernel: Dynamic Preempt: voluntary
jul 11 19:42:21 loopz kernel: rcu: Preemptible hierarchical RCU implementation.
jul 11 19:42:21 loopz kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
jul 11 19:42:21 loopz kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
jul 11 19:42:21 loopz kernel:         Trampoline variant of Tasks RCU enabled.
jul 11 19:42:21 loopz kernel:         Rude variant of Tasks RCU enabled.
jul 11 19:42:21 loopz kernel:         Tracing variant of Tasks RCU enabled.
jul 11 19:42:21 loopz kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
jul 11 19:42:21 loopz kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
jul 11 19:42:21 loopz kernel: NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
jul 11 19:42:21 loopz kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
jul 11 19:42:21 loopz kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
jul 11 19:42:21 loopz kernel: Console: colour dummy device 80x25
jul 11 19:42:21 loopz kernel: printk: console [tty0] enabled
jul 11 19:42:21 loopz kernel: ACPI: Core revision 20230628
jul 11 19:42:21 loopz kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
jul 11 19:42:21 loopz kernel: APIC: Switch to symmetric I/O mode setup
jul 11 19:42:21 loopz kernel: x2apic: IRQ remapping doesn't support X2APIC mode
jul 11 19:42:21 loopz kernel: APIC: Switched APIC routing to: physical flat
jul 11 19:42:21 loopz kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
jul 11 19:42:21 loopz kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b28fcd3b94, max_idle_ns: 440795294499 ns
jul 11 19:42:21 loopz kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5990.98 BogoMIPS (lpj=9980773)
jul 11 19:42:21 loopz kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
jul 11 19:42:21 loopz kernel: LVT offset 1 assigned for vector 0xf9
jul 11 19:42:21 loopz kernel: LVT offset 2 assigned for vector 0xf4
jul 11 19:42:21 loopz kernel: process: using mwait in idle threads
jul 11 19:42:21 loopz kernel: Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
jul 11 19:42:21 loopz kernel: Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
jul 11 19:42:21 loopz kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
jul 11 19:42:21 loopz kernel: Spectre V2 : Mitigation: Retpolines
jul 11 19:42:21 loopz kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
jul 11 19:42:21 loopz kernel: Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
jul 11 19:42:21 loopz kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
jul 11 19:42:21 loopz kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
jul 11 19:42:21 loopz kernel: Spectre V2 : User space: Mitigation: STIBP always-on protection
jul 11 19:42:21 loopz kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
jul 11 19:42:21 loopz kernel: Speculative Return Stack Overflow: Mitigation: Safe RET
jul 11 19:42:21 loopz kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
jul 11 19:42:21 loopz kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
jul 11 19:42:21 loopz kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
jul 11 19:42:21 loopz kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
jul 11 19:42:21 loopz kernel: x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
jul 11 19:42:21 loopz kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
jul 11 19:42:21 loopz kernel: x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
jul 11 19:42:21 loopz kernel: x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
jul 11 19:42:21 loopz kernel: x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
jul 11 19:42:21 loopz kernel: Freeing SMP alternatives memory: 40K
jul 11 19:42:21 loopz kernel: pid_max: default: 32768 minimum: 301
jul 11 19:42:21 loopz kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
jul 11 19:42:21 loopz kernel: landlock: Up and running.
jul 11 19:42:21 loopz kernel: Yama: becoming mindful.
jul 11 19:42:21 loopz kernel: LSM support for eBPF active
jul 11 19:42:21 loopz kernel: Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
jul 11 19:42:21 loopz kernel: Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
jul 11 19:42:21 loopz kernel: smpboot: CPU0: AMD Ryzen 7 5700X3D 8-Core Processor (family: 0x19, model: 0x21, stepping: 0x2)
jul 11 19:42:21 loopz kernel: RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
jul 11 19:42:21 loopz kernel: RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
jul 11 19:42:21 loopz kernel: RCU Tasks Trace: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
jul 11 19:42:21 loopz kernel: Performance Events: Fam17h+ core perfctr, AMD PMU driver.
jul 11 19:42:21 loopz kernel: ... version:                0
jul 11 19:42:21 loopz kernel: ... bit width:              48
jul 11 19:42:21 loopz kernel: ... generic registers:      6
jul 11 19:42:21 loopz kernel: ... value mask:             0000ffffffffffff
jul 11 19:42:21 loopz kernel: ... max period:             00007fffffffffff
jul 11 19:42:21 loopz kernel: ... fixed-purpose events:   0
jul 11 19:42:21 loopz kernel: ... event mask:             000000000000003f
jul 11 19:42:21 loopz kernel: signal: max sigframe size: 3376
jul 11 19:42:21 loopz kernel: rcu: Hierarchical SRCU implementation.
jul 11 19:42:21 loopz kernel: rcu:         Max phase no-delay instances is 1000.
jul 11 19:42:21 loopz kernel: smp: Bringing up secondary CPUs ...
jul 11 19:42:21 loopz kernel: smpboot: x86: Booting SMP configuration:
jul 11 19:42:21 loopz kernel: .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
jul 11 19:42:21 loopz kernel: Spectre V2 : Update user space SMT mitigation: STIBP always-on
jul 11 19:42:21 loopz kernel: smp: Brought up 1 node, 16 CPUs
jul 11 19:42:21 loopz kernel: smpboot: Max logical packages: 2
jul 11 19:42:21 loopz kernel: smpboot: Total of 16 processors activated (95853.73 BogoMIPS)
jul 11 19:42:21 loopz kernel: devtmpfs: initialized
jul 11 19:42:21 loopz kernel: x86/mm: Memory block size: 128MB
jul 11 19:42:21 loopz kernel: ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20dfff] (57344 bytes)
jul 11 19:42:21 loopz kernel: ACPI: PM: Registering ACPI NVS region [mem 0xbcba6000-0xbd285fff] (7208960 bytes)
jul 11 19:42:21 loopz kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
jul 11 19:42:21 loopz kernel: futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
jul 11 19:42:21 loopz kernel: pinctrl core: initialized pinctrl subsystem
jul 11 19:42:21 loopz kernel: PM: RTC time: 22:42:18, date: 2024-07-11
jul 11 19:42:21 loopz kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
jul 11 19:42:21 loopz kernel: DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
jul 11 19:42:21 loopz kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
jul 11 19:42:21 loopz kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
jul 11 19:42:21 loopz kernel: audit: initializing netlink subsys (disabled)
jul 11 19:42:21 loopz kernel: audit: type=2000 audit(1720737737.196:1): state=initialized audit_enabled=0 res=1
jul 11 19:42:21 loopz kernel: thermal_sys: Registered thermal governor 'fair_share'
jul 11 19:42:21 loopz kernel: thermal_sys: Registered thermal governor 'bang_bang'
jul 11 19:42:21 loopz kernel: thermal_sys: Registered thermal governor 'step_wise'
jul 11 19:42:21 loopz kernel: thermal_sys: Registered thermal governor 'user_space'
jul 11 19:42:21 loopz kernel: thermal_sys: Registered thermal governor 'power_allocator'
jul 11 19:42:21 loopz kernel: cpuidle: using governor ladder
jul 11 19:42:21 loopz kernel: cpuidle: using governor menu
jul 11 19:42:21 loopz kernel: Detected 1 PCC Subspaces
jul 11 19:42:21 loopz kernel: Registering PCC driver as Mailbox controller
jul 11 19:42:21 loopz kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
jul 11 19:42:21 loopz kernel: PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
jul 11 19:42:21 loopz kernel: PCI: Using configuration type 1 for base access
jul 11 19:42:21 loopz kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
jul 11 19:42:21 loopz kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
jul 11 19:42:21 loopz kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
jul 11 19:42:21 loopz kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
jul 11 19:42:21 loopz kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
jul 11 19:42:21 loopz kernel: ACPI: Added _OSI(Module Device)
jul 11 19:42:21 loopz kernel: ACPI: Added _OSI(Processor Device)
jul 11 19:42:21 loopz kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
jul 11 19:42:21 loopz kernel: ACPI: Added _OSI(Processor Aggregator Device)
jul 11 19:42:21 loopz kernel: ACPI: 8 ACPI AML tables successfully acquired and loaded
jul 11 19:42:21 loopz kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
jul 11 19:42:21 loopz kernel: ACPI: _OSC evaluation for CPUs failed, trying _PDC
jul 11 19:42:21 loopz kernel: ACPI: Interpreter enabled
jul 11 19:42:21 loopz kernel: ACPI: PM: (supports S0 S3 S4 S5)
jul 11 19:42:21 loopz kernel: ACPI: Using IOAPIC for interrupt routing
jul 11 19:42:21 loopz kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
jul 11 19:42:21 loopz kernel: PCI: Ignoring E820 reservations for host bridge windows
jul 11 19:42:21 loopz kernel: ACPI: Enabled 3 GPEs in block 00 to 1F
jul 11 19:42:21 loopz kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
jul 11 19:42:21 loopz kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
jul 11 19:42:21 loopz kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
jul 11 19:42:21 loopz kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
jul 11 19:42:21 loopz kernel: acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
jul 11 19:42:21 loopz kernel: PCI host bridge to bus 0000:00
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfec2ffff window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
jul 11 19:42:21 loopz kernel: pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:01.1: [1022:1483] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:00:01.3: [1022:1483] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:00:01.3: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:00:01.3: PME# supported from D0 D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:03.1: [1022:1483] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:00:07.1: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:00:08.1: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
