but will this save the profile?
If I search the net or archwiki everyone seem to use a GUI to handle thisā¦
But it would be bloat if I have letās say one BT-speaker I want to connect each time I boot upā¦
they will get saved here I think: /var/lib/bluetooth/
Could be that bluetoothctl saved them too but it will not run to enable the profiles⦠what a GUI will do using the same profiles ?
So something like bluetoothctl -- command on login?
When you say āsave a profileā are you talking about what sink and or codec is needed for headphones?
The setting I had them change will make sure that the Bluetooth is on when they boot. If the speaker is on and previously paired with the system, it should connect automatically then.
If you need to specify codecs and what sink to use, you can also do this with a config file.
