@pierrelatour
If you are dual booting on Windows make sure fast startup in Windows power management is disabled.
I am not. Wondering what the problem could be. I`m using Arch now and it has the same problem.
did a sudo cp iwlwifi-ty-a0-gf-a0-59.gcode /lib/firmware with this, still nothing.
You just download and extract the files. They will be inside the extracted folder. You can copy the firmware file to /lib/firmware
I guess you can try that. Not sure if that firmware file already exists or is different? Have you also checked nothing is blocking it.
rfkill
Edit: If so use
rfkill unblock all
5 wlan phy3 unblocked unblocked
6 bluetooth hci0 unblocked unblocked
Nothing yet.
Also, i tried inxi-i again without the dongle and that is the result
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp11s0 state: down mac: a8:a1:59:18:ed:99
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Did you try again sudo modprobe iwlwifi also did you update to the 6.9.9-arch1-1 kernel?
Edit: Do you have Windows installed with EOS? Fast start up feature in Windows under Windows Power Management needs to be disabled.
@pierrelatour
This is a Pci-e card. You said it worked on Windows. It’s not going to work if not detected on arch. I don’t know the reason why it’s not being detected. That’s what needs to be figured out.
What does this show?
lspci
Edit: Also
sudo dmesg | grep iwl
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 7
01:00.0 Non-Volatile memory controller: Hosin Global Electronics Patriot P300 NVMe SSD (DRAM-less) (rev 01)
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset USB 3.1 xHCI Controller (rev 02)
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset SATA Controller (rev 02)
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset PCIe Upstream Port (rev 02)
03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
0a:00.0 SATA controller: ASMedia Technology Inc. ASM1061/ASM1062 Serial ATA Controller (rev 02)
0b:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 11)
0c:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070 Lite Hash Rate] (rev a1)
0c:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
0d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
0e:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
0e:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
0e:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
0e:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
sudo dmesg | grep iwl = Nothing happened.
Also
[pedro@loopz ~]$ nmcli device status
DEVICE TYPE STATE CONNECTION
wlan0 wifi connected MARTINS
lo loopback connected (externally) lo
enp11s0 ethernet unavailable --
So wlan0 is the dongle, i don`t know what enp11s0 is probably the internet device.
It just isn’t seeing the hardware. So it doesn’t load the module.
lsmod
Module Size Used by
uinput 20480 1
ccm 20480 6
rtl8xxxu 303104 0
mac80211 1597440 1 rtl8xxxu
libarc4 12288 1 mac80211
cfg80211 1363968 2 mac80211,rtl8xxxu
rfcomm 102400 7
snd_seq_dummy 12288 0
snd_hrtimer 12288 1
snd_seq 131072 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
uhid 20480 1
cmac 12288 4
algif_hash 12288 1
algif_skcipher 12288 1
af_alg 32768 6 algif_hash,algif_skcipher
bnep 36864 2
vfat 24576 1
fat 106496 1 vfat
r8169 126976 0
realtek 40960 1
uas 36864 0
mdio_devres 12288 1 r8169
mousedev 24576 0
usb_storage 90112 1 uas
libphy 221184 3 r8169,mdio_devres,realtek
btusb 86016 0
intel_rapl_msr 20480 0
amd_atl 40960 1
btrtl 32768 1 btusb
intel_rapl_common 40960 1 intel_rapl_msr
btintel 65536 1 btusb
btbcm 24576 1 btusb
joydev 24576 0
btmtk 12288 1 btusb
bluetooth 1101824 42 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
ecdh_generic 16384 2 bluetooth
kvm_amd 204800 0
nvidia_drm 122880 20
nvidia_modeset 1912832 79 nvidia_drm
kvm 1363968 1 kvm_amd
snd_hda_codec_realtek 208896 1
video 77824 1 nvidia_modeset
pkcs8_key_parser 12288 0
snd_hda_codec_generic 110592 1 snd_hda_codec_realtek
rfkill 40960 8 bluetooth,cfg80211
crct10dif_pclmul 12288 1
crc16 12288 1 bluetooth
snd_hda_scodec_component 20480 1 snd_hda_codec_realtek
snd_hda_codec_hdmi 98304 1
hid_generic 12288 0