jul 11 19:42:21 loopz kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
jul 11 19:42:21 loopz kernel: pci 0000:00:18.0: [1022:1440] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:18.1: [1022:1441] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:18.2: [1022:1442] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:18.3: [1022:1443] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:18.4: [1022:1444] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:18.5: [1022:1445] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:18.6: [1022:1446] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:00:18.7: [1022:1447] type 00 class 0x060000
jul 11 19:42:21 loopz kernel: pci 0000:01:00.0: [1ed0:2283] type 00 class 0x010802
jul 11 19:42:21 loopz kernel: pci 0000:01:00.0: reg 0x10: [mem 0xfc810000-0xfc813fff 64bit]
jul 11 19:42:21 loopz kernel: pci 0000:01:00.0: reg 0x30: [mem 0xfc800000-0xfc80ffff pref]
jul 11 19:42:21 loopz kernel: pci 0000:01:00.0: reg 0x164: [mem 0x00000000-0x00003fff 64bit]
jul 11 19:42:21 loopz kernel: pci 0000:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0003ffff 64bit] (contains BAR0 for 16 VFs)
jul 11 19:42:21 loopz kernel: pci 0000:00:01.1: PCI bridge to [bus 01]
jul 11 19:42:21 loopz kernel: pci 0000:00:01.1:   bridge window [mem 0xfc800000-0xfc8fffff]
jul 11 19:42:21 loopz kernel: pci 0000:00:01.1: bridge has subordinate 01 but max busn 02
jul 11 19:42:21 loopz kernel: pci 0000:02:00.0: [1022:43b9] type 00 class 0x0c0330
jul 11 19:42:21 loopz kernel: pci 0000:02:00.0: reg 0x10: [mem 0xfc7a0000-0xfc7a7fff 64bit]
jul 11 19:42:21 loopz kernel: pci 0000:02:00.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:02:00.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:02:00.1: [1022:43b5] type 00 class 0x010601
jul 11 19:42:21 loopz kernel: pci 0000:02:00.1: reg 0x24: [mem 0xfc780000-0xfc79ffff]
jul 11 19:42:21 loopz kernel: pci 0000:02:00.1: reg 0x30: [mem 0xfc700000-0xfc77ffff pref]
jul 11 19:42:21 loopz kernel: pci 0000:02:00.1: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:02:00.1: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:02:00.2: [1022:43b0] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:02:00.2: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:02:00.2: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:00:01.3: PCI bridge to [bus 02-0b]
jul 11 19:42:21 loopz kernel: pci 0000:00:01.3:   bridge window [io  0xd000-0xefff]
jul 11 19:42:21 loopz kernel: pci 0000:00:01.3:   bridge window [mem 0xfc500000-0xfc7fffff]
jul 11 19:42:21 loopz kernel: pci 0000:00:01.3:   bridge window [mem 0xe2100000-0xe21fffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci 0000:03:00.0: [1022:43b4] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:03:00.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:03:00.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:03:01.0: [1022:43b4] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:03:01.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:03:01.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:03:02.0: [1022:43b4] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:03:02.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:03:02.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:03:03.0: [1022:43b4] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:03:03.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:03:03.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:03:04.0: [1022:43b4] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:03:04.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:03:04.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:03:05.0: [1022:43b4] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:03:05.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:03:05.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:03:06.0: [1022:43b4] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:03:06.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:03:06.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:03:07.0: [1022:43b4] type 01 class 0x060400
jul 11 19:42:21 loopz kernel: pci 0000:03:07.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:03:07.0: PME# supported from D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:02:00.2: PCI bridge to [bus 03-0b]
jul 11 19:42:21 loopz kernel: pci 0000:02:00.2:   bridge window [io  0xd000-0xefff]
jul 11 19:42:21 loopz kernel: pci 0000:02:00.2:   bridge window [mem 0xfc500000-0xfc6fffff]
jul 11 19:42:21 loopz kernel: pci 0000:02:00.2:   bridge window [mem 0xe2100000-0xe21fffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci 0000:03:00.0: PCI bridge to [bus 04]
jul 11 19:42:21 loopz kernel: pci 0000:03:01.0: PCI bridge to [bus 05]
jul 11 19:42:21 loopz kernel: pci 0000:03:02.0: PCI bridge to [bus 06]
jul 11 19:42:21 loopz kernel: pci 0000:03:03.0: PCI bridge to [bus 07]
jul 11 19:42:21 loopz kernel: pci 0000:03:04.0: PCI bridge to [bus 08]
jul 11 19:42:21 loopz kernel: pci 0000:03:05.0: PCI bridge to [bus 09]
jul 11 19:42:21 loopz kernel: pci 0000:0a:00.0: [1b21:0612] type 00 class 0x010601
jul 11 19:42:21 loopz kernel: pci 0000:0a:00.0: reg 0x10: [io  0xe050-0xe057]
jul 11 19:42:21 loopz kernel: pci 0000:0a:00.0: reg 0x14: [io  0xe040-0xe043]
jul 11 19:42:21 loopz kernel: pci 0000:0a:00.0: reg 0x18: [io  0xe030-0xe037]
jul 11 19:42:21 loopz kernel: pci 0000:0a:00.0: reg 0x1c: [io  0xe020-0xe023]
jul 11 19:42:21 loopz kernel: pci 0000:0a:00.0: reg 0x20: [io  0xe000-0xe01f]
jul 11 19:42:21 loopz kernel: pci 0000:0a:00.0: reg 0x24: [mem 0xfc600000-0xfc6001ff]
jul 11 19:42:21 loopz kernel: pci 0000:03:06.0: PCI bridge to [bus 0a]
jul 11 19:42:21 loopz kernel: pci 0000:03:06.0:   bridge window [io  0xe000-0xefff]
jul 11 19:42:21 loopz kernel: pci 0000:03:06.0:   bridge window [mem 0xfc600000-0xfc6fffff]
jul 11 19:42:21 loopz kernel: pci 0000:0b:00.0: [10ec:8168] type 00 class 0x020000
jul 11 19:42:21 loopz kernel: pci 0000:0b:00.0: reg 0x10: [io  0xd000-0xd0ff]
jul 11 19:42:21 loopz kernel: pci 0000:0b:00.0: reg 0x18: [mem 0xfc500000-0xfc500fff 64bit]
jul 11 19:42:21 loopz kernel: pci 0000:0b:00.0: reg 0x20: [mem 0xe2100000-0xe2103fff 64bit pref]
jul 11 19:42:21 loopz kernel: pci 0000:0b:00.0: supports D1 D2
jul 11 19:42:21 loopz kernel: pci 0000:0b:00.0: PME# supported from D0 D1 D2 D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:03:07.0: PCI bridge to [bus 0b]
jul 11 19:42:21 loopz kernel: pci 0000:03:07.0:   bridge window [io  0xd000-0xdfff]
jul 11 19:42:21 loopz kernel: pci 0000:03:07.0:   bridge window [mem 0xfc500000-0xfc5fffff]
jul 11 19:42:21 loopz kernel: pci 0000:03:07.0:   bridge window [mem 0xe2100000-0xe21fffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: [10de:2488] type 00 class 0x030000
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: reg 0x10: [mem 0xfb000000-0xfbffffff]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: reg 0x1c: [mem 0xe0000000-0xe1ffffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: reg 0x24: [io  0xf000-0xf07f]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: reg 0x30: [mem 0xfc000000-0xfc07ffff pref]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: BAR 1: assigned to efifb
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: PME# supported from D0 D3hot
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:03.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.1: [10de:228b] type 00 class 0x040300
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.1: reg 0x10: [mem 0xfc080000-0xfc083fff]
jul 11 19:42:21 loopz kernel: pci 0000:00:03.1: PCI bridge to [bus 0c]
jul 11 19:42:21 loopz kernel: pci 0000:00:03.1:   bridge window [io  0xf000-0xffff]
jul 11 19:42:21 loopz kernel: pci 0000:00:03.1:   bridge window [mem 0xfb000000-0xfc0fffff]
jul 11 19:42:21 loopz kernel: pci 0000:00:03.1:   bridge window [mem 0xd0000000-0xe1ffffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci 0000:0d:00.0: [1022:148a] type 00 class 0x130000
jul 11 19:42:21 loopz kernel: pci 0000:0d:00.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:00:07.1: PCI bridge to [bus 0d]
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.0: [1022:1485] type 00 class 0x130000
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.0: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.1: [1022:1486] type 00 class 0x108000
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.1: reg 0x18: [mem 0xfc300000-0xfc3fffff]
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.1: reg 0x24: [mem 0xfc408000-0xfc409fff]
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.1: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.3: [1022:149c] type 00 class 0x0c0330
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.3: reg 0x10: [mem 0xfc200000-0xfc2fffff 64bit]
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.3: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.3: PME# supported from D0 D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.4: [1022:1487] type 00 class 0x040300
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.4: reg 0x10: [mem 0xfc400000-0xfc407fff]
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.4: enabling Extended Tags
jul 11 19:42:21 loopz kernel: pci 0000:0e:00.4: PME# supported from D0 D3hot D3cold
jul 11 19:42:21 loopz kernel: pci 0000:00:08.1: PCI bridge to [bus 0e]
jul 11 19:42:21 loopz kernel: pci 0000:00:08.1:   bridge window [mem 0xfc200000-0xfc4fffff]
jul 11 19:42:21 loopz kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
jul 11 19:42:21 loopz kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 0
jul 11 19:42:21 loopz kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
jul 11 19:42:21 loopz kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
jul 11 19:42:21 loopz kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
jul 11 19:42:21 loopz kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
jul 11 19:42:21 loopz kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
jul 11 19:42:21 loopz kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
jul 11 19:42:21 loopz kernel: iommu: Default domain type: Translated
jul 11 19:42:21 loopz kernel: iommu: DMA domain TLB invalidation policy: lazy mode
jul 11 19:42:21 loopz kernel: SCSI subsystem initialized
jul 11 19:42:21 loopz kernel: libata version 3.00 loaded.
