page 404 i have linux on this laptop from 2016 …and worked fine, on all distro
[tiger@tiger-pc ~]$ lsmod
Module Size Used by
8021q 40960 0
garp 16384 1 8021q
mrp 20480 1 8021q
stp 16384 1 garp
llc 16384 2 stp,garp
nls_iso8859_1 16384 1
nls_cp437 20480 1
vfat 24576 1
fat 86016 1 vfat
amdgpu 5132288 0
gpu_sched 36864 1 amdgpu
uvcvideo 114688 0
btusb 65536 0
videobuf2_vmalloc 20480 1 uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 28672 1 uvcvideo
videobuf2_common 57344 2 videobuf2_v4l2,uvcvideo
btrtl 24576 1 btusb
videodev 249856 3 videobuf2_v4l2,uvcvideo,videobuf2_common
btbcm 16384 1 btusb
btintel 28672 1 btusb
bluetooth 671744 5 btrtl,btintel,btbcm,btusb
mc 61440 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
ecdh_generic 16384 1 bluetooth
ecc 32768 1 ecdh_generic
snd_hda_codec_hdmi 73728 1
x86_pkg_temp_thermal 20480 0
intel_powerclamp 20480 0
joydev 28672 0
mousedev 24576 0
kvm 790528 0
irqbypass 16384 1 kvm
radeon 1646592 1
crct10dif_pclmul 16384 1
crc32_pclmul 16384 0
ghash_clmulni_intel 16384 0
i915 2375680 10
snd_hda_codec_realtek 126976 1
hp_wmi 16384 0
snd_hda_codec_generic 94208 1 snd_hda_codec_realtek
wmi_bmof 16384 0
ledtrig_audio 16384 2 snd_hda_codec_generic,snd_hda_codec_realtek
aesni_intel 372736 0
cfg80211 851968 0
sparse_keymap 16384 1 hp_wmi
crypto_simd 16384 1 aesni_intel
snd_hda_intel 49152 4
cryptd 24576 2 crypto_simd,ghash_clmulni_intel
snd_intel_nhlt 20480 1 snd_hda_intel
snd_hda_codec 155648 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
intel_spi_platform 16384 0
rfkill 28672 3 hp_wmi,bluetooth,cfg80211
intel_spi 24576 1 intel_spi_platform
spi_nor 61440 1 intel_spi
r8169 94208 0
snd_hda_core 102400 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
i2c_algo_bit 16384 3 amdgpu,radeon,i915
glue_helper 16384 1 aesni_intel
ttm 122880 2 amdgpu,radeon
realtek 20480 0
drm_kms_helper 212992 3 amdgpu,radeon,i915
mtd 77824 2 spi_nor,intel_spi
intel_cstate 16384 0
psmouse 180224 0
intel_uncore 147456 0
iTCO_wdt 16384 0
iTCO_vendor_support 16384 1 iTCO_wdt
mei_hdcp 24576 0
libphy 102400 3 r8169,realtek
drm 516096 11 gpu_sched,drm_kms_helper,amdgpu,radeon,i915,ttm
snd_hwdep 16384 1 snd_hda_codec
intel_rapl_msr 20480 0
pcspkr 16384 0
intel_rapl_perf 16384 0
input_leds 16384 0
snd_pcm 135168 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_timer 40960 1 snd_pcm
wmi 36864 2 hp_wmi,wmi_bmof
intel_gtt 24576 1 i915
snd 106496 16 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
agpgart 53248 3 intel_gtt,ttm,drm
soundcore 16384 1 snd
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
processor_thermal_device 20480 0
evdev 24576 16
intel_rapl_common 28672 2 intel_rapl_msr,processor_thermal_device
battery 24576 0
ac 16384 0
mei_me 45056 1
i2c_hid 32768 0
mac_hid 16384 0
int3400_thermal 20480 0
int340x_thermal_zone 16384 1 processor_thermal_device
mei 118784 3 mei_hdcp,mei_me
lpc_ich 28672 0
i2c_i801 36864 0
hp_wireless 16384 0
intel_soc_dts_iosf 20480 1 processor_thermal_device
acpi_thermal_rel 16384 1 int3400_thermal
intel_pch_thermal 16384 0
coretemp 20480 0
msr 16384 0
pkcs8_key_parser 16384 0
crypto_user 16384 0
ip_tables 36864 0
x_tables 49152 1 ip_tables
ext4 782336 1
crc32c_generic 16384 0
crc16 16384 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 135168 1 ext4
ums_realtek 24576 0
uas 28672 0
usb_storage 77824 2 uas,ums_realtek
hid_logitech_hidpp 45056 0
hid_logitech_dj 28672 0
hid_generic 16384 0
usbhid 65536 1 hid_logitech_dj
sr_mod 28672 0
hid 143360 6 i2c_hid,usbhid,hid_generic,hid_logitech_dj,hid_logitech_hidpp
cdrom 73728 1 sr_mod
sd_mod 57344 4
serio_raw 20480 0
ahci 40960 3
atkbd 36864 0
libahci 40960 1 ahci
libps2 20480 2 atkbd,psmouse
libata 274432 2 libahci,ahci
crc32c_intel 24576 2
xhci_pci 20480 0
scsi_mod 249856 5 sd_mod,usb_storage,uas,libata,sr_mod
ehci_pci 20480 0
xhci_hcd 282624 1 xhci_pci
ehci_hcd 98304 1 ehci_pci
i8042 32768 0
serio 28672 6 serio_raw,atkbd,psmouse,i8042
Don’t know why you are getting the 4040 error as the page is working. I’m just pointing out that that particular Broadcom chipset is saying it’s not supported. But that doesn’t mean it won’t work or that you can’t get it working. It may be a kernel issue. I would see if there is an updated firmware!
ok, i will put last lts again
Do you have other kernels installed?
You can try linux-lts or linux-zen
now , yes.
WARNING: Possibly missing firmware for module: wd719x
==> WARNING: Possibly missing firmware for module: aic94xx …to install or to skip these?
tiger@tiger-pc ~]$ uname -r
5.4.7-arch1-1
and Packages (1) linux-lts-4.19.92-1
sudo pacman -S linux-lts linux-lts-headers
sudo pacman -S linux-zen linux-zen-headers
It is not enough to have more kernels, my Zen works very well for me and it is a 10-year-old pc with 4 gigs of ram
]$ uname -rs
Linux 5.4.7-zen1-1-zen
i dont want more, ever i use lts, and never deleted the main kernel from iso installer.
btw, how is zen? ck?
linux-zen it goes very well, it is a core made to use daily
ok, restart and come back
bash: /etc/modprobe.d/blacklist.conf: No such file or directory
ah ok
Maybe you could create this file and blacklist these and try.
blacklist b43
blacklist bcma
blacklist ssb
Do you have headers installed for the lts kernel?
yes, tried to load modules and wifi stopped again and dont show on panel tray
To show information about a module:
$ modinfo broadcom
To list the options that are set for a loaded module:
$ systool -v -m broadcom
no problem, installed zen kernel, updated the grub and loaded now. its safe to delete the others kernels?
vermagic: 5.4.7-zen1-1-zen SMP preempt mod_unload
sig_id: PKCS#7
It is not necessary to remove them …
