I suspect something is up with GDM but I’m not sure. Yesterday evening I did a fresh install just selecting gnome for DE which I suspect is setting GDM as as the DM and got greeted with a blinking cursor.
When trying with Budgie and then installing Gnome additionally it works which from what I understand is using lightdm.
Where is best to report such issues, I presume it’s upstream somewhere?
Apologies I’m not that familiar with DMs.
Log output:
[ 8.182] (--) Log file renamed from "/var/log/Xorg.pid-667.log" to "/var/log/Xorg.0.log"
[ 8.182] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 8.183]
X.Org X Server 1.20.10
X Protocol Version 11, Revision 0
[ 8.183] Build Operating System: Linux Arch Linux
[ 8.183] Current Operating System: Linux puslar 5.9.12-arch1-1 #1 SMP PREEMPT Wed, 02 Dec 2020 16:14:56 +0000 x86_64
[ 8.183] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=eb2b6998-7119-4be5-8da5-7640bfdb5aff rw cryptdevice=UUID=05faba5d-5744-4f8f-881a-9fe9e2ffe0ce:luks-05faba5d-5744-4f8f-881a-9fe9e2ffe0ce root=/dev/mapper/luks-05faba5d-5744-4f8f-881a-9fe9e2ffe0ce loglevel=3 nowatchdog acpi=force
[ 8.183] Build Date: 01 December 2020 07:51:57PM
[ 8.183]
[ 8.183] Current version of pixman: 0.40.0
[ 8.183] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 8.183] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 8.183] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec 8 23:11:51 2020
[ 8.184] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 8.184] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 8.185] (==) No Layout section. Using the first Screen section.
[ 8.185] (==) No screen section available. Using defaults.
[ 8.185] (**) |-->Screen "Default Screen Section" (0)
[ 8.185] (**) | |-->Monitor "<default monitor>"
[ 8.185] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 8.185] (==) Automatically adding devices
[ 8.185] (==) Automatically enabling devices
[ 8.185] (==) Automatically adding GPU devices
[ 8.185] (==) Automatically binding GPU devices
[ 8.185] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 8.186] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 8.186] Entry deleted from font path.
[ 8.187] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 8.187] Entry deleted from font path.
[ 8.187] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 8.187] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 8.187] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 8.187] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 8.187] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 8.187] (==) FontPath set to:
[ 8.187] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 8.187] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 8.187] (II) Module ABI versions:
[ 8.187] X.Org ANSI C Emulation: 0.4
[ 8.187] X.Org Video Driver: 24.1
[ 8.187] X.Org XInput driver : 24.1
[ 8.187] X.Org Server Extension : 10.0
[ 8.188] (++) using VT number 1
[ 8.190] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 8.192] (--) PCI:*(0@0:2:0) 8086:191b:1028:06e4 rev 6, Mem @ 0xdb000000/16777216, 0x70000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 8.192] (--) PCI: (1@0:0:0) 10de:139b:1028:06e4 rev 162, Mem @ 0xdc000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 8.192] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 8.192] (II) LoadModule: "glx"
[ 8.193] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 8.196] (II) Module glx: vendor="X.Org Foundation"
[ 8.196] compiled for 1.20.10, module version = 1.0.0
[ 8.196] ABI class: X.Org Server Extension, version 10.0
[ 8.196] (==) Matched intel as autoconfigured driver 0
[ 8.196] (==) Matched modesetting as autoconfigured driver 1
[ 8.196] (==) Matched fbdev as autoconfigured driver 2
[ 8.196] (==) Matched vesa as autoconfigured driver 3