jul 11 19:42:21 loopz kernel: ACPI: bus type USB registered
jul 11 19:42:21 loopz kernel: usbcore: registered new interface driver usbfs
jul 11 19:42:21 loopz kernel: usbcore: registered new interface driver hub
jul 11 19:42:21 loopz kernel: usbcore: registered new device driver usb
jul 11 19:42:21 loopz kernel: pps_core: LinuxPPS API ver. 1 registered
jul 11 19:42:21 loopz kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
jul 11 19:42:21 loopz kernel: PTP clock support registered
jul 11 19:42:21 loopz kernel: EDAC MC: Ver: 3.0.0
jul 11 19:42:21 loopz kernel: efivars: Registered efivars operations
jul 11 19:42:21 loopz kernel: NetLabel: Initializing
jul 11 19:42:21 loopz kernel: NetLabel:  domain hash size = 128
jul 11 19:42:21 loopz kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
jul 11 19:42:21 loopz kernel: NetLabel:  unlabeled traffic allowed by default
jul 11 19:42:21 loopz kernel: mctp: management component transport protocol core
jul 11 19:42:21 loopz kernel: NET: Registered PF_MCTP protocol family
jul 11 19:42:21 loopz kernel: PCI: Using ACPI for IRQ routing
jul 11 19:42:21 loopz kernel: PCI: pci_cache_line_size set to 64 bytes
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0x09bff000-0x0bffffff]
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0xb39c3000-0xb3ffffff]
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0xb64f2018-0xb7ffffff]
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0xb6fc9000-0xb7ffffff]
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0xbb402000-0xbbffffff]
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0xbf000000-0xbfffffff]
jul 11 19:42:21 loopz kernel: e820: reserve RAM buffer [mem 0x83f380000-0x83fffffff]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: vgaarb: setting as boot VGA device
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: vgaarb: bridge control possible
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
jul 11 19:42:21 loopz kernel: vgaarb: loaded
jul 11 19:42:21 loopz kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
jul 11 19:42:21 loopz kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter
jul 11 19:42:21 loopz kernel: clocksource: Switched to clocksource tsc-early
jul 11 19:42:21 loopz kernel: VFS: Disk quotas dquot_6.6.0
jul 11 19:42:21 loopz kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
jul 11 19:42:21 loopz kernel: pnp: PnP ACPI init
jul 11 19:42:21 loopz kernel: system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
jul 11 19:42:21 loopz kernel: system 00:01: [mem 0xfeb80000-0xfebfffff] has been reserved
jul 11 19:42:21 loopz kernel: system 00:02: [mem 0xfd200000-0xfd2fffff] has been reserved
jul 11 19:42:21 loopz kernel: system 00:04: [io  0x0280-0x028f] has been reserved
jul 11 19:42:21 loopz kernel: system 00:04: [io  0x0290-0x029f] has been reserved
jul 11 19:42:21 loopz kernel: system 00:04: [io  0x02a0-0x02af] has been reserved
jul 11 19:42:21 loopz kernel: system 00:04: [io  0x02b0-0x02bf] has been reserved
jul 11 19:42:21 loopz kernel: pnp 00:05: [dma 0 disabled]
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x04d0-0x04d1] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x040b] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x04d6] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0c00-0x0c01] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0c14] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0c50-0x0c51] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0c52] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0c6c] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0c6f] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0cd8-0x0cdf] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0800-0x089f] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0b00-0x0b0f] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0b20-0x0b3f] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0900-0x090f] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [io  0x0910-0x091f] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
jul 11 19:42:21 loopz kernel: system 00:06: [mem 0xfec01000-0xfec01fff] could not be reserved
jul 11 19:42:21 loopz kernel: system 00:06: [mem 0xfedc0000-0xfedc0fff] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [mem 0xfed80000-0xfed8ffff] could not be reserved
jul 11 19:42:21 loopz kernel: system 00:06: [mem 0xfec10000-0xfec10fff] has been reserved
jul 11 19:42:21 loopz kernel: system 00:06: [mem 0xff000000-0xffffffff] has been reserved
jul 11 19:42:21 loopz kernel: pnp: PnP ACPI: found 7 devices
(unless you have reasons against it, you can also just share the link the commands output)
Gotta add that maybe I did things i’m not aware of since i’m newbie, was just trying to fix my wifi. My bluetooth also isn’t working since I passed the installation phase.
jul 11 19:42:21 loopz kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
jul 11 19:42:21 loopz kernel: NET: Registered PF_INET protocol family
jul 11 19:42:21 loopz kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
jul 11 19:42:21 loopz kernel: tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
jul 11 19:42:21 loopz kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
jul 11 19:42:21 loopz kernel: TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
jul 11 19:42:21 loopz kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
jul 11 19:42:21 loopz kernel: TCP: Hash tables configured (established 262144 bind 65536)
jul 11 19:42:21 loopz kernel: MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
jul 11 19:42:21 loopz kernel: UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
jul 11 19:42:21 loopz kernel: UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
jul 11 19:42:21 loopz kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
jul 11 19:42:21 loopz kernel: NET: Registered PF_XDP protocol family
jul 11 19:42:21 loopz kernel: pci 0000:01:00.0: BAR 7: assigned [mem 0xfc814000-0xfc853fff 64bit]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: resource 9 [mem 0xc0000000-0xfec2ffff window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:00: resource 10 [mem 0xfee00000-0xffffffff window]
jul 11 19:42:21 loopz kernel: pci_bus 0000:01: resource 1 [mem 0xfc800000-0xfc8fffff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:02: resource 0 [io  0xd000-0xefff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:02: resource 1 [mem 0xfc500000-0xfc7fffff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:02: resource 2 [mem 0xe2100000-0xe21fffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci_bus 0000:03: resource 0 [io  0xd000-0xefff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:03: resource 1 [mem 0xfc500000-0xfc6fffff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:03: resource 2 [mem 0xe2100000-0xe21fffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0a: resource 0 [io  0xe000-0xefff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0a: resource 1 [mem 0xfc600000-0xfc6fffff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0b: resource 0 [io  0xd000-0xdfff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0b: resource 1 [mem 0xfc500000-0xfc5fffff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0b: resource 2 [mem 0xe2100000-0xe21fffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0c: resource 0 [io  0xf000-0xffff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0c: resource 1 [mem 0xfb000000-0xfc0fffff]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0c: resource 2 [mem 0xd0000000-0xe1ffffff 64bit pref]
jul 11 19:42:21 loopz kernel: pci_bus 0000:0e: resource 1 [mem 0xfc200000-0xfc4fffff]
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.1: extending delay after power-on from D3hot to 20 msec
jul 11 19:42:21 loopz kernel: pci 0000:0c:00.1: D0 power state depends on 0000:0c:00.0
jul 11 19:42:21 loopz kernel: PCI: CLS 64 bytes, default 64
jul 11 19:42:21 loopz kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
jul 11 19:42:21 loopz kernel: software IO TLB: mapped [mem 0x00000000af946000-0x00000000b3946000] (64MB)
jul 11 19:42:21 loopz kernel: Trying to unpack rootfs image as initramfs...
