Call for testing kernel-install-for-dracut
I have recently completed an AUR package kernel-install-for-dracut as an alternative to my kernel-install-mkinitcpio
It is nearly identical to that package except is uses dracut instead of mkinitcpio.
Why use dracut?
  • It produces a single initrd image which includes any needed ucode images
  • It is a much more modern and complete solution than mkinitcpio
  • In most cases it “just works” without requiring the changes often required by mkinitcpio
So I have tested it in 3 test cases without issue:
  • A basic ext4 setup
  • A zfs on root install
  • A btrfs on luks install using plymouth
In all cases, it “just worked”. There was no special config required for anything including zfs.
If you want to try it out and you are already running my kernel-install-mkinitcpio package. You can simply install it and then run kernel-install on one of your kernels.
I recommend having two kernels installed prior to installing kernel-install-for-dracut. That way you can test with one kernel and if anything doesn’t work you will still be able to boot off the other kernel.
Hello Dalto, tried to install and got these errors:
 -> kernel-install-for-dracut-1.2-1 already made -- skipping build
loading packages...
resolving dependencies...
:: kernel-install-for-dracut and mkinitcpio are in conflict. Remove mkinitcpio? [y/N] y
:: kernel-install-for-dracut and kernel-install-mkinitcpio are in conflict. Remove kernel-install-mkinitcpio? [y/N] y
:: removing mkinitcpio breaks dependency 'mkinitcpio' required by mkinitcpio-openswap
 -> exit status 1
You can just remove it.
yay -Rc mkinitcpio-openswap
Its working, really thanks Dalto :+1:
After package installation, I ran:
while read -r kernel; do
    kernelversion=$(basename "${kernel%/vmlinuz}")
    echo "Installing kernel ${kernelversion}"
    sudo kernel-install add ${kernelversion} ${kernel}
done < <(find /usr/lib/modules -maxdepth 2 -type f -name vmlinuz)
Bold move! You just went straight for all kernels at once. Did it work after reboot?
Yes, its working flawless, I didn’t think twice, just went and tested it, I trust you :slight_smile:
Already rebooted, just noticed that my systemd-boot boot menu options order changed
I’m currently installing systemd-boot based on your guide and I’m at this step right now where I could either use dracut or mkinitcpio. Since they’re both in the AUR and both provided by you, I figure why not go the extra step and be one of the early adopters (don’t worry I keep backups).
Since I’m out of my element in regards to systemd-boot and dracut (other than I’ve used it once or twice on Fedora), I’m curious if say the main systemd package was updated, will there be some sort of hook to regenerate the initramfs? I’m sure there’s other questions I might have once fully installed and rebooted.
Systemd-boot gets reinstalled when it is updated via hook. There should be no need to regen the initrds when systemd is updated.
The initrds get build whenever a kernel is installed/updated.
Awesome good to know thank you! Let me finish up this step by step guide and I’ll report back shortly! For quick reference my system is btrfs, no encryption, and I have 3 kernels installed.
What about CPU microcode?
Its not showing it anymore in initrd in my entry.conf
$ cat b6cebfd9c59b41a79dd137badc328377-5.19.4-arch1-1.conf
title      EndeavourOS
version    5.19.4-arch1-1
machine-id b6cebfd9c59b41a79dd137badc328377
sort-key   endeavouros-5.19.4-arch1-1
options    root=UUID=b1a08508-812b-448c-9e8b-ae7903e02f76 rw rootflags=subvol=@ loglevel=3 nowatchdog nvme_load=YES amd_pstate.shared_mem=1 systemd.machine_id=b6cebfd9c59b41a79dd137badc328377
linux      /b6cebfd9c59b41a79dd137badc328377/5.19.4-arch1-1/linux
initrd     /b6cebfd9c59b41a79dd137badc328377/5.19.4-arch1-1/initrd
But it seems that is loaded correctly:
$ sudo journalctl -k --grep=microcode
ago 28 14:59:18 eos kernel: microcode: CPU0: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU1: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU2: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU3: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU4: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU5: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU6: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU7: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU8: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU9: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU10: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: CPU11: patch_level=0x0a201016
ago 28 14:59:18 eos kernel: microcode: Microcode Update Driver: v2.2.
It gets embedded in the initrd. That is one of the advantages of dracut.
Ok so keep it mind, I’m still going through the convert to systemd-boot guide. I’m at the kernel-install step (not doing the manual way), so I first removed any conflicts with yay -Rc mkinitcpio-openswap and then I installed via yay -S kernel-install-for-dracut which installed fine and removed mkinitcpio as well. Then I used your bash script, saved it in a text file, and ran it as sudo bash ./convert.sh and the whole process on 3 kernels took about 1-2 minutes till the command was done, but I think I ran into a problem at the end it said one of the fallbacks failed and I’m assuming it’s probably because 3 kernels was larger than my EFI file size maybe? Appreciate any feedback. Here’s the command log:
[scott@EndeavourOS ~]$ sudo bash ./convert.sh
Installing kernel 5.15.63-1-lts
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd 5.15.63-1-lts
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'dmraid' will not be installed, because command 'kpartx' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module 'squash' will not be installed, because command 'mksquashfs' could not be found!
