I have a rather interesting bug with my legion 5 laptop. It appears that it also happens on other distros like Ubuntu, Fedora, Pop_os, Nobara and even EndeavourOS.
I also found a thread that has the same issue as mine:
HOWEVER
The problem that I have is if the brightness level is at 5-10%, it is considered as 100% for whatever reason.
The brightness driver that controls the…backlight of the laptop is nvidia_0.
I don’t have this problem on hybrid graphics however.
I have tried many grub options, including acpi_osi=Linux, acpi_backlight=vendor/none/native/video, video.use_native_backlight=1 and even turning off amdgpu.backlight.
Is there a way to fix this?
I am currently using Nobara. I don’t think I can bother with another distro reinstall at the moment
Users of NVIDIA’s proprietary drivers can change display brightness via the nvidia-settings utility under “X Server Color Correction.” However, note that this has absolutely nothing to do with backlight (intensity), it merely adjusts the color output. (Reducing brightness this way is a power-inefficient last resort when all other options fail; increasing brightness spoils your color output completely, in a way similar to overexposed photos.)
I’m guessing your aim is not to increase the screen’s brightness, but rather to dim it at times…
Again, when the slider is at 5-10, the brightness is considered to be at 100%. This does not occur on hybrid graphics as that is handled by the amdgpu I think
Well, my keyboard does not have such brightness control keys, lol.
So I made a script that can change brightness. I don’t have to use it often, as it was needed mostly because initially the brightness was much too high for my sore eyes.
No, it is an old (> 10 years) desktop machine that I built using standard components. And later I bought the Nvidia 1030 card that still works with the latest Nvidia driver. Just hoping the Nvidia driver keeps supporting it for a few more years, since the machine itself is working very well.
DP-4 yes an no 120 its actually 60.06hz. set by default.
I run a dual monitor setup so HDMI and DP-4 are the video ports in use. Screen brightness on Laptop is controlled by Laptop Keyboard fn+f5/f6 key combination the HDMI is controlled by the TV that is connected to it.
As of April 23rd Nvidia driver Version 530.41.03
NVML Version: 12.530.41.03
Again no its not. I say this because if it was then more people would have the same issue. This is not the case. I have nvidia and no issue with screen brightness at all. If the problem is an nvidia issue then I to would have the same issue. I don’t which tells me that the driver is fine however there may be a conflict between the driver and some other hardware/software in your setup.
