Hi Guys, April’s release will not boot for me, i can select the default option in the menu but after that it just hangs at probing EDD(edd=off to disable)…ok. Computer is a Dell Inspiron 1545, have download the image several times and md5 and sig check out every time also tried different usb sticks. With previous versions i have had no problems booting.
Hi!
Can you provide detailed information about your computer? For example, command
hwinfo --short
[phil@caldew ~]$ hwinfo --short
cpu:
Pentium® Dual-Core CPU T4300 @ 2.10GHz, 1480 MHz
Pentium® Dual-Core CPU T4300 @ 2.10GHz, 1625 MHz
keyboard:
/dev/input/event3 AT Translated Set 2 keyboard
mouse:
/dev/input/mice Logitech M-BT96a Pilot Optical Mouse
/dev/input/mice AlpsPS/2 ALPS GlidePoint
monitor:
K647H N156B3 LCD Monitor
graphics card:
Intel Mobile 4 Series Chipset Integrated Graphics Controller
sound:
Intel 82801I (ICH9 Family) HD Audio Controller
storage:
Intel 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode]
network:
enp9s0 Marvell 88E8040 PCI-E Fast Ethernet Controller
network interface:
enp9s0 Ethernet network interface
lo Loopback network interface
disk:
/dev/sdb Generic Multi-Card
/dev/sda ST9500325AS
Realtek USB 2.0 multicard reader
partition:
/dev/sda1 Partition
/dev/sda2 Partition
/dev/sda3 Partition
/dev/sda4 Partition
/dev/sda5 Partition
/dev/sda6 Partition
/dev/sda7 Partition
/dev/sda8 Partition
/dev/sda9 Partition
/dev/sda10 Partition
/dev/sda11 Partition
cdrom:
/dev/sr0 Optiarc DVD±RW AD-7700H
usb controller:
Intel 82801I (ICH9 Family) USB UHCI Controller #5
Intel 82801I (ICH9 Family) USB UHCI Controller #2
Intel 82801I (ICH9 Family) USB UHCI Controller #6
Intel 82801I (ICH9 Family) USB UHCI Controller #3
Intel 82801I (ICH9 Family) USB UHCI Controller #4
Intel 82801I (ICH9 Family) USB UHCI Controller #1
Intel 82801I (ICH9 Family) USB2 EHCI Controller #2
Intel 82801I (ICH9 Family) USB2 EHCI Controller #1
bios:
BIOS
bridge:
Intel 82801I (ICH9 Family) PCI Express Port 1
Intel ICH9M LPC Interface Controller
Intel 82801 Mobile PCI Bridge
Intel Mobile 4 Series Chipset Memory Controller Hub
Intel 82801I (ICH9 Family) PCI Express Port 5
Intel 82801I (ICH9 Family) PCI Express Port 3
hub:
Linux Foundation 1.1 root hub
Linux Foundation 2.0 root hub
memory:
Main Memory
unknown:
FPU
DMA controller
PIC
Keyboard controller
Intel 82801I (ICH9 Family) SMBus Controller
/dev/input/event12 Ricoh Integrated Webcam
The other day i tried https://github.com/endeavouros-team/ISO/releases/download/0-EndeavourOS-development-ISO-releases/endeavouros-devel-2020.04.09-x86_64_rc2.iso which booted without a problem.
Just wait a minute, eventually it will boot, I also had this on an older test machine.
Ok i will give it a try.
Yes it did boot after nearly 10 minutes
What has changed, when i install a new system will i have this delay every time i boot.
If i turn EDD off what effect will that have.
10 minutes is long, it took under 2 minutes on that older laptop (2008 model) over here, my newer machines don’t have that problem @joekamprad or @fernandomaroto?
Could you show the output of:
systemd-analyze blame
14.129s dhcpcd@enp9s0.service
9.707s ldconfig.service
5.500s lvm2-monitor.service
4.991s dev-sdb.device
2.297s dev-loop0.device
2.102s upower.service
1.231s systemd-journald.service
1.138s systemd-logind.service
952ms systemd-udevd.service
931ms udisks2.service
929ms systemd-timesyncd.service
740ms polkit.service
620ms NetworkManager.service
554ms systemd-udev-trigger.service
362ms systemd-modules-load.service
258ms user@1000.service
110ms systemd-sysusers.service
97ms tmp.mount
96ms kmod-static-nodes.service
88ms systemd-sysctl.service
87ms sys-kernel-tracing.mount
87ms dev-hugepages.mount
87ms dev-mqueue.mount
86ms sys-kernel-debug.mount
85ms systemd-journal-catalog-update.service
67ms systemd-remount-fs.service
66ms systemd-tmpfiles-setup-dev.service
63ms systemd-tmpfiles-setup.service
58ms systemd-journal-flush.service
Just done a quick fresh install of the new release and it does not hang at boot (good news).
how do you “burn” iso ?
I use Gnome Disks to burn iso.
When i say i’ve done a fresh install i mean i booted new release, waited for it to boot, then installed i3 onto my hard drive. I then reboot into my new install on my hard drive without a delay when booting.
i was try asking how do you use the ISO file, like burning it to a DVD or copy it to usb-pendrive, with an app or command?
It’s interesting that you said had no delay with 2020.04.09-x86_64_rc2.iso
and with 04.11
you face the issue.
As i see on archlinux site, the kernel was updated 2020-04-08 and systemd 2020-04-03, they were good candidates for guilty, but they were present on the iso that worked for you.
I have this on VM sometimes, when that happens i just porweroff and boot the VM again. Ok, VM is not real machine, but this behaviour seems random…
Ok, good that you checked different things already.
Very important to test different usb ports on your device, maybe one is malfunctioning.
Any chance for you to make the usb using dd command?
At least is working fine after install…
I can try different usb ports and also try dd command to burn iso.
If we just go back to the beginning for a moment, it hangs at
“probing EDD(edd=off to disable)…ok”
which means it has completed that task, right.
next i get a flashing cursor on the next line until the delay is finished, then the next line to appear is “running early hook for [udev]” maybe this is where the system is hanging.
Thank you for the report, we are looking into it now.
Burnt two sdcards using the dd command in the intergrated card reader and booted from same.
Burnt two usb sticks using the dd command in each usb port and booted from same, for a total of three ports.
On every boot it hangs after “probing EDD(edd=off to disable)…ok” then after long delay boot continues.
I just tested it on an old machine (2010) and it had also a long boot for the ISO, I did an install and when the system is installed, it boots with the regular speed.
I tried to boot the new version and I took about 4 minutes to boot on one of my testing laptops.
During that time the display showed after the message mentioned above (“probing EDD(edd=off to disable)…ok.”) following error:
ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - LNKG (20200110/dspkginit-438)
