Amdgpu ring gfx_0.0.0 timeout
Running wayland and noticing minecraft started causing issues. Running latest linux kernel 6.16.3-arch1-1 and noticed those are being pushed out rapid fire this last week so likely a kernel issue.
Aug 26 18:20:08 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Aug 26 18:20:08 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Aug 26 18:20:08 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Aug 26 18:20:08 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Aug 26 18:20:09 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=7925632, emitted seq=7925634
Aug 26 18:20:09 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Process information: process java pid 456665 thread java:cs0 pid 456716
Aug 26 18:20:09 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
Aug 26 18:20:09 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset failed
Aug 26 18:20:09 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
Aug 26 18:20:09 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
Aug 26 18:20:09 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
Aug 26 18:20:09 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
Aug 26 18:20:20 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset succeeded, trying to resume
Aug 26 18:20:20 acefour-1 kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000300000).
Aug 26 18:20:20 acefour-1 kernel: [drm] VRAM is lost due to GPU reset!
Aug 26 18:20:20 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
Aug 26 18:20:20 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
❯ lspci -k -d ::03xx
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT] (rev df)
	Subsystem: XFX Limited Radeon RX 6700 [SPEEDSTER SWFT 309]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
Not sure if there is anything that can be done other than maybe switch to LTS kernel.
The errors you’re encountering align with known regressions in recent Linux kernels and the AMDGPU stack under Wayland. This user report details the same sequence: “ring gfx_0.0.0 timeout,” leading to VRAM loss, PSP resume failure, and system crashes under Wayland. This points to a kernel regression causing AMDGPU instability under specific workloads or environments. I suggest trying a LTS kernel as a starting point.
Out of curiosity, doesn’t the latest mainline Linux kernel, i.e. 6.16.x in 2025, have all the fixes of the LTS kernel and new features/capabilities? Features/Capabilities that are missing from the LTS kernels. Or am I missing something?
Yes. And new features can introduce bugs resp. regressions which you do not see in the LTS kernel.
Looks like it affects LTS kernel too. Just tried it out
@AceFour which LTS kernel did you try out, 6.12.x or 6.6.x or 6.1.x.
Please do not note that some of these kernels are hosted in AUR so please be careful while installing or using them. Recently there has been a spate of disturbances in the force, i.e. people trying to upload malicious packages in AUR.
p.s. Sorry could not give the links to the other LTS kernels from AUR, the AUR website just crashed with the message, “502 Bad Gateway”
Someone had posted a issue similar to this but for AMD Ryzen 7 5700x3d, GPU RX7900xt running Wayland on Linux mainline kernel 6.15.x on the Arch Forum website.
The difference is that it happens randomly and not while playing minecraft.
@AceFour was that you who posted it?
Maybe this should be kicked upstairs to the Linux Kernel mailing list?
6.12.x and it was not me that posted. I have an Intel CPU. I might do that as it doesn’t take long to fail with me and pretty consistent
So basically it does to appear to be an issue with AMD GPU.
And appears they have no idea either. Tried some other desktops on Wayland and X11 and none work and the graphical tearing is worse then it has ever been. Not holding my breath that this will be fixed quickly and not important enough for me to start downgrading everything.
On a side note I’m kind of digging Cosmic desktop. I don’t know how long I will use it as I am a Hyprland/NeoVim/TMUX do everything with a keyboard kind of guy. However my wife has just about had it with Microshaft and wants me to drop linux on her laptop. This desktop is pretty easy to use for her.
@AceFour
Have you tried the following kernel parameter.
amdgpu.ppfeaturemask=0xfffd3fff
Have not, let me give it a go
Punts almost immediately when I start the minecraft world. Here is the kernel log
Aug 31 20:05:37 acefour-1 kernel: /proc/cgroups lists only v1 controllers, use cgroup.controllers of root cgroup for v2 info
Aug 31 20:06:37 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Aug 31 20:06:37 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Aug 31 20:06:37 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Aug 31 20:06:37 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Aug 31 20:06:38 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=27621, emitted seq=27623
Aug 31 20:06:38 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Process information: process java pid 5678 thread java:cs0 pid 5727
Aug 31 20:06:38 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
Aug 31 20:06:38 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset failed
Aug 31 20:06:38 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
Aug 31 20:06:38 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
Aug 31 20:06:38 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
Aug 31 20:06:38 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
Aug 31 20:06:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset succeeded, trying to resume
Aug 31 20:06:49 acefour-1 kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000300000).
Aug 31 20:06:49 acefour-1 kernel: [drm] VRAM is lost due to GPU reset!
Aug 31 20:06:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
Aug 31 20:06:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Aug 31 20:06:50 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Aug 31 20:06:51 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Aug 31 20:06:52 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Aug 31 20:06:53 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Aug 31 20:06:54 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Aug 31 20:06:54 acefour-1 kernel: [drm:psp_v11_0_memory_training [amdgpu]] *ERROR* send training msg failed.
Aug 31 20:06:54 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Failed to process memory training!
Aug 31 20:06:54 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: resume of IP block <psp> failed -62
Aug 31 20:06:54 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset end with ret = -62
Aug 31 20:06:54 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU Recovery Failed: -62
I capture the log for Minecraft Launcher and got this . . .