[ 8.196] (==) Assigned the driver to the xf86ConfigLayout
[ 8.196] (II) LoadModule: "intel"
[ 8.196] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 8.199] (II) Module intel: vendor="X.Org Foundation"
[ 8.199] compiled for 1.20.9, module version = 2.99.917
[ 8.199] Module class: X.Org Video Driver
[ 8.199] ABI class: X.Org Video Driver, version 24.1
[ 8.199] (II) LoadModule: "modesetting"
[ 8.199] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 8.200] (II) Module modesetting: vendor="X.Org Foundation"
[ 8.200] compiled for 1.20.10, module version = 1.20.10
[ 8.200] Module class: X.Org Video Driver
[ 8.200] ABI class: X.Org Video Driver, version 24.1
[ 8.200] (II) LoadModule: "fbdev"
[ 8.200] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 8.200] (II) Module fbdev: vendor="X.Org Foundation"
[ 8.200] compiled for 1.20.8, module version = 0.5.0
[ 8.200] (II) LoadModule: "vesa"
[ 8.200] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 8.201] (II) Module vesa: vendor="X.Org Foundation"
[ 8.201] compiled for 1.20.9, module version = 2.5.0
[ 8.201] Module class: X.Org Video Driver
[ 8.201] ABI class: X.Org Video Driver, version 24.1
[ 8.201] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 8.201] (II) intel: Driver for Intel(R) HD Graphics
[ 8.201] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 8.201] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 8.201] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 8.201] (II) FBDEV: driver for framebuffer: fbdev
[ 8.201] (II) VESA: driver for VESA chipsets: vesa
[ 8.684] intel: waited 480 ms for i915.ko driver to load
[ 8.685] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200715
[ 8.685] (II) intel(0): SNA compiled from 2.99.917-913-g9236c582
[ 8.700] (WW) Falling back to old probe method for modesetting
[ 8.700] (WW) Falling back to old probe method for fbdev
[ 8.700] (II) Loading sub module "fbdevhw"
[ 8.700] (II) LoadModule: "fbdevhw"
[ 8.700] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 8.700] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 8.700] compiled for 1.20.10, module version = 0.0.2
[ 8.700] ABI class: X.Org Video Driver, version 24.1
[ 8.701] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 530
[ 8.701] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[ 8.701] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 8.701] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 8.701] (==) intel(0): RGB weight 888
[ 8.701] (==) intel(0): Default visual is TrueColor
[ 8.702] (II) intel(0): Output eDP1 has no monitor section
[ 8.702] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 8.702] (II) intel(0): Enabled output eDP1
[ 8.702] (II) intel(0): Output DP1 has no monitor section
[ 8.702] (II) intel(0): Enabled output DP1
[ 8.702] (II) intel(0): Output HDMI1 has no monitor section
[ 8.702] (II) intel(0): Enabled output HDMI1
[ 8.702] (II) intel(0): Output DP2 has no monitor section
[ 8.703] (II) intel(0): Enabled output DP2
[ 8.703] (II) intel(0): Output HDMI2 has no monitor section
[ 8.703] (II) intel(0): Enabled output HDMI2
[ 8.703] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 8.703] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 8.703] (II) intel(0): Enabled output VIRTUAL1
[ 8.703] (--) intel(0): Output eDP1 using initial mode 3840x2160 on pipe 0
[ 8.703] (==) intel(0): TearFree disabled
[ 8.703] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 8.703] (==) intel(0): DPI set to (96, 96)
[ 8.703] (II) Loading sub module "dri3"
[ 8.703] (II) LoadModule: "dri3"
[ 8.703] (II) Module "dri3" already built-in
[ 8.703] (II) Loading sub module "dri2"
[ 8.703] (II) LoadModule: "dri2"
[ 8.703] (II) Module "dri2" already built-in
[ 8.703] (II) Loading sub module "present"