jul 11 19:42:21 loopz kernel: LVT offset 0 assigned for vector 0x400
jul 11 19:42:21 loopz kernel: perf: AMD IBS detected (0x000003ff)
jul 11 19:42:21 loopz kernel: Initialise system trusted keyrings
jul 11 19:42:21 loopz kernel: Key type blacklist registered
jul 11 19:42:21 loopz kernel: workingset: timestamp_bits=41 max_order=23 bucket_order=0
jul 11 19:42:21 loopz kernel: zbud: loaded
jul 11 19:42:21 loopz kernel: integrity: Platform Keyring initialized
jul 11 19:42:21 loopz kernel: integrity: Machine keyring initialized
jul 11 19:42:21 loopz kernel: Key type asymmetric registered
jul 11 19:42:21 loopz kernel: Asymmetric key parser 'x509' registered
jul 11 19:42:21 loopz kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
jul 11 19:42:21 loopz kernel: io scheduler mq-deadline registered
jul 11 19:42:21 loopz kernel: io scheduler kyber registered
jul 11 19:42:21 loopz kernel: io scheduler bfq registered
jul 11 19:42:21 loopz kernel: pcieport 0000:00:01.1: PME: Signaling with IRQ 26
jul 11 19:42:21 loopz kernel: pcieport 0000:00:01.1: AER: enabled with IRQ 26
jul 11 19:42:21 loopz kernel: pcieport 0000:00:01.3: PME: Signaling with IRQ 27
jul 11 19:42:21 loopz kernel: pcieport 0000:00:01.3: AER: enabled with IRQ 27
jul 11 19:42:21 loopz kernel: pcieport 0000:00:03.1: PME: Signaling with IRQ 28
jul 11 19:42:21 loopz kernel: pcieport 0000:00:03.1: AER: enabled with IRQ 28
jul 11 19:42:21 loopz kernel: pcieport 0000:00:07.1: PME: Signaling with IRQ 30
jul 11 19:42:21 loopz kernel: pcieport 0000:00:07.1: AER: enabled with IRQ 30
jul 11 19:42:21 loopz kernel: pcieport 0000:00:08.1: PME: Signaling with IRQ 31
jul 11 19:42:21 loopz kernel: pcieport 0000:00:08.1: AER: enabled with IRQ 31
jul 11 19:42:21 loopz kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
jul 11 19:42:21 loopz kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
jul 11 19:42:21 loopz kernel: ACPI: button: Power Button [PWRB]
jul 11 19:42:21 loopz kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
jul 11 19:42:21 loopz kernel: ACPI: button: Power Button [PWRF]
jul 11 19:42:21 loopz kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1220
jul 11 19:42:21 loopz kernel: Monitor-Mwait will be used to enter C-1 state
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C000: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C002: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C004: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C006: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C008: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C00A: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C00C: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C00E: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C001: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C003: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C005: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C007: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C009: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C00B: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C00D: Found 2 idle states
jul 11 19:42:21 loopz kernel: ACPI: \_PR_.C00F: Found 2 idle states
jul 11 19:42:21 loopz kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
jul 11 19:42:21 loopz kernel: 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
jul 11 19:42:21 loopz kernel: Non-volatile memory driver v1.3
jul 11 19:42:21 loopz kernel: Linux agpgart interface v0.103
jul 11 19:42:21 loopz kernel: tpm_crb MSFT0101:00: Disabling hwrng
jul 11 19:42:21 loopz kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
jul 11 19:42:21 loopz kernel: ACPI: bus type drm_connector registered
jul 11 19:42:21 loopz kernel: ahci 0000:02:00.1: version 3.0
jul 11 19:42:21 loopz kernel: ahci 0000:02:00.1: SSS flag set, parallel bus scan disabled
jul 11 19:42:21 loopz kernel: ahci 0000:02:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0xff impl SATA mode
jul 11 19:42:21 loopz kernel: ahci 0000:02:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
jul 11 19:42:21 loopz kernel: scsi host0: ahci
jul 11 19:42:21 loopz kernel: scsi host1: ahci
jul 11 19:42:21 loopz kernel: scsi host2: ahci
jul 11 19:42:21 loopz kernel: scsi host3: ahci
jul 11 19:42:21 loopz kernel: scsi host4: ahci
jul 11 19:42:21 loopz kernel: scsi host5: ahci
jul 11 19:42:21 loopz kernel: scsi host6: ahci
jul 11 19:42:21 loopz kernel: scsi host7: ahci
jul 11 19:42:21 loopz kernel: ata1: SATA max UDMA/133 abar m131072@0xfc780000 port 0xfc780100 irq 42
jul 11 19:42:21 loopz kernel: ata2: SATA max UDMA/133 abar m131072@0xfc780000 port 0xfc780180 irq 42
jul 11 19:42:21 loopz kernel: ata3: SATA max UDMA/133 abar m131072@0xfc780000 port 0xfc780200 irq 42
jul 11 19:42:21 loopz kernel: ata4: SATA max UDMA/133 abar m131072@0xfc780000 port 0xfc780280 irq 42
jul 11 19:42:21 loopz kernel: ata5: SATA max UDMA/133 abar m131072@0xfc780000 port 0xfc780300 irq 42
jul 11 19:42:21 loopz kernel: ata6: SATA max UDMA/133 abar m131072@0xfc780000 port 0xfc780380 irq 42
jul 11 19:42:21 loopz kernel: ata7: SATA max UDMA/133 abar m131072@0xfc780000 port 0xfc780400 irq 42
jul 11 19:42:21 loopz kernel: ata8: SATA max UDMA/133 abar m131072@0xfc780000 port 0xfc780480 irq 42
jul 11 19:42:21 loopz kernel: ahci 0000:0a:00.0: SSS flag set, parallel bus scan disabled
jul 11 19:42:21 loopz kernel: ahci 0000:0a:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
jul 11 19:42:21 loopz kernel: ahci 0000:0a:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc
jul 11 19:42:21 loopz kernel: scsi host8: ahci
jul 11 19:42:21 loopz kernel: scsi host9: ahci
jul 11 19:42:21 loopz kernel: ata9: SATA max UDMA/133 abar m512@0xfc600000 port 0xfc600100 irq 43
jul 11 19:42:21 loopz kernel: ata10: SATA max UDMA/133 abar m512@0xfc600000 port 0xfc600180 irq 43
jul 11 19:42:21 loopz kernel: usbcore: registered new interface driver usbserial_generic
jul 11 19:42:21 loopz kernel: usbserial: USB Serial support registered for generic
jul 11 19:42:21 loopz kernel: rtc_cmos 00:03: RTC can wake from S4
jul 11 19:42:21 loopz kernel: rtc_cmos 00:03: registered as rtc0
jul 11 19:42:21 loopz kernel: rtc_cmos 00:03: setting system clock to 2024-07-11T22:42:18 UTC (1720737738)
jul 11 19:42:21 loopz kernel: rtc_cmos 00:03: alarms up to one month, y3k, 114 bytes nvram
jul 11 19:42:21 loopz kernel: amd_pstate: driver load is disabled, boot with specific mode to enable this
jul 11 19:42:21 loopz kernel: ledtrig-cpu: registered to indicate activity on CPUs
jul 11 19:42:21 loopz kernel: efifb: probing for efifb
jul 11 19:42:21 loopz kernel: efifb: framebuffer at 0xd0000000, using 8100k, total 8100k
jul 11 19:42:21 loopz kernel: efifb: mode is 1920x1080x32, linelength=7680, pages=1
jul 11 19:42:21 loopz kernel: efifb: scrolling: redraw
jul 11 19:42:21 loopz kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
jul 11 19:42:21 loopz kernel: fbcon: Deferring console take-over
jul 11 19:42:21 loopz kernel: fb0: EFI VGA frame buffer device
jul 11 19:42:21 loopz kernel: hid: raw HID events driver (C) Jiri Kosina
jul 11 19:42:21 loopz kernel: drop_monitor: Initializing network drop monitor service
jul 11 19:42:21 loopz kernel: Initializing XFRM netlink socket
jul 11 19:42:21 loopz kernel: NET: Registered PF_INET6 protocol family
jul 11 19:42:21 loopz kernel: Freeing initrd memory: 97788K
jul 11 19:42:21 loopz kernel: Segment Routing with IPv6
jul 11 19:42:21 loopz kernel: RPL Segment Routing with IPv6
jul 11 19:42:21 loopz kernel: In-situ OAM (IOAM) with IPv6
jul 11 19:42:21 loopz kernel: NET: Registered PF_PACKET protocol family
jul 11 19:42:21 loopz kernel: microcode: CPU0: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU2: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU3: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU6: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU8: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU5: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU4: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU7: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU9: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU10: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU11: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU1: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU12: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU13: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU14: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: CPU15: patch_level=0x0a20120e
jul 11 19:42:21 loopz kernel: microcode: Microcode Update Driver: v2.2.
