April release will not boot
As mentioned earlier, we are looking into these problems and are going to offer a fixed ISO, when ready.
Are you booting from UEFI or Bios? Do you know how to add a kernel parameter to the boot? Maybe ACPI=Off
From BIOS.
But as mentioned from @Bryanpwo you just have to wait some time for the system to boot anyway.
Well you try booting on the ISO and when the menu comes up on the screen press the tab key. Enter ACPI=Off at the end of the line and press F10 and then enter to boot to see if it’s any different.
I too have noticed the lengthy delay on the booting of my April iso. It’s from a usb stick … until I confirm that it will run without problems. Cautious me! After it starts, things appear to work okay. What about a simple cure … inserting edd=no … to bypass this step??
riccardo
(Canberra)
Neither ACPI=off or EDD=off appended to kernel boot parameters works for me, just have to wait for fixed iso.
Is this your first attempt at installing EndeavourOS? What is your hardware? Post the link to the following command.
inxi -Fxxc0 | curl -F ‘f:1=<-’ lx.io
Have been using EndeavourOS for about six months. Once installed it works without fault.
System: Host: caldew Kernel: 5.6.4-arch1-1 x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Gnome 3.36.1 wm: gnome-shell
dm: GDM Distro: EndeavourOS
Machine: Type: Portable System: Dell product: Inspiron 1545 v: N/A serial: <superuser/root required> Chassis: type: 8
Mobo: Dell model: 0G848F serial: <superuser/root required> BIOS: Dell v: A14 date: 12/07/2009
Battery: ID-1: BAT0 charge: 15.3 Wh condition: 15.9/48.8 Wh (32%) volts: 11.5/11.1 model: SMP DELL Y823G9 serial: 1114
status: Unknown
CPU: Topology: Dual Core model: Pentium T4300 bits: 64 type: MCP arch: Penryn rev: A L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 8381
Speed: 1202 MHz min/max: 1200/2100 MHz Core speeds (MHz): 1: 1680 2: 1821
Graphics: Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:2a42
Display: wayland server: X.Org 1.20.8 driver: i915 compositor: gnome-shell resolution: 1366x768~60Hz
Audio: Device-1: Intel 82801I HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:293e
Sound Server: ALSA v: k5.6.4-arch1-1
Network: Device-1: Marvell 88E8040 PCI-E Fast Ethernet vendor: Dell driver: sky2 v: 1.30 port: de00 bus ID: 09:00.0
chip ID: 11ab:4354
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: 00:25:64:69:08:45
Drives: Local Storage: total: 465.76 GiB used: 10.70 GiB (2.3%)
ID-1: /dev/sda vendor: Seagate model: ST9500325AS size: 465.76 GiB speed: 3.0 Gb/s serial: 5VE4GHVC
Partition: ID-1: / size: 53.89 GiB used: 10.64 GiB (19.7%) fs: ext4 dev: /dev/sda9
ID-2: /boot size: 503.9 MiB used: 59.0 MiB (11.7%) fs: ext2 dev: /dev/sda8
Sensors: System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 167 Uptime: 4h 02m Memory: 3.81 GiB used: 1.32 GiB (34.6%) Init: systemd v: 245 Compilers: gcc: 9.3.0
Shell: bash v: 5.0.16 running in: gnome-terminal inxi: 3.0.38
