Hi, since I installed EndeavourOS I have never been able to fully use my bluetooth devices (keyboard, galaxy buds+) I usually manage to pair and connect the keyboard, but every other day the connection is lost and I have to use a usb cable and restart the bluetooth service manually. When trying to connect the buds+ it is even worse, since the whole bluetooth service hangs up and I need to reboot the computer, restart the bluetooth service and pair all devices again. I am using GNOME as my DE, and the bluetooth settings menu usually shows devices that are not even available anymore as if they were connected/discoverable (Say, a tv).
Am I missing something? Why is bluetooth so flawed on this OS? I am running Ubuntu on my work machine an I have had 0 issues working with bluetooth there. Is there any guide on how to properly diagnose and fix my issues?
sudo bluetoothctl
Agent registered
[CHG] Controller C0:E4:34:01:51:6C Pairable: yes
[bluetooth]# list
Controller C0:E4:34:01:51:6C alberto-linux [default]
[bluetooth]# power on
Failed to set power on: org.bluez.Error.Busy
âžś ~ lsusb
Bus 006 Device 002: ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 005: ID 1b1c:0a46 Corsair CORSAIR VIRTUOSO SE Wireless Gaming Headset
Bus 005 Device 008: ID 1532:007e Razer USA, Ltd RC30-030502 Mouse Dock
Bus 005 Device 006: ID 1532:007b Razer USA, Ltd RC30-0305 Gaming Mouse Dongle [Viper Ultimate (Wireless)]
Bus 005 Device 003: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 005 Device 009: ID 043e:9a39 LG Electronics USA, Inc. USB Controls
Bus 005 Device 007: ID 08bb:2902 Texas Instruments PCM2902 Audio Codec
Bus 005 Device 004: ID 046d:0892 Logitech, Inc. C920 HD Pro Webcam
Bus 005 Device 002: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 2109:0815 VIA Labs, Inc. USB3.0 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0b05:185c ASUSTek Computer, Inc. Bluetooth Radio
Bus 001 Device 003: ID 0b05:1872 ASUSTek Computer, Inc. AURA LED Controller
Bus 001 Device 004: ID 1ea7:0907 SHARKOON Technologies GmbH Keyboard
Bus 001 Device 002: ID 2109:2815 VIA Labs, Inc. USB2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
âžś ~ sudo systemctl status bluetooth.service
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2021-12-18 14:07:22 CET; 2min 18s ago
Docs: man:bluetoothd(8)
Main PID: 28112 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 38347)
Memory: 916.0K
CPU: 12ms
CGroup: /system.slice/bluetooth.service
└─28112 /usr/lib/bluetooth/bluetoothd
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Bluetooth management interface 1.21 initialized
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Failed to set mode: Blocked through rfkill (0x12)
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Endpoint registered: sender=:1.143 path=/MediaEndpoint/A2DPSink/sbc
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Endpoint registered: sender=:1.143 path=/MediaEndpoint/A2DPSource/sbc
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Endpoint registered: sender=:1.143 path=/MediaEndpoint/A2DPSink/sbc_xq_453
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Endpoint registered: sender=:1.143 path=/MediaEndpoint/A2DPSource/sbc_xq_453
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Endpoint registered: sender=:1.143 path=/MediaEndpoint/A2DPSink/sbc_xq_512
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Endpoint registered: sender=:1.143 path=/MediaEndpoint/A2DPSource/sbc_xq_512
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Endpoint registered: sender=:1.143 path=/MediaEndpoint/A2DPSink/sbc_xq_552
dic 18 14:07:22 alberto-linux bluetoothd[28112]: Endpoint registered: sender=:1.143 path=/MediaEndpoint/A2DPSource/sbc_xq_552
âžś ~
âžś ~ sudo /usr/lib/bluetooth/bluetoothd -n -d
[sudo] password for alberto:
bluetoothd[33937]: Bluetooth daemon 5.62
bluetoothd[33937]: src/main.c:parse_config() parsing /etc/bluetooth/main.conf
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “DiscoverableTimeout” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “AlwaysPairable” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “PairableTimeout” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “Privacy” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “JustWorksRepairing” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “TemporaryTimeout” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “Name” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “Class” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “DeviceID” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “ReverseServiceDiscovery” in group “General”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “Cache” in group “GATT”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “KeySize” in group “GATT”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “ExchangeMTU” in group “GATT”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “Channels” in group “GATT”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “SessionMode” in group “AVDTP”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “StreamMode” in group “AVDTP”
bluetoothd[33937]: src/main.c:parse_config() Key file does not have key “RSSISamplingPeriod” in group “AdvMon”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “PageScanType” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “PageScanInterval” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “PageScanWindow” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanType” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanInterval” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanWindow” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “LinkSupervisionTimeout” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “PageTimeout” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “MinSniffInterval” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “MaxSniffInterval” in group “BR”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “MinAdvertisementInterval” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “MaxAdvertisementInterval” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “MultiAdvertisementRotationInterval” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalAutoConnect” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowAutoConnect” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalSuspend” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowSuspend” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalDiscovery” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowDiscovery” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalAdvMonitor” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowAdvMonitor” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalConnect” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowConnect” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “MinConnectionInterval” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “MaxConnectionInterval” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ConnectionLatency” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “ConnectionSupervisionTimeout” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “Autoconnecttimeout” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “AdvMonAllowlistScanDuration” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “AdvMonNoFilterScanDuration” in group “LE”
bluetoothd[33937]: src/main.c:parse_mode_config() Key file does not have key “EnableAdvMonInterleaveScan” in group “LE”
D-Bus setup failed: Name already in use
bluetoothd[33937]: src/main.c:main() Unable to get on D-Bus