jul 11 19:42:21 loopz kernel: resctrl: L3 allocation detected
jul 11 19:42:21 loopz kernel: resctrl: MB allocation detected
jul 11 19:42:21 loopz kernel: resctrl: L3 monitoring detected
jul 11 19:42:21 loopz kernel: IPI shorthand broadcast: enabled
jul 11 19:42:21 loopz kernel: sched_clock: Marking stable (540007602, 255260)->(556056501, -15793639)
jul 11 19:42:21 loopz kernel: registered taskstats version 1
jul 11 19:42:21 loopz kernel: Loading compiled-in X.509 certificates
jul 11 19:42:21 loopz kernel: Loaded X.509 cert 'Build time autogenerated kernel key: a9dab79398e058d5fb31732224f25766cb1a0700'
jul 11 19:42:21 loopz kernel: zswap: loaded using pool zstd/zsmalloc
jul 11 19:42:21 loopz kernel: Key type .fscrypt registered
jul 11 19:42:21 loopz kernel: Key type fscrypt-provisioning registered
jul 11 19:42:21 loopz kernel: integrity: Loading X.509 certificate: UEFI:db
jul 11 19:42:21 loopz kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
jul 11 19:42:21 loopz kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
jul 11 19:42:21 loopz kernel: PM:   Magic number: 0:851:754
jul 11 19:42:21 loopz kernel: ata_link link5: hash matches
jul 11 19:42:21 loopz kernel:  link5: hash matches
jul 11 19:42:21 loopz kernel: tty ttyS5: hash matches
jul 11 19:42:21 loopz kernel: RAS: Correctable Errors collector initialized.
jul 11 19:42:21 loopz kernel: ata9: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
jul 11 19:42:21 loopz kernel: ata1.00: ATA-10: SanDisk SSD PLUS 1000GB, UH4504RL, max UDMA/133
jul 11 19:42:21 loopz kernel: ata1.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32)
jul 11 19:42:21 loopz kernel: ata1.00: Features: Dev-Sleep
jul 11 19:42:21 loopz kernel: ata1.00: configured for UDMA/133
jul 11 19:42:21 loopz kernel: scsi 0:0:0:0: Direct-Access     ATA      SanDisk SSD PLUS 04RL PQ: 0 ANSI: 5
jul 11 19:42:21 loopz kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
jul 11 19:42:21 loopz kernel: sd 0:0:0:0: [sda] Write Protect is off
jul 11 19:42:21 loopz kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
jul 11 19:42:21 loopz kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
jul 11 19:42:21 loopz kernel: sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
jul 11 19:42:21 loopz kernel:  sda: sda1 sda2
jul 11 19:42:21 loopz kernel: sd 0:0:0:0: [sda] Attached SCSI disk
jul 11 19:42:21 loopz kernel: ata2: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: tsc: Refined TSC clocksource calibration: 2994.374 MHz
jul 11 19:42:21 loopz kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b29828a32c, max_idle_ns: 440795270613 ns
jul 11 19:42:21 loopz kernel: ata3: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: ata4: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: ata5: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: ata6: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: ata7: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: ata8: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: ata10: SATA link down (SStatus 0 SControl 300)
jul 11 19:42:21 loopz kernel: clk: Disabling unused clocks
jul 11 19:42:21 loopz kernel: Freeing unused decrypted memory: 2028K
jul 11 19:42:21 loopz kernel: Freeing unused kernel image (initmem) memory: 3420K
jul 11 19:42:21 loopz kernel: Write protecting the kernel read-only data: 30720k
jul 11 19:42:21 loopz kernel: Freeing unused kernel image (rodata/data gap) memory: 1316K
jul 11 19:42:21 loopz kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
jul 11 19:42:21 loopz kernel: rodata_test: all tests were successful
jul 11 19:42:21 loopz kernel: Run /init as init process
jul 11 19:42:21 loopz kernel:   with arguments:
jul 11 19:42:21 loopz kernel:     /init
jul 11 19:42:21 loopz kernel:   with environment:
jul 11 19:42:21 loopz kernel:     HOME=/
jul 11 19:42:21 loopz kernel:     TERM=linux
jul 11 19:42:21 loopz kernel:     nvme_load=YES
jul 11 19:42:21 loopz systemd[1]: Successfully made /usr/ read-only.
jul 11 19:42:21 loopz systemd[1]: systemd 256.2-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
jul 11 19:42:21 loopz systemd[1]: Detected architecture x86-64.
jul 11 19:42:21 loopz systemd[1]: Running in initrd.
jul 11 19:42:21 loopz kernel: fbcon: Taking over console
jul 11 19:42:21 loopz kernel: Console: switching to colour frame buffer device 240x67
jul 11 19:42:21 loopz systemd[1]: Hostname set to <loopz>.
jul 11 19:42:21 loopz systemd[1]: Queued start job for default target Initrd Default Target.
jul 11 19:42:21 loopz systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
jul 11 19:42:21 loopz systemd[1]: Expecting device /dev/disk/by-uuid/0619913a-9aad-4f73-8f6f-56f5c815c99f...
jul 11 19:42:21 loopz systemd[1]: Expecting device /dev/disk/by-uuid/2fa1c21f-8991-4be8-a4e7-0ac469e17972...
jul 11 19:42:21 loopz systemd[1]: Reached target Initrd /usr File System.
jul 11 19:42:21 loopz systemd[1]: Reached target Path Units.
jul 11 19:42:21 loopz systemd[1]: Reached target Slice Units.
jul 11 19:42:21 loopz systemd[1]: Reached target Swaps.
jul 11 19:42:21 loopz systemd[1]: Reached target Timer Units.
jul 11 19:42:21 loopz systemd[1]: Listening on Journal Socket (/dev/log).
jul 11 19:42:21 loopz systemd[1]: Listening on Journal Sockets.
jul 11 19:42:21 loopz systemd[1]: Listening on udev Control Socket.
jul 11 19:42:21 loopz systemd[1]: Listening on udev Kernel Socket.
jul 11 19:42:21 loopz systemd[1]: Reached target Socket Units.
jul 11 19:42:21 loopz systemd[1]: Starting Create List of Static Device Nodes...
jul 11 19:42:21 loopz systemd[1]: Starting Journal Service...
jul 11 19:42:21 loopz systemd[1]: Starting Load Kernel Modules...
jul 11 19:42:21 loopz systemd[1]: Starting Virtual Console Setup...
jul 11 19:42:21 loopz systemd[1]: Finished Create List of Static Device Nodes.
jul 11 19:42:21 loopz systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
jul 11 19:42:21 loopz systemd[1]: Finished Virtual Console Setup.
jul 11 19:42:21 loopz systemd[1]: dracut ask for additional cmdline parameters was skipped because no trigger condition checks were met.
jul 11 19:42:21 loopz systemd[1]: Starting dracut cmdline hook...
jul 11 19:42:21 loopz systemd-journald[251]: Collecting audit messages is disabled.
jul 11 19:42:21 loopz kernel: i2c_dev: i2c /dev entries driver
jul 11 19:42:21 loopz systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
jul 11 19:42:21 loopz systemd[1]: Starting Create System Users...
jul 11 19:42:21 loopz systemd[1]: Finished Create System Users.
jul 11 19:42:21 loopz systemd[1]: Starting Create Static Device Nodes in /dev...
jul 11 19:42:21 loopz systemd[1]: Finished Create Static Device Nodes in /dev.
jul 11 19:42:21 loopz systemd[1]: Started Journal Service.
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:02:00.0: xHCI Host Controller
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 1
jul 11 19:42:21 loopz kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
jul 11 19:42:21 loopz kernel: sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
jul 11 19:42:21 loopz kernel: sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
jul 11 19:42:21 loopz kernel: ccp 0000:0e:00.1: enabling device (0000 -> 0002)
jul 11 19:42:21 loopz kernel: ccp 0000:0e:00.1: ccp: unable to access the device: you might be running a broken BIOS.
jul 11 19:42:21 loopz kernel: ccp 0000:0e:00.1: psp enabled
jul 11 19:42:21 loopz kernel: cryptd: max_cpu_qlen set to 1000
jul 11 19:42:21 loopz kernel: nvme nvme0: pci function 0000:01:00.0
jul 11 19:42:21 loopz kernel: AVX2 version of gcm_enc/dec engaged.
jul 11 19:42:21 loopz kernel: AES CTR mode by8 optimization enabled
jul 11 19:42:21 loopz kernel: nvme nvme0: missing or invalid SUBNQN field.
jul 11 19:42:21 loopz kernel: nvme nvme0: allocated 128 MiB host memory buffer.