dracut: dracut module 'squash' will not be installed, because command 'unsquashfs' could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: i18n ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: resume ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: ostree ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode:                     real
dracut: Method:                   sha256
dracut: Files:                    762
dracut: Linked:                   1 files
dracut: Compared:                 0 xattrs
dracut: Compared:                 46 files
dracut: Saved:                    692 B
dracut: Duration:                 0.005449 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Using microcode found in '/boot/intel-ucode.img' ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd' ***
dracut: dracut: using auto-determined compression method 'gzip'
dracut: *** Creating initramfs image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd' done ***
dracut: Executing: /usr/bin/dracut -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd-fallback 5.15.63-1-lts
dracut: dracut module 'multipath' will not be installed, because command 'multipath' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: *** Including module: bash ***
dracut: *** Including module: modsign ***
dracut: *** Including module: dbus-daemon ***
dracut: *** Including module: dbus ***
dracut: *** Including module: network-manager ***
dracut: *** Including module: network ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: kernel-network-modules ***
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: cifs ***
dracut: *** Including module: lunmask ***
dracut: *** Including module: nbd ***
dracut: *** Including module: nfs ***
dracut: Mode:                     real
dracut: Files:                    2467
dracut: Linked:                   9 files
dracut: Compared:                 466 files
dracut: Saved:                    1.4 MiB
dracut: Duration:                 0.032194 seconds
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd-fallback' ***
dracut: *** Creating initramfs image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd-fallback' done ***
Installing kernel 5.19.4-arch1-1
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd 5.19.4-arch1-1
dracut: Mode:                     real
dracut: Files:                    771
dracut: Compared:                 42 files
dracut: Duration:                 0.005331 seconds
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd' ***
cp: error writing '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd': No space left on device
dracut: dracut: creation of /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd failed
dracut: Executing: /usr/bin/dracut -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd-fallback 5.19.4-arch1-1
dracut: Mode:                     real
dracut: Files:                    2489
dracut: Compared:                 455 files
dracut: Duration:                 0.031062 seconds
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd-fallback' ***
cp: error writing '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd-fallback': No space left on device
dracut: dracut: creation of /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd-fallback failed
Installing kernel 5.19.4-zen1-1-zen
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd 5.19.4-zen1-1-zen
dracut: Mode:                     real
dracut: Files:                    771
dracut: Compared:                 40 files
dracut: Duration:                 0.005372 seconds
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd' ***
cp: error writing '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd': No space left on device
dracut: dracut: creation of /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd failed
dracut: Executing: /usr/bin/dracut -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd-fallback 5.19.4-zen1-1-zen
dracut: Mode:                     real
dracut: Files:                    2490
dracut: Compared:                 450 files
dracut: Duration:                 0.030471 seconds
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd-fallback' ***
cp: error writing '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd-fallback': No space left on device
dracut: dracut: creation of /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd-fallback failed
Edit: here’s a pastebin link if that’s easier to read: https://pastebin.com/rXrQ2PPs
Did you clean out the esp or do you have both your old and new kernels/initrds in there?
The guide says to run the script first and then cleanup the boot. So I’ve only just run the script so far and have not gone on to the next step since I saw “failed” I decided better to stop and ask then keep going.
Edit: If you mean do I have older kernel versions e.g. 5.19.3, 5.19.2 packages installed as well, then yes I do typically keep 3 packages in the cache as a backup before pacman timer cleans them out.
That is probably the issue. Your ESP isn’t big enough to hold 6 kernels/initrams
I could get rid of the linux-zen kernel, that typically seems to be the one I use the least. Or is it a simple process to expand my ESP size? I’m guessing the former might be easier.
After you cleanup the extra kernels out of your ESP just re-run kernel-install for linux-zen(or reinstall it which will do the same thing).
So should I just remove the linux-zen kernel+headers for now, and re-run the sudo bash ./convert.sh ?
Just keep going and then reinstall linux-zen after the cleanup. That should solve all the issues.
Ok ran the cleanup command reinstalled linux-zen (not sure if I have to do that for the headers too?) but still got an error at the end. Do I need to reboot first after the cleanup and then try reinstall zen instead maybe?
[scott@EndeavourOS ~]$ sudo rm -r /boot/efi /boot/grub /boot/initramfs* /boot/vmlinuz*
[sudo] password for scott:
[scott@EndeavourOS ~]$ sudo pacman -S linux-zen
warning: linux-zen-5.19.4.zen1-1 is up to date -- reinstalling
Package (1)      Old Version    New Version    Net Change
extra/linux-zen  5.19.4.zen1-1  5.19.4.zen1-1    0.00 MiB
Total Installed Size:  185.83 MiB
Net Upgrade Size:        0.00 MiB
:: Proceed with installation? [Y/n]
(1/1) checking keys in keyring                     [-----------------------] 100%
(1/1) checking package integrity                   [-----------------------] 100%
(1/1) loading package files                        [-----------------------] 100%
(1/1) checking for file conflicts                  [-----------------------] 100%
(1/1) checking available disk space                [-----------------------] 100%
:: Running pre-transaction hooks...
(1/1) Saving Linux kernel modules...
:: Processing package changes...
(1/1) reinstalling linux-zen                       [-----------------------] 100%
(1/6) Restoring Linux kernel modules...
++ uname -r
+ KVER=5.19.4-arch1-1
+ test -e /usr/lib/modules/backup/5.19.4-arch1-1
+ rsync -AHXal --ignore-existing /usr/lib/modules/backup/5.19.4-arch1-1 /usr/lib/modules/
+ rm -rf /usr/lib/modules/backup
(2/6) Arming ConditionNeedsUpdate...
(3/6) Updating module dependencies...
(4/6) Installing kernel...
:: Running kernel-install for kernel 5.19.4-zen1-1-zen
dracut: Mode:                     real
dracut: Files:                    771
dracut: Compared:                 41 files
dracut: Duration:                 0.005398 seconds
dracut: Mode:                     real
dracut: Files:                    2490
dracut: Duration:                 0.030259 seconds
(5/6) Check if user should be informed about rebooting after certain system package upgrades.
(6/6) Checking which packages need to be rebuilt
