Booting reached target Graphical Interface then continue blinking
Wonder what happens if you run pacman -S xf86-video-nouveau
You could also install the nvidia drivers manually.
pacman -S nvidia nvidia-utils lib32-nvidia-libgl nvidia-settings
No difference from installing xf86-video-nouveau. Although all the packages (nvidia nvidia-utils lib32-nvidia-libgl nvidia-settings) are installed.
They may be installed but i wanted to reinstall them because it doesn’t show them as loading.
If you run this it shows.
inxi -Ga
inxi -Ga resulted in:
12Graphics:
12Device-1 Intel CoffeeLake-H GT2 [UHD Graphics 630] 12vendor Acer Incorporated ALI 12driver i915
12v kernel 12arch Gen-9.5 12process Intel 14nm 12built 2016-20 12ports 12active eDP-1 12empty none
12bus-ID 00:02.0 12chip-ID 8086:3e9b 12class-ID 0300
12Device-2 NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] 12vendor Acer Incorporated ALI
12driver nouveau 12v kernel 12non-free 535.xx+ 12status current (as of 2023-08) 12arch Turing 12code TUxxx
12process TSMC 12nm FF 12built 2018-22 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12ports 12active none
12empty HDMI-A-1 12bus-ID 01:00.0 12chip-ID 10de:1f91 12class-ID 0300 12temp 31.0 C
12Device-3 Quanta HD Webcam 12driver uvcvideo 12type USB 12rev 2.0 12speed 480 Mb/s 12lanes 1 12mode 2.0
12bus-ID 1-5:4 12chip-ID 0408:a060 12class-ID 0e02 12serial <filter>
12Display 12server X.org 12v 1.21.1.8 12with Xwayland 12v 23.2.1 12compositor xfwm 12driver 12X
12loaded modesetting 12unloaded nvidia 12dri iris 12gpu i915 12display-ID :0.0
12Monitor-1 eDP-1 12model AU Optronics 0x21ed 12built 2016 12res 1920x1080 12dpi 142 12gamma
1.2
12size 344x193mm (13.54x7.6") 12diag 394mm (15.5") 12ratio 16:9 12modes 1920x1080
12API OpenGL 12Message GL data unavailable for root.
EDIT: Add code tag
Is there a way to load them manually?
Can you edit the posts to include code tags around the output or i could do it for you if you like.
Not that i know of.
edited
It shows it’s that nouveau driver is loaded not the nvidia drivers. You also have to have a way to switch to nvidia since this is a hybrid laptop such as optimus-manager or other. Otherwise it only renders on the intel driver.
Did you ever use nvidia? I’m not sure if your hardware has a setting in the bios for hybrid, dedicated or integrated either?
Edit: Did you try installing the nvidia drivers manually as i suggested?
I do use optimus manager, by default, it loads intel’s on booting.
I used to use Nvidia or hybrid, but I don’t think this’s the problem.
Yes, I treid.
Take a look at the following videos, https://drive.google.com/drive/folders/18eFWrAOTTDsHrJfyx9QrXcCGR8dFANte?usp=sharing
The BeforeD is when the laptop was first booted, and the AfterD was after removing docker from chroot, this may provide some helpful notes. I don’t think it’s Nvidia problem
I see but it doesn’t really help me. I don’t use docker and i don’t know what you have done exactly that caused this other than you said you removed docker when from arch-chroot. :man_shrugging:
Sorry, not from chroot, I removed it from the main OS using chroot.
Not sure if I can access more valuable information. If I boot into the main OS, and the dashed (-) [AfterD] screen appeared, if I clicked the power off button, the first thing it will stop is Light display manager. I think the issue could be from what is suppose to run after Light display manager since they are being turned off in reverse order.
Is lightdm enabled? I’m not sure why you can’t get into a tty from booting on the OS. Have you tried all fkeys you could?
systemctl status lightdm
You could try systemctl restart lightdm
Can’t do either from chroot, they are being ignored since I am running in chroot. But running systemctl is-enabled lightdm outputs enabled.
Yes, I can open the console for only a second, then the frame refresh itself and return me to the blinking black screen
What setting are you running in the bios? Maybe try change it?
Though, if I disable lightdm, it boots me straight to tty,
I was running with the same settings over several months, nothing that I changed, safe boot is off
No i mean can you try changing to integrated instead or hybrid or something ?
GPU settings? I change them with optimus manager, not the bios. I can access tty after disabling lightdm
If you can access tty right now can you run an update?
