New install with btrfs auto snap-shots and timeshift. Doesn’t seem correct. I installed grub-btrfs, timeshift, btrfs-autosnaps. When in timeshift i cannot browse to the files. Two directories were created that have @ with weird naming scheme? Not sure that it is correct.
[ricklinux@eos-kde ~]$ sudo btrfs subvolume list /
[sudo] password for ricklinux:
ID 256 gen 249 top level 5 path @
ID 257 gen 254 top level 5 path @home
ID 258 gen 196 top level 5 path @cache
ID 259 gen 252 top level 5 path @log
ID 260 gen 196 top level 5 path @swap
ID 263 gen 27 top level 256 path var/lib/portables
ID 264 gen 28 top level 256 path var/lib/machines
ID 290 gen 196 top level 5 path @-0gyqxf
ID 292 gen 196 top level 5 path @-g7un5v
ID 295 gen 230 top level 5 path timeshift-btrfs/snapshots/2021-08-11_21-58-35/@
ID 296 gen 231 top level 5 path timeshift-btrfs/snapshots/2021-08-11_21-58-35/@home
I mean the browse button in timeshift doesn’t work in plasma.
It is because all that button does is open your default file manager. However, timeshift is running as root because, apparently, running the application as root is a better choice than actually designing it in a way that properly escalates permissions. Dolphin is restricted from running as root so when timeshift tries to open dolphin it fails.
Did you boot into a snapshot? I have never used btrfs-grub but I think it must somehow create read/write copies of your snapshots in order for you to boot into them. Perhaps that is what those are?
I don’t know how to do that. Did you look at the fstab? Is it correct?
Edit: They aren’t listed there. So i’m confused.
Edit2: Obviously I’m not doing this right?
[ricklinux@eos-kde ~]$ sudo btrfs subvolume delete @-g7un5v
ERROR: Could not statfs: No such file or directory