jul 11 19:42:21 loopz kernel: nvme nvme0: 8/0/0 default/read/poll queues
jul 11 19:42:21 loopz kernel:  nvme0n1: p1 p2 p3
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:02:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000010008000410
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 2
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:02:00.0: Host supports USB 3.1 Enhanced SuperSpeed
jul 11 19:42:21 loopz kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
jul 11 19:42:21 loopz kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
jul 11 19:42:21 loopz kernel: usb usb1: Product: xHCI Host Controller
jul 11 19:42:21 loopz kernel: usb usb1: Manufacturer: Linux 6.6.38-1-lts xhci-hcd
jul 11 19:42:21 loopz kernel: usb usb1: SerialNumber: 0000:02:00.0
jul 11 19:42:21 loopz kernel: hub 1-0:1.0: USB hub found
jul 11 19:42:21 loopz kernel: hub 1-0:1.0: 14 ports detected
jul 11 19:42:21 loopz kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
jul 11 19:42:21 loopz kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
jul 11 19:42:21 loopz kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
jul 11 19:42:21 loopz kernel: usb usb2: Product: xHCI Host Controller
jul 11 19:42:21 loopz kernel: usb usb2: Manufacturer: Linux 6.6.38-1-lts xhci-hcd
jul 11 19:42:21 loopz kernel: usb usb2: SerialNumber: 0000:02:00.0
jul 11 19:42:21 loopz kernel: hub 2-0:1.0: USB hub found
jul 11 19:42:21 loopz kernel: hub 2-0:1.0: 8 ports detected
jul 11 19:42:21 loopz kernel: usb: port power management may be unreliable
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:0e:00.3: xHCI Host Controller
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:0e:00.3: new USB bus registered, assigned bus number 3
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:0e:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:0e:00.3: new USB bus registered, assigned bus number 4
jul 11 19:42:21 loopz kernel: xhci_hcd 0000:0e:00.3: Host supports USB 3.1 Enhanced SuperSpeed
jul 11 19:42:21 loopz kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
jul 11 19:42:21 loopz kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
jul 11 19:42:21 loopz kernel: usb usb3: Product: xHCI Host Controller
jul 11 19:42:21 loopz kernel: usb usb3: Manufacturer: Linux 6.6.38-1-lts xhci-hcd
jul 11 19:42:21 loopz kernel: usb usb3: SerialNumber: 0000:0e:00.3
jul 11 19:42:21 loopz kernel: hub 3-0:1.0: USB hub found
jul 11 19:42:21 loopz kernel: hub 3-0:1.0: 4 ports detected
jul 11 19:42:21 loopz kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
jul 11 19:42:21 loopz kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
jul 11 19:42:21 loopz kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
jul 11 19:42:21 loopz kernel: usb usb4: Product: xHCI Host Controller
jul 11 19:42:21 loopz kernel: usb usb4: Manufacturer: Linux 6.6.38-1-lts xhci-hcd
jul 11 19:42:21 loopz kernel: usb usb4: SerialNumber: 0000:0e:00.3
jul 11 19:42:21 loopz kernel: hub 4-0:1.0: USB hub found
jul 11 19:42:21 loopz kernel: hub 4-0:1.0: 4 ports detected
jul 11 19:42:21 loopz kernel: PM: Image not found (code -22)
jul 11 19:42:22 loopz kernel: usb 1-2: new full-speed USB device number 2 using xhci_hcd
jul 11 19:42:22 loopz kernel: usb 3-2: new low-speed USB device number 2 using xhci_hcd
jul 11 19:42:22 loopz kernel: nvidia: loading out-of-tree module taints kernel.
jul 11 19:42:22 loopz kernel: nvidia: module license 'NVIDIA' taints kernel.
jul 11 19:42:22 loopz kernel: Disabling lock debugging due to kernel taint
jul 11 19:42:22 loopz kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
jul 11 19:42:22 loopz kernel: nvidia: module license taints kernel.
jul 11 19:42:22 loopz kernel: usb 3-2: New USB device found, idVendor=0e8f, idProduct=0022, bcdDevice= 2.10
jul 11 19:42:22 loopz kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
jul 11 19:42:22 loopz kernel: usb 3-2: Product: USB KB V11
jul 11 19:42:22 loopz kernel: usb 3-2: Manufacturer: GASIA
jul 11 19:42:22 loopz kernel: usb 1-2: New USB device found, idVendor=1ea7, idProduct=0064, bcdDevice= 2.00
jul 11 19:42:22 loopz kernel: usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
jul 11 19:42:22 loopz kernel: usb 1-2: Product: 2.4G Mouse
jul 11 19:42:22 loopz kernel: usb 3-3: new full-speed USB device number 3 using xhci_hcd
jul 11 19:42:22 loopz kernel: usb 1-9: new full-speed USB device number 3 using xhci_hcd
jul 11 19:42:22 loopz kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 235
jul 11 19:42:22 loopz kernel: nvidia 0000:0c:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
jul 11 19:42:22 loopz kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  555.58.02  Tue Jun 25 01:39:15 UTC 2024
jul 11 19:42:22 loopz kernel: usb 3-3: New USB device found, idVendor=248a, idProduct=8367, bcdDevice= 1.00
jul 11 19:42:22 loopz kernel: usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
jul 11 19:42:22 loopz kernel: usb 3-3: Product: Wireless Receiver
jul 11 19:42:22 loopz kernel: usb 3-3: Manufacturer: Telink
jul 11 19:42:22 loopz kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
jul 11 19:42:22 loopz kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  555.58.02  Tue Jun 25 01:10:21 UTC 2024
jul 11 19:42:22 loopz kernel: [drm] [nvidia-drm] [GPU ID 0x00000c00] Loading driver
jul 11 19:42:22 loopz kernel: usb 3-4: new high-speed USB device number 4 using xhci_hcd
jul 11 19:42:22 loopz kernel: EXT4-fs (nvme0n1p2): mounted filesystem 2fa1c21f-8991-4be8-a4e7-0ac469e17972 r/w with ordered data mode. Quota mode: none.
jul 11 19:42:22 loopz kernel: usb 1-9: New USB device found, idVendor=8087, idProduct=0032, bcdDevice= 0.00
jul 11 19:42:22 loopz kernel: usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
jul 11 19:42:22 loopz kernel: input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/usb3/3-2/3-2:1.0/0003:0E8F:0022.0001/input/input2
jul 11 19:42:22 loopz kernel: usb 3-4: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
jul 11 19:42:22 loopz kernel: usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
jul 11 19:42:22 loopz kernel: usb 3-4: Product: 802.11n NIC
jul 11 19:42:22 loopz kernel: usb 3-4: Manufacturer: Realtek
jul 11 19:42:22 loopz kernel: usb 3-4: SerialNumber: 00E04C0001
jul 11 19:42:22 loopz kernel: hid-generic 0003:0E8F:0022.0001: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:0e:00.3-2/input0
jul 11 19:42:22 loopz kernel: input: GASIA USB KB V11 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/usb3/3-2/3-2:1.1/0003:0E8F:0022.0002/input/input3
jul 11 19:42:23 loopz kernel: input: GASIA USB KB V11 System Control as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/usb3/3-2/3-2:1.1/0003:0E8F:0022.0002/input/input4
jul 11 19:42:23 loopz kernel: hid-generic 0003:0E8F:0022.0002: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:0e:00.3-2/input1
jul 11 19:42:23 loopz kernel: input: 2.4G Mouse as /devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-2/1-2:1.0/0003:1EA7:0064.0003/input/input5
jul 11 19:42:23 loopz kernel: input: 2.4G Mouse as /devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-2/1-2:1.0/0003:1EA7:0064.0003/input/input6
jul 11 19:42:23 loopz kernel: hid-generic 0003:1EA7:0064.0003: input,hiddev96,hidraw2: USB HID v1.10 Mouse [2.4G Mouse] on usb-0000:02:00.0-2/input0
jul 11 19:42:23 loopz kernel: input: Telink Wireless Receiver Mouse as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/usb3/3-3/3-3:1.0/0003:248A:8367.0004/input/input7
jul 11 19:42:23 loopz kernel: input: Telink Wireless Receiver Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/usb3/3-3/3-3:1.0/0003:248A:8367.0004/input/input8
jul 11 19:42:23 loopz kernel: input: Telink Wireless Receiver System Control as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/usb3/3-3/3-3:1.0/0003:248A:8367.0004/input/input9
jul 11 19:42:23 loopz kernel: hid-generic 0003:248A:8367.0004: input,hidraw3: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:0e:00.3-3/input0
jul 11 19:42:23 loopz kernel: input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/usb3/3-3/3-3:1.1/0003:248A:8367.0005/input/input10
jul 11 19:42:23 loopz kernel: hid-generic 0003:248A:8367.0005: input,hidraw4: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:0e:00.3-3/input1
jul 11 19:42:23 loopz kernel: usbcore: registered new interface driver usbhid
jul 11 19:42:23 loopz kernel: usbhid: USB HID core driver
jul 11 19:42:24 loopz kernel: nvidia-uvm: Loaded the UVM driver, major device number 511.
jul 11 19:42:24 loopz kernel: Asymmetric key parser 'pkcs8' registered
jul 11 19:42:24 loopz kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:0c:00.0 on minor 0
jul 11 19:42:25 loopz systemd-journald[251]: Received SIGTERM from PID 1 (systemd).
jul 11 19:42:25 loopz systemd[1]: systemd 256.2-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
jul 11 19:42:25 loopz systemd[1]: Detected architecture x86-64.
jul 11 19:42:25 loopz kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
jul 11 19:42:25 loopz systemd[1]: bpf-restrict-fs: LSM BPF program attached
jul 11 19:42:25 loopz systemd[1]: run-credentials-systemd\x2djournald.service.mount: Deactivated successfully.
