Bauh or Pamac
It’s a non issue but if you insist :wink: it started with this:
Well, the package descriptions says so:
~🐸 pacman -Qi yay
Version         : 10.3.1-2
Description     : Yet another yogurt. Pacman wrapper and AUR helper written in go.
Pamac is linked to libalpm, I don’t think yay is.
Looking at my /var/log/pacman.log, it’s full of entries like this:
[2021-08-27T21:49:33+0200] [PACMAN] Running 'pacman -S -y -u --config /etc/pacman.conf --'
I know haven’t run those manually, that’s yay's doing.
These were not my words. I just didn’t quote the source properly. Sorry about that.
Last pacman libalmp update yay has its thing too…octopi uses a bit libalmp but uses full pacman
I just took a quick spin through the code. It is definitely making use of libalpm. Without a more in-depth reading of the code, I can’t say exactly what it is using it for. It is possible it using it for some functions and not others.
I abandoned pamac, too many broken incidents on EOS. Actually, I remember it breaking back in the day on Manjaro.
I have been using bauh for maybe over a year now, never an issue. I don’t usually use it for system updates, but it is a nice app manager to see all the app options, including flatpak and snap, and of course AUR.
You mean pamac :slight_smile:
It is almost as if the name “pamac” was intentionally confusing…
:wink:
indeedly-doodly
Yes, you’re right, it’s using this: https://github.com/Jguer/go-alpm
Oh come on @Kresimir, you can make your system your own by installing whatever you want on it. Terminal centric when applied to a system that you can customize in very radical ways doesn’t actually mean anything other than after install, you don’t have a lot of GUIs installed and need to manually install them if you need them. If you can install it on Arch you can install it on EOS. And pamac is built for Arch not for Manjaro specifically.
I encourage the use of yay, btw. I came from pamac myself and started to use yay more and more until I stopped using pamac altogether. It was a slow and confortable transition for me. I took my time. I still have it installed and use it sometimes to search for packages by description or quickly check out dependencies and install files.
Just because you can install it, does not mean you should use it.
https://wiki.archlinux.org/title/AUR_helpers#Graphical
Warning: Usage of graphical AUR helpers may lead to a defective system, for example through unattended partial upgrades.
Of course, there is no pacman police to stop you from doing it. If you insist on pushing a square peg through a round hole, it’s your system, go right ahead. :man_shrugging:t3:
I find partial upgrades useful sometimes. It helped me out in some scenarios when there were bugs upstream, or dependencies were broken or unsynced. If you know what you are doing, it can be a useful tool. I find that warning a bit silly to be honest. Since anyone can contribute to the wiki, I guess whoever added it is of the terminal-centric philosophy.
Okay… :man_shrugging:t3:
One can be "terminal centric" and yet use pamac ; )
PAMAC(8)        PAMAC(8)
NAME
       pamac - package manager utility
SYNOPSIS
       pamac <operation> [options] [targets]
DESCRIPTION
       pamac is a libalpm(3) front-end with AUR support.
OPERATIONS
       pamac --version
           Display current pamac version
       pamac --help, -h [operation]
           Display pamac help
       pamac search [options] <package(s)>
           Search for packages or files, multiple search terms can be specified
       pamac list [options] <package(s)>
           List packages, groups, repositories or files
       pamac info [options] <package(s)>
           Display package details, multiple packages can be specified
       pamac install [options] <package(s)>
           Install packages from repositories, path or url
       pamac reinstall [options] <package(s)>
           Reinstall packages
       pamac remove [options] [package(s)]
           Remove packages
       pamac checkupdates [options]
           Safely check for updates without modifiying the databases
       pamac upgrade [options]
           Upgrade your system
       pamac update [options]
           Upgrade your system
       pamac clone [options] <package(s)>
           Clone or sync packages build files from AUR
       pamac build [options] [package(s)]
           Build packages from AUR and install them with their dependencies
       pamac clean [options]
           Clean packages cache or build files
OPERATION OPTIONS
   SEARCH
       pamac search [options] <package(s)/file(s)>)
           --installed, -i
               only search for installed packages
           --repos, -r
               only search for packages in repositories
           --aur, -a
               also search in AUR
           --no-aur
               do not search in AUR
           --files, -f
               search for packages which own the given filenames (filenames can be partial)
           --quiet, -q
               only print names
   LIST
           --installed, -i
               list installed packages
           --explicitly-installed, -e
               list explicitly installed packages
           --orphans, -o
               list packages that were installed as dependencies but are no longer required by any installed package
           --foreign, -m
               list packages that were not found in the repositories
           --groups, -g [group(s)]
               list all packages that are members of the given groups, if no group is given list all groups
           --repos, -r [repo(s)]
               list all packages available in the given repos, if no repo is given list all repos
           --files, -f <package(s)>
               list files owned by the given packages
           --quiet, -q
               only print names
   INFO
           --aur, -a
               also search in AUR
           --no-aur
   INSTALL
       pamac install [options] <package(s),group(s)>
           --ignore <package(s)>
               ignore a package upgrade, multiple packages can be specified by separating them with a comma
           --overwrite <glob>
               overwrite conflicting files, multiple patterns can be specified by separating them with comma
           --download-only, -w
               download all packages but do not install/upgrade anything
           --dry-run, -d
               only print what would be done but do not run the transaction
           --as-deps
               mark all packages installed as a dependency
           --as-explicit
               mark all packages explicitly installed
           --upgrade
               check for updates
           --no-upgrade
               do not check for updates
           --no-confirm
               bypass any and all confirmation messages
   REINSTALL
       Reinstall packages
       pamac reinstall <package(s),group(s)>
           --overwrite <glob>
               overwrite conflicting files, multiple patterns can be specified by separating them with a comma
           --download-only, -w
           --as-deps
           --as-explicit
           --no-confirm
   REMOVE
       Remove packages
       pamac remove [options] [package(s),group(s)]
           --unneeded, -u
               remove packages only if they are not required by any other packages
           --orphans, -o
               remove dependencies that are not required by other packages,qq if this option is used without package name remove all orphans
           --no-orphans
               do not remove dependencies that are not required by other packages
           --no-save, -n
               ignore files backup
           --dry-run, -d
           --no-confirm
   CHECKUPDATES
           --builddir <dir>
               build directory (use with --devel), if no directory is given the one specified in pamac.conf is used
           --aur, -a
               also check updates in AUR
           --no-aur
               do not check updates in AUR
           --quiet, -q
               only print one line per update
           --devel
               also check development packages updates (use with --aur)
           --no-devel
               do not check development packages updates
       Exit code is 100 if updates are available.
