Amdgpu ring gfx_0.0.0 timeout
When I wiped those kernel params my score is much lower
I tried those kernel parameters and my score is lower than i posted by a little.
what is hardware you are using?
5800X with AMD RX6750 XT MSI B550
Tried the new LTS kernel and glmark2 died again on the shadows test. Someday it will be all stable. Today is not that day.
6.12.45-1-lts
Tried kernel-mainline on both Xorg and wayland with/without kernel params. No joy. About given up
What is your motherboard?
ASUS Prime Z690M-Plus D4
Are you running the latest Bios version 3801?
Updated 3 weeks ago
Are you running stock settings or are you tweaking it?
I don’t tweak the hardware, everything is stock settings. When Minecraft is not locking up the kernel here is what it looks like
Also tried Oracle java as well as openjdk
Never had an issue late last year and given there are 91 ring timeout tickets opened in the last 3 months at Mesa make me think they don’t know what is the cause yet.
Hard to play the game when it looks like that. :wink:
What is strange to me is your glmark2 score is so much higher than mine.
 glmark2 Score: 32327
Edit: I have the RX6750 XT so it should be similar.
Well I’m back to not even being able to run glmark2. Just tried and it crapped the bed
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.1.0 timeout, signaled seq=148660, emitted seq=148662
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Process information: process kwin_wayland pid 5072 thread kwin_wayla:cs0 pid 5205
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.1.0 ring reset
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.1.0 reset failed
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
Sep 19 12:55:36 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
Sep 19 12:55:45 acefour-1 kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Sep 19 12:55:46 acefour-1 kwin_wayland[5072]: kwin_wayland_drm: Pageflip timed out! This is a bug in the amdgpu kernel driver
Sep 19 12:55:47 acefour-1 kwin_wayland[5072]: kwin_wayland_drm: Pageflip timed out! This is a bug in the amdgpu kernel driver
Sep 19 12:55:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset succeeded, trying to resume
Sep 19 12:55:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
Sep 19 12:55:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 19 12:55:48 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 19 12:55:48 acefour-1 kwin_wayland[5072]: kwin_wayland_drm: Pageflip timed out! This is a bug in the amdgpu kernel driver
Sep 19 12:55:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 19 12:55:50 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 19 12:55:51 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 19 12:55:52 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 19 12:55:52 acefour-1 kernel: [drm:psp_v11_0_memory_training [amdgpu]] *ERROR* send training msg failed.
Sep 19 12:55:52 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Failed to process memory training!
Sep 19 12:55:52 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: resume of IP block <psp> failed -62
Sep 19 12:55:52 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset end with ret = -62
Sep 19 12:55:52 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU Recovery Failed: -62
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.1.0 timeout, signaled seq=148662, emitted seq=148662
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Process information: process kwin_wayland pid 5072 thread kwin_wayla:cs0 pid 5205
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.1.0 ring reset
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.1.0 reset failed
Sep 19 12:56:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
kernel_cmdline="amdgpu.noretry=0 amdgpu.lockup_timeout=0 iommu=pt amdgpu.gpu_recovery=1 amdgpu.runpm=0 amdgpu.mcbp=0 amdgpu.ppfeaturemask=0xfffd3fff"
Maybe some of the kernel parameters are not helping? :person_shrugging: Have you tried this one also?
amdgpu.dcdebugmask=0x10
yep
So I am not sure what this does but it sort of works. The Mesa env var for zink does not work with regular minecraft-launcher.
  • Using kernel params
  • Using Oracle JDK with params -Dsun.java3d.opengl=true -XX:+DisableExplicitGC -XX:MaxGCPauseMillis=500 -XX:SurvivorRatio=16 -XX:+UseParallelGC -XX:UseSSE=3 -XX:ParallelGCThreads=10
  • Using MultiMc launcher with optifine mod added
  • Clouds kept flashing on and off so turned the cloud option off. Later I turned it back on and they worked.
Result is no black lines and smooth game play
kernel_cmdline="amdgpu.noretry=0 amdgpu.lockup_timeout=0 iommu=pt amdgpu.gpu_recovery=1 amdgpu.runpm=0 amdgpu.mcbp=0 amdgpu.ppfeaturemask=0xfffd3fff amdgpu.dcdebugmask=0x10"
~ via 🌙 v5.4.8
❯ cat /etc/dracut.conf.d/cmdline.conf
~ via 🌙 v5.4.8
❯ java -version
java version "24.0.2" 2025-07-15
Java(TM) SE Runtime Environment (build 24.0.2+12-54)
Java HotSpot(TM) 64-Bit Server VM (build 24.0.2+12-54, mixed mode, sharing)
~ via 🌙 v5.4.8 took 12s
❯ MESA_LOADER_DRIVER_OVERRIDE=zink multimc
Reading up on it, sink takes opengl calls and translates them to vulkan calls
So while the benchmark is slower, it isn’t crashing so that is good
❯ MESA_LOADER_DRIVER_OVERRIDE=zink glmark2
    glmark2 2023.01
    OpenGL Information
    GL_VENDOR:      Mesa
    GL_RENDERER:    zink Vulkan 1.4(AMD Radeon RX 6700 (RADV NAVI22) (MESA_RADV))
    GL_VERSION:     4.6 (Compatibility Profile) Mesa 25.2.3-arch1.2
    Surface Config: buf=32 r=8 g=8 b=8 a=8 depth=24 stencil=0 samples=0
    Surface Size:   800x600 windowed
[build] use-vbo=false: FPS: 10288 FrameTime: 0.097 ms
[build] use-vbo=true: FPS: 15848 FrameTime: 0.063 ms
[texture] texture-filter=nearest: FPS: 15701 FrameTime: 0.064 ms
[texture] texture-filter=linear: FPS: 15632 FrameTime: 0.064 ms
[texture] texture-filter=mipmap: FPS: 15494 FrameTime: 0.065 ms
[shading] shading=gouraud: FPS: 15546 FrameTime: 0.064 ms
[shading] shading=blinn-phong-inf: FPS: 15349 FrameTime: 0.065 ms
[shading] shading=phong: FPS: 15424 FrameTime: 0.065 ms
[shading] shading=cel: FPS: 14841 FrameTime: 0.067 ms
[bump] bump-render=high-poly: FPS: 14304 FrameTime: 0.070 ms
[bump] bump-render=normals: FPS: 14866 FrameTime: 0.067 ms
[bump] bump-render=height: FPS: 15240 FrameTime: 0.066 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 15088 FrameTime: 0.066 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 14651 FrameTime: 0.068 ms
[pulsar] light=false:quads=5:texture=false: FPS: 14425 FrameTime: 0.069 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 8285 FrameTime: 0.121 ms
[desktop] effect=shadow:windows=4: FPS: 8534 FrameTime: 0.117 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 1785 FrameTime: 0.561 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 2223 FrameTime: 0.450 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 2255 FrameTime: 0.444 ms
[ideas] speed=duration: FPS: 6927 FrameTime: 0.144 ms
[jellyfish] <default>: FPS: 12674 FrameTime: 0.079 ms
[terrain] <default>: FPS: 2819 FrameTime: 0.355 ms
[shadow] <default>: FPS: 12624 FrameTime: 0.079 ms
[refract] <default>: FPS: 5535 FrameTime: 0.181 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 14075 FrameTime: 0.071 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 14138 FrameTime: 0.071 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 13890 FrameTime: 0.072 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 14170 FrameTime: 0.071 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 13769 FrameTime: 0.073 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 13853 FrameTime: 0.072 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 13675 FrameTime: 0.073 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 13570 FrameTime: 0.074 ms
                                  glmark2 Score: 12044