[ 8.703] (II) LoadModule: "present"
[ 8.703] (II) Module "present" already built-in
[ 8.703] (II) UnloadModule: "modesetting"
[ 8.703] (II) Unloading modesetting
[ 8.703] (II) UnloadModule: "fbdev"
[ 8.704] (II) Unloading fbdev
[ 8.704] (II) UnloadSubModule: "fbdevhw"
[ 8.704] (II) Unloading fbdevhw
[ 8.704] (II) UnloadModule: "vesa"
[ 8.704] (II) Unloading vesa
[ 8.706] (II) intel(0): SNA initialized with Skylake (gen9) backend
[ 8.706] (==) intel(0): Backing store enabled
[ 8.706] (==) intel(0): Silken mouse disabled
[ 8.706] (II) intel(0): HW Cursor enabled
[ 8.707] (==) intel(0): DPMS enabled
[ 8.707] (==) intel(0): Display hotplug detection enabled
[ 8.708] (II) intel(0): [DRI2] Setup complete
[ 8.708] (II) intel(0): [DRI2] DRI driver: i965
[ 8.708] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 8.708] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 8.708] (II) intel(0): hardware support for Present enabled
[ 8.708] (II) Initializing extension Generic Event Extension
[ 8.708] (II) Initializing extension SHAPE
[ 8.708] (II) Initializing extension MIT-SHM
[ 8.708] (II) Initializing extension XInputExtension
[ 8.708] (II) Initializing extension XTEST
[ 8.708] (II) Initializing extension BIG-REQUESTS
[ 8.708] (II) Initializing extension SYNC
[ 8.708] (II) Initializing extension XKEYBOARD
[ 8.708] (II) Initializing extension XC-MISC
[ 8.708] (II) Initializing extension SECURITY
[ 8.708] (II) Initializing extension XFIXES
[ 8.708] (II) Initializing extension RENDER
[ 8.708] (II) Initializing extension RANDR
[ 8.708] (II) Initializing extension COMPOSITE
[ 8.708] (II) Initializing extension DAMAGE
[ 8.708] (II) Initializing extension MIT-SCREEN-SAVER
[ 8.708] (II) Initializing extension DOUBLE-BUFFER
[ 8.708] (II) Initializing extension RECORD
[ 8.708] (II) Initializing extension DPMS
[ 8.708] (II) Initializing extension Present
[ 8.708] (II) Initializing extension DRI3
[ 8.708] (II) Initializing extension X-Resource
[ 8.708] (II) Initializing extension XVideo
[ 8.708] (II) Initializing extension XVideo-MotionCompensation
[ 8.708] (II) Initializing extension GLX
[ 8.740] (II) AIGLX: Loaded and initialized i965
[ 8.740] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 8.740] (II) Initializing extension XFree86-VidModeExtension
[ 8.740] (II) Initializing extension XFree86-DGA
[ 8.740] (II) Initializing extension XFree86-DRI
[ 8.740] (II) Initializing extension DRI2
[ 8.753] (II) intel(0): switch to mode 3840x2160@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 9.869] (II) intel(0): Setting screen physical size to 1016 x 571
[ 9.916] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 9.916] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 9.916] (**) Power Button: Applying InputClass "system-keyboard"
[ 9.916] (II) LoadModule: "libinput"
[ 9.916] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 9.918] (II) Module libinput: vendor="X.Org Foundation"
[ 9.918] compiled for 1.20.8, module version = 0.30.0
[ 9.918] Module class: X.Org XInput Driver
[ 9.918] ABI class: X.Org XInput driver, version 24.1
[ 9.918] (II) Using input driver 'libinput' for 'Power Button'
[ 9.919] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 20 paused 0
[ 9.919] (**) Power Button: always reports core events
[ 9.919] (**) Option "Device" "/dev/input/event3"
[ 9.919] (**) Option "_source" "server/udev"
[ 9.925] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 9.925] (II) event3 - Power Button: device is a keyboard
[ 9.925] (II) event3 - Power Button: device removed
[ 9.926] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 9.926] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 9.926] (**) Option "xkb_model" "pc105"
[ 9.926] (**) Option "xkb_layout" "gb"
