I just learned that I can download arch-wiki-lite and arch-wiki-docs for offline reading!
haha, too cool!
haha, too cool!
Yeah, we’ve discussed it somewhere on forum before - it’s extra cool, and wise might i add, to have an offline archwiki
How do you read it offline? Via terminal,?
Oooooh yeaaah, well there is also version which have just html copy offline which you can launch in browser as usual ![]()
community/arch-wiki-docs 20200527-1
Pages from Arch Wiki optimized for offline browsing
community/arch-wiki-lite 20200527-1
The wiki without html. 1/9 as big, easily searched and viewable on console.
The docs one have html
Yeah, I wanna know this too.
I ran the commands arch-wiki-lite and arch-wiki-docs but command not found.
Quick Google, do this in terminal: wiki-search QUERY.
Did some further digging, HTML files are located here /usr/share/doc/arch-wiki/html/en
Just run firefox /usr/share/doc/arch-wiki/html/en/Table_of_contents.html
To find the files of a package, run
pacman -Fl <package>
You may have to run
pacman -Fy
before that works.
started using arch-wiki-lite, easy to use in the terminal!
In the interests of making the ‘Arch Way’ install easier (for me) I installed the Archwiki app on my Android tablet. Definitely a worthwhile endeavour (sorry)
What’s the name arch wiki viewer online?
Or arch wiki manual offline…
Edit also found AURdroid and arch packages brilliant apps.