   UPGRADE, UPDATE
       Upgrade your system
       pamac upgrade,update [options]
           --force-refresh
               force the refresh of the databases
           --enable-downgrade
               enable package downgrades
           --disable-downgrade
               disable package downgrades
           --download-only, -w
               ignore a package upgrade, multiple packages can be specified by separating them with comma
           --overwrite <glob>
           --no-confirm
           --aur, -a
               also upgrade packages installed from AUR
           --no-aur
               do not upgrade packages installed from AUR
           --devel
               also upgrade development packages (use with --aur)
           --no-devel
               do not upgrade development packages
           --builddir <dir>
               build directory (use with --aur), if no directory is given the one specified in pamac.conf file is used
   CLONE
           --builddir <dir>
               build directory, if no directory is given the one specified in pamac.conf file is used
           --recurse, -r
               also clone needed dependencies
           --quiet, -q
               do not print any output
           --overwrite
               overwrite existing files
   BUILD
           --builddir <dir>
           --keep, -k
               keep built packages in cache after installation
           --no-keep
               do not keep built packages in cache after installation
           --dry-run, -d
           --no-clone
               do not clone build files from AUR, only use local files
           --no-confirm
       If no package name is given, use the PKGBUILD file in the current directory. The build directory will be the parent directory, --builddir option will be ignored and --no-clone option will be enforced.
   CLEAN
           --keep, -k <number>
               specify how many versions of each package are kept in the cache directory
           --uninstalled, -u
               only target uninstalled packages
           --build-files, -b
               remove all build files, the build directory is the one specified in pamac.conf
           --dry-run, -d
               do not remove files, only find candidate packages
           --verbose, -v
               also display all files names
           --no-confirm
EXAMPLES
       pamac search smplayer
           Search for packages in repos containing the word smplayer
       pamac search -a smplayer
           Search for packages in repos and AUR containing the word smplayer
       pamac install smplayer smplayer-themes
           Install smplayer and themes from the repos
       pamac reinstall smplayer
           Force a package to be installed even if it is already installed
       pamac build umplayer
           Compile and install umplayer from AUR
       pamac clone umplayer ~/Download
           Clone umplayer from AUR in Download folder
       pamac remove smplayer smplayer-themes umplayer
           Uninstall smplayer, smplayer-themes and umplayer
       pamac list -i
           Display a list of all installed packages
       pamac info -a smplayer
           Display information about a package in repos, AUR or installed
       pamac checkupdates -a
           Check if updates are available in repos and AUR
       pamac upgrade -a or pamac update -a
           Upgrade all packages installed from the repos or AUR
       pamac list -o
           Check if there are any orphaned packages installed
       pamac remove -o
           Remove all orphans
       pamac clean --keep 3
           Clear the cache except for the latest three package versions
ENVIRONMENT VARIABLES
       AURDEST
           Can be set to configure the build directory. Overridden by --builddir.
       EDITOR
           When editor is not configured, use these variables to pick what editor to use when editing PKGBUILDS.
CONFIGURATION
       See pamac.conf(5) for more details on configuring pamac using the /etc/pamac.conf file.
SEE ALSO
       pamac.conf(5)
BUGS
       Please report bugs to our Gitlab page https://gitlab.manjaro.org/applications/pamac/-/issues.
AUTHORS
       Guillaume Benoit
        08/21/2021        PAMAC(8)
While that is technically true I am not sure installing a daemon solely to enable the use of a small cli utility seems like overkill. :nerd_face:
It certainly is!
I remember being new to Manjaro and was obscenely confused for a few weeks trying to figure out why so many typos were acceptable. Especially since it wasn’t called pamac in the application menu. It said add/remove software.
Yeah, I too was wondering: “why are all these people unable to spell ‘pacman’ correctly, it’s not such a difficult word” :rofl:
Does this leave octopi the secret agent of GUI updating? :crazy_face:
It uses libalpm for reading the alpm databases, searching for packages and seeing what’s available in the repos, what’s actually installed etc.
Now when it comes to installing/upgrading/removing packages, it utilizes pacman itself by just running the binary with the appropriate parameters/flags…
