Can't load desktop, stuck on "Finished Notify about reboot on special conditions" after update
Hello, EOS community!
As always, after starting my PC I wanted to check if there are any updates to the system, so I typed “yay” and I got information that update is available for: iputils, mesa, lib32-mesa and for a tool that I use for recording. I went ahead and updated these things, but after updating them, I got a notification that I have to reboot to apply changes, so I rebooted, and unfortunately since then I can’t use my desktop because all I can see is:
[ OK ] Started Account service
[ OK ] Finished Notify about reboot on special conditions.
Below I attach the image and logs. I hope I will be able to solve this problem with your help.
Pacman log:
[2024-01-01T00:32:51+0100] [PACMAN] Running 'pacman -S -y --config /etc/pacman.conf --'
[2024-01-01T00:32:51+0100] [PACMAN] synchronizing package lists
[2024-01-01T00:33:11+0100] [PACMAN] Running 'pacman -S -y -u --config /etc/pacman.conf --'
[2024-01-01T00:33:11+0100] [PACMAN] synchronizing package lists
[2024-01-01T00:33:11+0100] [PACMAN] starting full system upgrade
[2024-01-01T00:33:43+0100] [ALPM] transaction started
[2024-01-01T00:33:43+0100] [ALPM] upgraded iputils (20231222-1 -> 20231222-2)
[2024-01-01T00:33:43+0100] [ALPM] upgraded mesa (1:23.3.1-1 -> 1:23.3.2-1)
[2024-01-01T00:33:44+0100] [ALPM] upgraded lib32-mesa (1:23.3.1-1 -> 1:23.3.2-1)
[2024-01-01T00:33:44+0100] [ALPM] transaction completed
[2024-01-01T00:33:44+0100] [ALPM] running '30-systemd-update.hook'...
[2024-01-01T00:33:44+0100] [ALPM] running 'eos-reboot-required.hook'...
[2024-01-01T00:33:44+0100] [ALPM] running 'rebuild-detector.hook'...
[2024-01-01T00:33:52+0100] [PACMAN] Running 'pacman -U --config /etc/pacman.conf -- /home/dawid/.cache/yay/gpu-screen-recorder-git/gpu-screen-recorder-git-r446.54b03ea-1-x86_64.pkg.tar.zst'
[2024-01-01T00:33:55+0100] [ALPM] transaction started
[2024-01-01T00:33:55+0100] [ALPM] upgraded gpu-screen-recorder-git (r440.852882b-1 -> r446.54b03ea-1)
[2024-01-01T00:33:55+0100] [ALPM] transaction completed
[2024-01-01T00:33:55+0100] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-01-01T00:33:55+0100] [ALPM] running '30-systemd-update.hook'...
[2024-01-01T00:33:55+0100] [ALPM] running 'rebuild-detector.hook'...
[2024-01-01T00:33:56+0100] [PACMAN] Running 'pacman -D -q --asexplicit --config /etc/pacman.conf -- gpu-screen-recorder-git'
[2024-01-01T00:37:07+0100] [PACMAN] Running 'pacman -S -y --config /etc/pacman.conf --'
[2024-01-01T00:37:07+0100] [PACMAN] synchronizing package lists
Image:
Please read this thread
I think you have to downgrade mesa.
It works after downgrading mesa. Thank you very much!