jul 11 19:42:25 loopz systemd[1]: initrd-switch-root.service: Deactivated successfully.
jul 11 19:42:25 loopz systemd[1]: Stopped Switch Root.
jul 11 19:42:25 loopz systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
jul 11 19:42:25 loopz systemd[1]: Created slice Slice /system/dirmngr.
jul 11 19:42:25 loopz systemd[1]: Created slice Slice /system/getty.
jul 11 19:42:25 loopz systemd[1]: Created slice Slice /system/gpg-agent.
jul 11 19:42:25 loopz systemd[1]: Created slice Slice /system/gpg-agent-browser.
jul 11 19:42:25 loopz systemd[1]: Created slice Slice /system/gpg-agent-extra.
jul 11 19:42:25 loopz systemd[1]: Created slice Slice /system/gpg-agent-ssh.
jul 11 19:42:25 loopz systemd[1]: Created slice Slice /system/keyboxd.
jul 11 19:42:25 loopz systemd[1]: Created slice Slice /system/systemd-fsck.
jul 11 19:42:25 loopz systemd[1]: Created slice User and Session Slice.
jul 11 19:42:25 loopz systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
jul 11 19:42:25 loopz systemd[1]: Started Forward Password Requests to Wall Directory Watch.
jul 11 19:42:25 loopz systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
jul 11 19:42:25 loopz systemd[1]: Expecting device /dev/disk/by-uuid/0619913a-9aad-4f73-8f6f-56f5c815c99f...
jul 11 19:42:25 loopz systemd[1]: Expecting device /dev/disk/by-uuid/834E-F2E0...
jul 11 19:42:25 loopz systemd[1]: Reached target Local Encrypted Volumes.
jul 11 19:42:25 loopz systemd[1]: Reached target Login Prompts.
jul 11 19:42:25 loopz systemd[1]: Stopped target Switch Root.
jul 11 19:42:25 loopz systemd[1]: Stopped target Initrd File Systems.
jul 11 19:42:25 loopz systemd[1]: Stopped target Initrd Root File System.
jul 11 19:42:25 loopz systemd[1]: Reached target Local Integrity Protected Volumes.
jul 11 19:42:25 loopz systemd[1]: Reached target Remote File Systems.
jul 11 19:42:25 loopz systemd[1]: Reached target Slice Units.
jul 11 19:42:25 loopz systemd[1]: Reached target Local Verity Protected Volumes.
jul 11 19:42:25 loopz systemd[1]: Listening on Device-mapper event daemon FIFOs.
jul 11 19:42:25 loopz systemd[1]: Listening on LVM2 poll daemon socket.
jul 11 19:42:25 loopz systemd[1]: Listening on Process Core Dump Socket.
jul 11 19:42:25 loopz systemd[1]: Listening on Credential Encryption/Decryption.
jul 11 19:42:25 loopz systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
jul 11 19:42:25 loopz systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
jul 11 19:42:25 loopz systemd[1]: Listening on udev Control Socket.
jul 11 19:42:25 loopz systemd[1]: Listening on udev Kernel Socket.
jul 11 19:42:25 loopz systemd[1]: Listening on User Database Manager Socket.
jul 11 19:42:25 loopz systemd[1]: Mounting Huge Pages File System...
jul 11 19:42:25 loopz systemd[1]: Mounting POSIX Message Queue File System...
jul 11 19:42:25 loopz systemd[1]: Mounting Kernel Debug File System...
jul 11 19:42:25 loopz systemd[1]: Mounting Kernel Trace File System...
jul 11 19:42:25 loopz systemd[1]: Starting Create List of Static Device Nodes...
jul 11 19:42:25 loopz systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
jul 11 19:42:25 loopz systemd[1]: Starting Load Kernel Module configfs...
jul 11 19:42:25 loopz systemd[1]: Starting Load Kernel Module dm_mod...
jul 11 19:42:25 loopz systemd[1]: Starting Load Kernel Module drm...
jul 11 19:42:25 loopz systemd[1]: Starting Load Kernel Module fuse...
jul 11 19:42:25 loopz systemd[1]: Starting Load Kernel Module loop...
jul 11 19:42:25 loopz systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
jul 11 19:42:25 loopz systemd[1]: Starting Journal Service...
jul 11 19:42:25 loopz systemd[1]: Starting Load Kernel Modules...
jul 11 19:42:25 loopz systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
jul 11 19:42:25 loopz systemd[1]: Starting Remount Root and Kernel File Systems...
jul 11 19:42:25 loopz systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
jul 11 19:42:25 loopz systemd[1]: Starting Load udev Rules from Credentials...
jul 11 19:42:25 loopz systemd[1]: Starting Coldplug All udev Devices...
jul 11 19:42:25 loopz systemd[1]: Mounted Huge Pages File System.
jul 11 19:42:25 loopz systemd[1]: Mounted POSIX Message Queue File System.
jul 11 19:42:25 loopz systemd[1]: Mounted Kernel Debug File System.
jul 11 19:42:25 loopz systemd[1]: Mounted Kernel Trace File System.
jul 11 19:42:25 loopz kernel: loop: module loaded
jul 11 19:42:25 loopz kernel: fuse: init (API version 7.39)
jul 11 19:42:25 loopz kernel: device-mapper: uevent: version 1.0.3
jul 11 19:42:25 loopz kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
jul 11 19:42:25 loopz systemd-journald[489]: Collecting audit messages is disabled.
jul 11 19:42:25 loopz systemd[1]: Finished Create List of Static Device Nodes.
jul 11 19:42:25 loopz kernel: EXT4-fs (nvme0n1p2): re-mounted 2fa1c21f-8991-4be8-a4e7-0ac469e17972 r/w. Quota mode: none.
jul 11 19:42:25 loopz systemd[1]: Started Journal Service.
jul 11 19:42:25 loopz systemd-journald[489]: Received client request to flush runtime journal.
jul 11 19:42:26 loopz kernel: mousedev: PS/2 mouse device common for all mice
jul 11 19:42:26 loopz kernel: Adding 36068352k swap on /dev/nvme0n1p3.  Priority:-2 extents:1 across:36068352k SS
jul 11 19:42:26 loopz kernel: piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
jul 11 19:42:26 loopz kernel: piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
jul 11 19:42:26 loopz kernel: piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
jul 11 19:42:26 loopz kernel: input: PC Speaker as /devices/platform/pcspkr/input/input11
jul 11 19:42:26 loopz kernel: Bluetooth: Core ver 2.22
jul 11 19:42:26 loopz kernel: NET: Registered PF_BLUETOOTH protocol family
jul 11 19:42:26 loopz kernel: Bluetooth: HCI device and connection manager initialized
jul 11 19:42:26 loopz kernel: Bluetooth: HCI socket layer initialized
jul 11 19:42:26 loopz kernel: Bluetooth: L2CAP socket layer initialized
jul 11 19:42:26 loopz kernel: Bluetooth: SCO socket layer initialized
jul 11 19:42:26 loopz kernel: RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
jul 11 19:42:26 loopz kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
jul 11 19:42:26 loopz kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
jul 11 19:42:26 loopz kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
jul 11 19:42:26 loopz kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
jul 11 19:42:26 loopz kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
jul 11 19:42:26 loopz kernel: cfg80211: failed to load regulatory.db
jul 11 19:42:26 loopz kernel: usbcore: registered new interface driver btusb
jul 11 19:42:26 loopz kernel: r8169 0000:0b:00.0 eth0: RTL8168g/8111g, a8:a1:59:18:ed:99, XID 4c0, IRQ 76
jul 11 19:42:26 loopz kernel: r8169 0000:0b:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
jul 11 19:42:26 loopz kernel: Bluetooth: hci0: Firmware timestamp 2024.18 buildtype 1 build 81528
jul 11 19:42:26 loopz kernel: Bluetooth: hci0: No support for _PRR ACPI method
jul 11 19:42:26 loopz kernel: r8169 0000:0b:00.0 enp11s0: renamed from eth0
jul 11 19:42:26 loopz kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
jul 11 19:42:26 loopz kernel: Bluetooth: hci0: Boot Address: 0x100800
jul 11 19:42:26 loopz kernel: Bluetooth: hci0: Firmware Version: 120-18.24
jul 11 19:42:26 loopz kernel: Bluetooth: hci0: Firmware already loaded
jul 11 19:42:26 loopz kernel: kvm_amd: TSC scaling supported
jul 11 19:42:26 loopz kernel: kvm_amd: Nested Virtualization enabled
jul 11 19:42:26 loopz kernel: kvm_amd: Nested Paging enabled
jul 11 19:42:26 loopz kernel: kvm_amd: LBR virtualization supported
jul 11 19:42:26 loopz kernel: kvm_amd: Virtual VMLOAD VMSAVE supported
jul 11 19:42:26 loopz kernel: kvm_amd: Virtual GIF supported
jul 11 19:42:26 loopz kernel: snd_hda_intel 0000:0c:00.1: Disabling MSI
jul 11 19:42:26 loopz kernel: snd_hda_intel 0000:0c:00.1: Handle vga_switcheroo audio client
jul 11 19:42:26 loopz kernel: snd_hda_intel 0000:0e:00.4: enabling device (0000 -> 0002)
jul 11 19:42:26 loopz kernel: MCE: In-kernel MCE decoding enabled.