[ 9.942] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 9.942] (II) event3 - Power Button: device is a keyboard
[ 9.943] (II) config/udev: Adding input device Video Bus (/dev/input/event14)
[ 9.943] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 9.943] (**) Video Bus: Applying InputClass "system-keyboard"
[ 9.943] (II) Using input driver 'libinput' for 'Video Bus'
[ 9.943] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 23 paused 0
[ 9.943] (**) Video Bus: always reports core events
[ 9.943] (**) Option "Device" "/dev/input/event14"
[ 9.943] (**) Option "_source" "server/udev"
[ 9.944] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[ 9.944] (II) event14 - Video Bus: device is a keyboard
[ 9.945] (II) event14 - Video Bus: device removed
[ 9.945] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input22/event14"
[ 9.945] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 9.945] (**) Option "xkb_model" "pc105"
[ 9.945] (**) Option "xkb_layout" "gb"
[ 9.946] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[ 9.946] (II) event14 - Video Bus: device is a keyboard
[ 9.946] (II) config/udev: Adding input device Video Bus (/dev/input/event15)
[ 9.946] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 9.946] (**) Video Bus: Applying InputClass "system-keyboard"
[ 9.946] (II) Using input driver 'libinput' for 'Video Bus'
[ 9.947] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 24 paused 0
[ 9.947] (**) Video Bus: always reports core events
[ 9.947] (**) Option "Device" "/dev/input/event15"
[ 9.947] (**) Option "_source" "server/udev"
[ 9.948] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 9.948] (II) event15 - Video Bus: device is a keyboard
[ 9.949] (II) event15 - Video Bus: device removed
[ 9.949] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0a/LNXVIDEO:01/input/input23/event15"
[ 9.949] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 9.949] (**) Option "xkb_model" "pc105"
[ 9.949] (**) Option "xkb_layout" "gb"
[ 9.950] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 9.950] (II) event15 - Video Bus: device is a keyboard
[ 9.951] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 9.951] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 9.951] (**) Power Button: Applying InputClass "system-keyboard"
[ 9.951] (II) Using input driver 'libinput' for 'Power Button'
[ 9.951] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 25 paused 0
[ 9.951] (**) Power Button: always reports core events
[ 9.951] (**) Option "Device" "/dev/input/event1"
[ 9.952] (**) Option "_source" "server/udev"
[ 9.952] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9.952] (II) event1 - Power Button: device is a keyboard
[ 9.953] (II) event1 - Power Button: device removed
[ 9.953] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 9.953] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 9.953] (**) Option "xkb_model" "pc105"
[ 9.953] (**) Option "xkb_layout" "gb"
[ 9.954] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9.954] (II) event1 - Power Button: device is a keyboard
[ 9.954] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 9.954] (II) No input driver specified, ignoring this device.
[ 9.954] (II) This device may have been added with another device file.
[ 9.955] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 9.955] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 9.955] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 9.955] (II) Using input driver 'libinput' for 'Sleep Button'
[ 9.956] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 26 paused 0
[ 9.956] (**) Sleep Button: always reports core events
[ 9.956] (**) Option "Device" "/dev/input/event2"
[ 9.956] (**) Option "_source" "server/udev"
[ 9.957] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 9.957] (II) event2 - Sleep Button: device is a keyboard
