No, it didn’t work and yes I have grep installed…
Same here on my desktop.
If it doesn’t work, what is your filesystem?
ext4
I would guess that the word “Birth” needs to be changed to the language used on the installed system if you are not using English. (Or just use stat /)
Works here.
Birth: 2021-03-24 11:03:43.000000000 -0400
this ?
stat / | grep Ontstaan
dutch
$ stat / | grep Birth
Birth: 2020-01-07 23:21:03.000000000 +0200
This is the date my laptop arrived ![]()
My experience is similar to yours. I have broken some things during this time while fiddling, and was about to reinstall just a few weeks ago, but then I decided to give the matter a bit more attention and I managed to fix the bugs that were gnawing at my patience lately. Upon fixing them I discovered the culprit to be some “tweaks” or failed fixes I did at some time or another
Yep, dit werkt.
Does this help?
LANG=C stat / | grep Birth
$ LANG=C stat / | grep Birth
Birth: 2020-01-11 20:09:47.000000000 +0100
Never!
I keep practicing by reinstalling. Sometimes Arch most of the time EndeavourOS. This one i stopped and try to leave alone now!
Birth: 2020-08-03 22:16:51.999251563 -0400
Evidently I never quite got around to that clean Endeavouros install I’d promised myself. Despite embiggening the disk in the last year.
My Franken AnterEndeavouros is running sweet though
Birth: 2018-03-31 17:02:20.000000000 +0100
Same here, i keep practicing reinstall every month it seems lol.
Birth: 2021-05-04 14:44:51.000000000 -0400
Now that’s impressive. 3+ years? Keep it up!!
~ stat / | grep Créé
Créé : 2018-02-27 18:31:47.000000000 +0100
A classical Arch installed using Anarchy Linux… 3 years and 2 months or 38 months… How times fly by…
[csteinforth@E14 ~]$ LANG=C stat / | grep Birth
Birth: 2020-10-18 20:52:32.000000000 +0200
Not that long but the longest time an install of a Linux distro survived.
I can confirm this for an E14. Maybe not the top notch, but a solid choice. The predecessor was an E530, which also worked very well.