jul 11 19:42:26 loopz kernel: snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
jul 11 19:42:26 loopz kernel: snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
jul 11 19:42:26 loopz kernel: snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
jul 11 19:42:26 loopz kernel: snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
jul 11 19:42:26 loopz kernel: snd_hda_codec_realtek hdaudioC1D0:    inputs:
jul 11 19:42:26 loopz kernel: snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
jul 11 19:42:26 loopz kernel: snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
jul 11 19:42:26 loopz kernel: snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
jul 11 19:42:26 loopz kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input12
jul 11 19:42:26 loopz kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input13
jul 11 19:42:26 loopz kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input14
jul 11 19:42:26 loopz kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input15
jul 11 19:42:26 loopz kernel: input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:0e:00.4/sound/card1/input16
jul 11 19:42:26 loopz kernel: input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:0e:00.4/sound/card1/input17
jul 11 19:42:26 loopz kernel: input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:0e:00.4/sound/card1/input18
jul 11 19:42:26 loopz kernel: input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:0e:00.4/sound/card1/input19
jul 11 19:42:26 loopz kernel: input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:0e:00.4/sound/card1/input20
jul 11 19:42:26 loopz kernel: intel_rapl_common: Found RAPL domain package
jul 11 19:42:26 loopz kernel: intel_rapl_common: Found RAPL domain core
jul 11 19:42:26 loopz kernel: usb 3-4: RTL8188EU rev D (TSMC) romver 0, 1T1R, TX queues 2, WiFi=1, BT=0, GPS=0, HI PA=0
jul 11 19:42:27 loopz kernel: usb 3-4: RTL8188EU MAC: d0:37:45:9d:ef:23
jul 11 19:42:27 loopz kernel: usb 3-4: rtl8xxxu: Loading firmware rtlwifi/rtl8188eufw.bin
jul 11 19:42:27 loopz kernel: usb 3-4: Firmware revision 28.0 (signature 0x88e1)
jul 11 19:42:27 loopz kernel: Generic FE-GE Realtek PHY r8169-0-b00:00: attached PHY driver (mii_bus:phy_addr=r8169-0-b00:00, irq=MAC)
jul 11 19:42:27 loopz kernel: r8169 0000:0b:00.0 enp11s0: Link is Down
jul 11 19:42:27 loopz kernel: usbcore: registered new interface driver rtl8xxxu
jul 11 19:42:29 loopz kernel: wlan0: authenticate with 24:e4:ce:2e:db:4b
jul 11 19:42:29 loopz kernel: wlan0: send auth to 24:e4:ce:2e:db:4b (try 1/3)
jul 11 19:42:29 loopz kernel: wlan0: authenticated
jul 11 19:42:29 loopz kernel: wlan0: associate with 24:e4:ce:2e:db:4b (try 1/3)
jul 11 19:42:29 loopz kernel: wlan0: RX AssocResp from 24:e4:ce:2e:db:4b (capab=0x1411 status=0 aid=17)
jul 11 19:42:29 loopz kernel: usb 3-4: rtl8xxxu_bss_info_changed: HT supported
jul 11 19:42:29 loopz kernel: wlan0: associated
jul 11 19:42:29 loopz kernel: wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 24:e4:ce:2e:db:4b
jul 11 19:42:33 loopz kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
jul 11 20:04:20 loopz kernel: NET: Registered PF_ALG protocol family
jul 11 20:04:26 loopz kernel: block nvme0n1: the capability attribute has been deprecated.
jul 11 21:31:05 loopz kernel: xwaylandv:zfq0[1326]: segfault at c0 ip 00007a4cd9efe965 sp 00007a4cd87fe488 error 4 in libnvidia-glcore.so.555.58.02[7a4cd9600000+c00000] likely on CPU 8 (core 0, socket 0)
jul 11 21:31:05 loopz kernel: Code: 30 48 8b 49 10 48 8b 49 58 8b 49 60 41 89 48 38 83 f8 08 74 52 48 8d 04 c0 48 8b 84 c6 70 01 00 00 48 85 c0 74 41 48 8b 48 10 <48> 8b 89 c0 00 00 00 41 c6 40 40 01 48 8b 70 10 49 89 70 48 8b 89
jul 11 21:36:51 loopz kernel: usb 3-4: USB disconnect, device number 4
jul 11 21:36:51 loopz kernel: wlan0: deauthenticating from 24:e4:ce:2e:db:4b by local choice (Reason: 3=DEAUTH_LEAVING)
jul 11 21:36:51 loopz kernel: usb 3-4: disconnecting
jul 11 21:37:41 loopz kernel: usb 3-4: new high-speed USB device number 5 using xhci_hcd
jul 11 21:37:41 loopz kernel: usb 3-4: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
jul 11 21:37:42 loopz kernel: usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
jul 11 21:37:42 loopz kernel: usb 3-4: Product: 802.11n NIC
jul 11 21:37:42 loopz kernel: usb 3-4: Manufacturer: Realtek
jul 11 21:37:42 loopz kernel: usb 3-4: SerialNumber: 00E04C0001
jul 11 21:37:42 loopz kernel: usb 3-4: RTL8188EU rev D (TSMC) romver 0, 1T1R, TX queues 2, WiFi=1, BT=0, GPS=0, HI PA=0
jul 11 21:37:42 loopz kernel: usb 3-4: RTL8188EU MAC: d0:37:45:9d:ef:23
jul 11 21:37:42 loopz kernel: usb 3-4: rtl8xxxu: Loading firmware rtlwifi/rtl8188eufw.bin
jul 11 21:37:42 loopz kernel: usb 3-4: Firmware revision 28.0 (signature 0x88e1)
jul 11 21:37:44 loopz kernel: wlan0: authenticate with 24:e4:ce:2e:db:4b
jul 11 21:37:44 loopz kernel: wlan0: send auth to 24:e4:ce:2e:db:4b (try 1/3)
jul 11 21:37:44 loopz kernel: wlan0: authenticated
jul 11 21:37:44 loopz kernel: wlan0: associate with 24:e4:ce:2e:db:4b (try 1/3)
jul 11 21:37:44 loopz kernel: wlan0: RX AssocResp from 24:e4:ce:2e:db:4b (capab=0x1411 status=0 aid=33)
jul 11 21:37:44 loopz kernel: usb 3-4: rtl8xxxu_bss_info_changed: HT supported
jul 11 21:37:44 loopz kernel: wlan0: associated
jul 11 21:37:44 loopz kernel: wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 24:e4:ce:2e:db:4b
I’ve noted you’re using the LTS kernel. While I review those logs, may I suggest you also just try booting into the standard kernel, in case it’s not an issue there?
I changed it. I’m using the standard kernel. Nothing has changed unfortunately.
Unless I’ve missed it, I can’t see anything in the bootlog about an iwlwifi WLAN adapter.
Might you have another system, a Windows one perhaps, that you could test this card in to confirm the hardware is ok?
I do not have it, sadly. When I was installing the system the bluetooth was working like a charm (the device supports both internet and bluetooth), and now it’s gone along the internet connection.
Did you try loading the module
sudo modprobe iwlwifi
If you have a place you could install Windows as a trial (spare drive), that might be an option, purely for temporary testing purposes. This should hopefully help confirm whether an issue (possible hardware failure) can be replicated.
The interwebs has some pointers on how that might be achieved. eg:
It is possible to write a legitimate Windows ISO to a bootable USB from Linux, without needing to use Microsoft’s media creation software.
Yep. Still, nothing.
Yeah, I’ll try it, I come back in an hour to say if it worked on Windows or not.
You can also try
sudo modprobe btusb
Thank you but it does not work. I am trying everything I could.
Also, it worked in Windows, I installed and then nothing happened. Then I downloaded the Exe drive file at the official website (https://fenvi.com/drive.html), and it worked. My model is FV-AXE3000RGB.
I do not know the content of this exe, it`s just an Intel instalation, maybe it is the intel drivers. Is there a way I can use it in linux for my wireless to work?
I would appreciate so much if I solve this case.
I also changed my system to Arch (just initialized everything from 0) and it`s not working either. Could it be the PCI entry that is not working?
I also find this tgz archive on intel`s website that seems to contained the drivers for linux, but I really do not know how to install.
Intel® Wi-Fi 6 AX210 de 160 MHz 5.10+ [iwlwifi-ty-59.601f3a66.0.tgz]
(https://wireless.wiki.kernel.org/_media/en/users/drivers/iwlwifi-ty-59.601f3a66.0.tgz)
