Can I see ls /efi
[scott@EndeavourOS ~]$ ls /efi
5f36d8c0aa64460e9be33539d6a364bd EFI loader
How about du -sh /efi/5f36d8c0aa64460e9be33539d6a364bd/*
[scott@EndeavourOS ~]$ du -sh /efi/5f36d8c0aa64460e9be33539d6a364bd/*
222M /efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts
11M /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1
12M /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen
Ahh…
ls -lh /efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts
[scott@EndeavourOS ~]$ ls -lh /efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts
total 222M
-rwxr-xr-x 1 root root 77M Aug 28 14:20 initrd
-rwxr-xr-x 1 root root 135M Aug 28 14:20 initrd-fallback
-rwxr-xr-x 1 root root 11M Aug 28 14:20 linux
Can you install elfutils and pigz and then run this:
sudo rm -r /efi/5f36d8c0aa64460e9be33539d6a364bd
Then run my conversion script again.
sudo pacman -S elfutils pigz and then ran sudo rm -r /efi/5f36d8c0aa64460e9be33539d6a364bd, but it looks like I still get the same error at the very end still:
[scott@EndeavourOS ~]$ sudo bash ./convert.sh
Installing kernel 5.15.63-1-lts
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd 5.15.63-1-lts
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'dmraid' will not be installed, because command 'kpartx' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module 'squash' will not be installed, because command 'mksquashfs' could not be found!
dracut: dracut module 'squash' will not be installed, because command 'unsquashfs' could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: i18n ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: resume ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: ostree ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode: real
dracut: Method: sha256
dracut: Files: 762
dracut: Linked: 1 files
dracut: Compared: 0 xattrs
dracut: Compared: 46 files
dracut: Saved: 692 B
dracut: Duration: 0.005555 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Using microcode found in '/boot/intel-ucode.img' ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd' ***
dracut: dracut: using auto-determined compression method 'pigz'
dracut: *** Creating initramfs image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd' done ***
dracut: Executing: /usr/bin/dracut -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd-fallback 5.15.63-1-lts
dracut: dracut module 'multipath' will not be installed, because command 'multipath' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: *** Including module: bash ***
dracut: *** Including module: modsign ***
dracut: *** Including module: dbus-daemon ***
dracut: *** Including module: dbus ***
dracut: *** Including module: network-manager ***
dracut: *** Including module: network ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: kernel-network-modules ***
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: cifs ***
dracut: *** Including module: lunmask ***
dracut: *** Including module: nbd ***
dracut: *** Including module: nfs ***
dracut: Mode: real
dracut: Files: 2467
dracut: Linked: 9 files
dracut: Compared: 466 files
dracut: Saved: 1.4 MiB
dracut: Duration: 0.032271 seconds
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd-fallback' ***
dracut: *** Creating initramfs image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.15.63-1-lts/initrd-fallback' done ***
Installing kernel 5.19.4-arch1-1
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd 5.19.4-arch1-1
dracut: Mode: real
dracut: Files: 771
dracut: Compared: 42 files
dracut: Duration: 0.005516 seconds
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd' ***
cp: error writing '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd': No space left on device
dracut: dracut: creation of /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd failed
dracut: Executing: /usr/bin/dracut -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd-fallback 5.19.4-arch1-1
dracut: Mode: real
dracut: Files: 2489
dracut: Compared: 455 files
dracut: Duration: 0.031210 seconds
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd-fallback' ***
cp: error writing '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd-fallback': No space left on device
dracut: dracut: creation of /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-arch1-1/initrd-fallback failed
Installing kernel 5.19.4-zen1-1-zen
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd 5.19.4-zen1-1-zen
dracut: Mode: real
dracut: Files: 771
dracut: Compared: 40 files
dracut: Duration: 0.005401 seconds
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd' ***
cp: error writing '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd': No space left on device
dracut: dracut: creation of /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd failed
dracut: Executing: /usr/bin/dracut -f /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd-fallback 5.19.4-zen1-1-zen
dracut: Mode: real
dracut: Files: 2490
dracut: Compared: 450 files
dracut: Duration: 0.029933 seconds
dracut: *** Creating image file '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd-fallback' ***
cp: error writing '/efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd-fallback': No space left on device
dracut: dracut: creation of /efi/5f36d8c0aa64460e9be33539d6a364bd/5.19.4-zen1-1-zen/initrd-fallback failed
Re-running the other commands mentioned just in case anything change and/or if it helps:
total 222M
-rwxr-xr-x 1 root root 77M Aug 28 15:06 initrd
-rwxr-xr-x 1 root root 135M Aug 28 15:07 initrd-fallback
-rwxr-xr-x 1 root root 11M Aug 28 15:07 linux
Why are your initrds so huge?
None of the files I have generated on any system have been large like that.
I have absolutely no idea, outside of installing the linux-lts kernel from pacman, I don’t do anything else with it and I do not customize it in anyway, I’m more or less a ‘stick to the defaults’ as much as I can type of user.
Dunno if it helps, but I did a fresh install of EndeavourOS Artemis Neo about a week ago (from the EndeavourOS_Artemis_neo_22_7.iso), so my system shouldn’t be cluttered at all.
It seems mine are bigger too. Although, nowhere near the size of yours.
Dracut is definitely including more in the image. I will have to see what it would take to safely slim them down if that is possible.
I tried removing the kernel modules. This reduced the size a good bit. There was a downside though. The initrd could no longer load the root filesystem so I am not sure it is worth it…
you probably have to edit the dracut configuration.
Good idea. Previous to that suggestion I had been baking cookies which wasn’t having the desired impact on the initrd size.
How do I which kernel modules to ignore? As you say initrd couldn’t load the rootfs if you ignore too much
I’m trying to track down any similar issues and I came across this one from a year ago (tl:dr some are blaming the increased file size on nvidia, others blame it on debugging symbols):
I’m still searching around and seeing some reports (over years) of some users having a similar issue of a larger than life kernel size.
Also, not sure if it’s safe for me to attempt any reboots? Or just hold off on that till this is tracked down a little better perhaps.
Given the sizes involved, you can only have a single kernel installed.
So if you want to reboot, you need to pick one and then rerun the script.
I have been testing. The only thing I have found which can be safely removed and actually takes up any space is i18n support. However, it is only 2MB(4MB total). You can remove things like plymouth but the savings is not material.
I also tried changing the compression but there wasn’t much difference there either.
Ah that’s the bummer, that’s a big deal breaker for me, I like having at least 2 kernels to be able to either boot or test from. I doubt it’s possible to undo all the changes I’ve already done? I do have a archinstall iso handy for if I go the nuclear option since I have been wanting to test that out.
