Good evening I have this printer in wifi mode but everytime I load up the drivers for this printer and everything seems ok this message shows up: error del server cups as you can see I also downloaded the printer from the localhost 631 even if in libreoffice you see the printer showing it will not print anything at all please any help.
I did but everytime I tried to find that cups was installed it always tells me it doesn’t exist it there I way to check if put in the correct command line for cups? thank you
It the same ip that comes out from my printer it has always worked even in the past when I tried with other distros from arch but the problems seems to be with cups correct ?
it is correct the ip address is 192.168.001.100 subnet mask 255.255.255.000 and gateway is 192.168.001.001 I cant find no DHCP
i just included a image of printer it always gives me the problem with cups thank you
That’s a nice printer. Not sure what the cups issue is. Usually brother printers are one of the easiest to get working on Linux. I have one myself but it is connected to usb so it is easier.
I was watching the video when I copied the second command of line sudo systemctl enable org.cups.cupsd.service the message show up in the system saying cups not exist please see image