crc32_pclmul 12288 0
snd_hda_intel 65536 2
polyval_clmulni 12288 0
snd_intel_dspcfg 40960 1 snd_hda_intel
polyval_generic 12288 1 polyval_clmulni
nvidia_uvm 6823936 0
gf128mul 16384 1 polyval_generic
snd_intel_sdw_acpi 16384 1 snd_intel_dspcfg
ghash_clmulni_intel 16384 0
snd_hda_codec 212992 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
sha512_ssse3 53248 0
sha1_ssse3 32768 0
snd_hda_core 143360 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
usbhid 81920 0
aesni_intel 360448 9
snd_hwdep 20480 1 snd_hda_codec
crypto_simd 16384 1 aesni_intel
snd_pcm 200704 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
cryptd 28672 3 crypto_simd,ghash_clmulni_intel
snd_timer 53248 3 snd_seq,snd_hrtimer,snd_pcm
sp5100_tco 20480 0
rapl 20480 0
wmi_bmof 12288 0
pcspkr 12288 0
snd 155648 16 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
ccp 180224 1 kvm_amd
acpi_cpufreq 32768 0
soundcore 16384 1 snd
k10temp 16384 0
i2c_piix4 36864 0
gpio_amdpt 16384 0
gpio_generic 24576 1 gpio_amdpt
mac_hid 12288 0
nvidia 10174464 796 nvidia_uvm,nvidia_modeset
i2c_dev 28672 0
crypto_user 20480 0
loop 45056 0
dm_mod 225280 0
nfnetlink 20480 1
zram 45056 2
ip_tables 36864 0
x_tables 65536 1 ip_tables
nvme 65536 2
nvme_core 253952 3 nvme
sha256_ssse3 36864 0
xhci_pci 24576 0
xhci_pci_renesas 24576 1 xhci_pci
nvme_auth 24576 1 nvme_core
wmi 36864 2 video,wmi_bmof
btrfs 2134016 1
blake2b_generic 24576 0
libcrc32c 12288 1 btrfs
crc32c_generic 12288 0
crc32c_intel 16384 2
xor 20480 1 btrfs
raid6_pq 122880 1 btrfs
@pierrelatour
It’s just not seeing the hardware. Are you running on the latest kernel? 6.9.9-arch1-1
Edit: Don’t know what to do from here. Are you able to return it and get a different brand?
2 years ago I added Bluetooth - just a small dongle and with a shorter delivery time than Aliexpress (which has changed a lot with respect to pricing and shippingi here in Thailand since the onset of COVID).
I ordered via Shopee and discovered that honesty is not their strongest point - opening up my first dongle revealed what I expected, the chip was not an original of the stated internal chip.
With some hardware, the difference is obvious and easy to spot (assuming you can get into the packaging - my dongles were easy enough to open up without breaking them. With others (my Class-D audio amplifiers, for example) they are sometimes hidden with heatsinks… for example with the TPA3116D2 amplifier chips which cost around $1 each - with some being labelled accurately (with Chinese chips - which aren’t too bad, but certainly are not quite as effective unless you’re just driving cheap speakers) and priced accordingly 60% the price of the genuine article.
Then others are deceptive, labelled as original. I forget the detail now, but China has many ‘clone’ chips which are generally engineered for Windows computers where they’ll probably just work… but with Bluetooth often not.
Thus returned, refunded and replaced with another order… which also failed in a similar manner.
My third order worked - the whole process took about a month.
Bus 003 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
TLDR - always make sure you can get a quick return/refund and then move on to the next one.
It worked. It`s embarrassing but I just changed the PCI slot and it worked for some reason. I would like to apologize the time you guys spent with me.
I was going to ask this question if you had it installed in the correct Pci-e slot? Or if you had another available slot to try it in. How Windows arranges it’s hardware is not the same on linux. I feel just as embarrassed for not asking you so don’t feel bad. Glad it’s working now. It should show up in the hardware now with inxi -Na
You can just mark post 36 as the solution then after this.
Glad you got it working! Good call on trying another slot ![]()
Exactly. Thank you, Rick.
Device-1: **Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi**
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 08:00.0
chip-ID: 8086:2725 class-ID: 0280
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 0b:00.0 chip-ID: 10ec:8168 class-ID: 0200
