Electron = chonky most of the time lol
Yeah, good point. Electron is a bit heavy!
And what difference do you see between popsicle and imagewriter?
I know I’m repeating myself, but everything will be clear if you read this:
It’s bloat! Balena Bloat!
If you check the comment under the package, you have my comment ![]()
https://aur.archlinux.org/packages/popsicle#comment-819871
The build is failing when using rust package. If I install rustup beforehand, cargo fetches tool chain for version 1.40.0 before build, and it succeeds.
Popsicle-git works perfectly fine, but in case the git version breaks for some reason you could use this workaround to get the stable one working. You also have popsicle-bin in case you want to skip compiling all together.
Irony is a very British trait, I’m afraid.