[ 9.957] (II) event2 - Sleep Button: device removed
[ 9.957] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 9.957] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 9.957] (**) Option "xkb_model" "pc105"
[ 9.957] (**) Option "xkb_layout" "gb"
[ 9.958] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 9.958] (II) event2 - Sleep Button: device is a keyboard
[ 9.958] (II) config/udev: Adding drm device (/dev/dri/card1)
[ 9.958] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 9.959] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 27 paused 0
[ 9.959] (II) LoadModule: "modesetting"
[ 9.959] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 9.959] (II) Module modesetting: vendor="X.Org Foundation"
[ 9.959] compiled for 1.20.10, module version = 1.20.10
[ 9.959] Module class: X.Org Video Driver
[ 9.959] ABI class: X.Org Video Driver, version 24.1
[ 9.959] (II) modeset(G0): using drv /dev/dri/card1
[ 9.960] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 9.960] (==) modeset(G0): RGB weight 888
[ 9.960] (==) modeset(G0): Default visual is TrueColor
[ 9.960] (II) Loading sub module "glamoregl"
[ 9.960] (II) LoadModule: "glamoregl"
[ 9.960] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 9.964] (II) Module glamoregl: vendor="X.Org Foundation"
[ 9.964] compiled for 1.20.10, module version = 1.0.1
[ 9.964] ABI class: X.Org ANSI C Emulation, version 0.4
[ 10.185] (II) modeset(G0): glamor X acceleration enabled on NV117
[ 10.185] (II) modeset(G0): glamor initialized
[ 10.185] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 10.185] (==) modeset(G0): DPI set to (96, 96)
[ 10.185] (II) Loading sub module "fb"
[ 10.185] (II) LoadModule: "fb"
[ 10.185] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 10.186] (II) Module fb: vendor="X.Org Foundation"
[ 10.186] compiled for 1.20.10, module version = 1.0.0
[ 10.186] ABI class: X.Org ANSI C Emulation, version 0.4
[ 10.186] (EE)
[ 10.186] (EE) Backtrace:
[ 10.186] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x53) [0x564a9e790f63]
[ 10.186] (EE) 1: /usr/lib/Xorg (0x564a9e64a000+0x151da5) [0x564a9e79bda5]
[ 10.186] (EE) 2: /usr/lib/libc.so.6 (0x7faf07808000+0x3d6a0) [0x7faf078456a0]
[ 10.186] (EE) 3: /usr/lib/libc.so.6 (gsignal+0x145) [0x7faf07845615]
[ 10.186] (EE) 4: /usr/lib/libc.so.6 (abort+0x116) [0x7faf0782e862]
[ 10.186] (EE) 5: /usr/lib/libc.so.6 (0x7faf07808000+0x26747) [0x7faf0782e747]
[ 10.186] (EE) 6: /usr/lib/libc.so.6 (0x7faf07808000+0x35bf6) [0x7faf0783dbf6]
[ 10.186] (EE) 7: /usr/lib/Xorg (dixRegisterPrivateKey+0x0) [0x564a9e6df870]
[ 10.186] (EE) 8: /usr/lib/xorg/modules/libglamoregl.so (glamor_init+0xc9) [0x7faf01eedfb9]
[ 10.187] (EE) 9: /usr/lib/xorg/modules/drivers/modesetting_drv.so (0x7faf02055000+0x140fd) [0x7faf020690fd]
[ 10.187] (EE) 10: /usr/lib/Xorg (AddGPUScreen+0x10e) [0x564a9e6c340e]
[ 10.187] (EE) 11: /usr/lib/Xorg (0x564a9e64a000+0x185eb9) [0x564a9e7cfeb9]
[ 10.187] (EE) 12: /usr/lib/Xorg (0x564a9e64a000+0x1bb288) [0x564a9e805288]
[ 10.187] (EE) 13: /usr/lib/Xorg (0x564a9e64a000+0x1bb52b) [0x564a9e80552b]
[ 10.187] (EE) 14: /usr/lib/Xorg (InitInput+0xf5) [0x564a9e7b5435]
[ 10.187] (EE) 15: /usr/lib/Xorg (0x564a9e64a000+0x39798) [0x564a9e683798]
[ 10.187] (EE) 16: /usr/lib/libc.so.6 (__libc_start_main+0xf2) [0x7faf07830152]
[ 10.187] (EE) 17: /usr/lib/Xorg (_start+0x2e) [0x564a9e6845de]
[ 10.187] (EE)
[ 10.187] (EE)
Fatal server error:
[ 10.187] (EE) Caught signal 6 (Aborted). Server aborting
[ 10.187] (EE)
[ 10.187] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 10.187] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 10.187] (EE)
[ 10.187] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 10.471] (EE) Server terminated with error (1). Closing log file.