Gtk-Message: 20:04:33.751: Failed to load module "colorreload-gtk-module"
sh: line 1: orca: command not found
Created browser window for reuse: 0x600004
[5279:5279:0831/200433.888634:ERROR:browser_main_loop.cc(280)] Gdk: _gdk_frame_clock_freeze: assertion 'GDK_IS_FRAME_CLOCK (clock)' failed
[5403:5452:0831/200434.395177:ERROR:ffmpeg_common.cc(965)] Unsupported pixel format: -1
terminate called after throwing an instance of 'std::bad_function_call'
  what():  bad_function_call
[5279:5279:0831/200537.251885:ERROR:browser_main_loop.cc(280)] Gdk: _gdk_frame_clock_thaw: assertion 'GDK_IS_FRAME_CLOCK (clock)' failed
Created browser window for reuse: 0x60001b
[5279:5279:0831/200537.449941:ERROR:browser_main_loop.cc(280)] Gdk: _gdk_frame_clock_freeze: assertion 'GDK_IS_FRAME_CLOCK (clock)' failed
[5402:5655:0831/200537.974338:ERROR:ffmpeg_common.cc(965)] Unsupported pixel format: -1
[5279:5279:0831/200604.159230:ERROR:browser_main_loop.cc(280)] Gdk: _gdk_frame_clock_thaw: assertion 'GDK_IS_FRAME_CLOCK (clock)' failed
[5279:5279:0831/200633.901591:ERROR:gpu_process_host.cc(1007)] GPU process exited unexpectedly: exit_code=512
[5799:5799:0831/200701.460520:ERROR:connection.cc(61)] X connection error received.
Which is probably because the display crashed the launcher window lost display connection.
❯ systool -vm amdgpu
Module = "amdgpu"
  Attributes:
    coresize            = "15593472"
    initsize            = "0"
    initstate           = "live"
    refcnt              = "51"
    srcversion          = "70CE4A20C522BE541822B9B"
    taint               = ""
    uevent              = <store method only>
  Parameters:
    abmlevel            = "-1"
    agp                 = "-1"
    aspm                = "-1"
    async_gfx_ring      = "1"
    audio               = "-1"
    backlight           = "-1"
    bad_page_threshold  = "-1"
    bapm                = "-1"
    cg_mask             = "18446744073709551615"
    cik_support         = "0"
    compute_multipipe   = "-1"
    cwsr_enable         = "1"
    damageclips         = "-1"
    dc                  = "-1"
    dcdebugmask         = "0"
    dcfeaturemask       = "2"
    debug_evictions     = "N"
    debug_mask          = "0"
    deep_color          = "0"
    disable_cu          = "(null)"
    discovery           = "-1"
    disp_priority       = "0"
    dpm                 = "-1"
    emu_mode            = "0"
    enforce_isolation   = "-1"
    exp_hw_support      = "0"
    force_asic_type     = "-1"
    forcelongtraining   = "0"
    freesync_video      = "1"
    fw_load_type        = "-1"
    gpu_recovery        = "-1"
    halt_if_hws_hang    = "0"
    hw_i2c              = "0"
    hws_gws_support     = "N"
    hws_max_conc_proc   = "-1"
    ip_block_mask       = "4294967295"
    lbpw                = "-1"
    lockup_timeout      = ""
    max_num_of_queues_per_device= "4096"
    mcbp                = "-1"
    mes_kiq             = "0"
    mes                 = "0"
    mes_log_enable      = "0"
    modeset             = "-1"
    msi                 = "-1"
    mtype_local         = "0"
    no_queue_eviction_on_vm_fault= "0"
    no_system_mem_limit = "N"
    noretry             = "-1"
    num_kcq             = "-1"
    pcie_gen2           = "-1"
    pcie_gen_cap        = "0"
    pcie_lane_cap       = "0"
    pg_mask             = "4294967295"
    ppfeaturemask       = "0xfffd3fff"
    queue_preemption_timeout_ms= "9000"
    ras_enable          = "-1"
    ras_mask            = "4294967295"
    rebar               = "-1"
    reset_method        = "-1"
    runpm               = "-1"
    sched_hw_submission = "2"
    sched_jobs          = "32"
    sched_policy        = "0"
    sdma_phase_quantum  = "32"
    seamless            = "-1"
    send_sigterm        = "0"
    sg_display          = "-1"
    si_support          = "0"
    smu_memory_pool_size= "0"
    smu_pptable_id      = "-1"
    svm_default_granularity= "9"
    timeout_fatal_disable= "N"
    timeout_period      = "0"
    tmz                 = "-1"
    umsch_mm_fwlog      = "0"
    umsch_mm            = "0"
    uni_mes             = "1"
    use_xgmi_p2p        = "1"
    user_partt_mode     = "4294967294"
    user_queue          = "-1"
    vcnfw_log           = "0"
    virtual_display     = "(null)"
    vis_vramlimit       = "0"
    visualconfirm       = "0"
    vm_block_size       = "-1"
    vm_fault_stop       = "0"
    vm_fragment_size    = "-1"
    vm_size             = "-1"
    vm_update_mode      = "-1"
    wbrf                = "-1"
  Sections:
❯ inxi -Fxxc0z | eos-sendlog
https://0x0.st/KHwd.txt
Have you checked if there is a newer Bios update?
Edit: Looks like a GDK/GTK+ issue.
Ok, updated the bios and fired up minecraft . . . the tearing is pretty bad. I had all the effects off. It lasted about 2-3 minutes and then crashed. However this time there wasn’t anything in the journal for amdgpu so I guess that is a positive.
The screen still goes dark and I have to hard reset the machine.
Sep 01 12:52:05 acefour-1 systemd-coredump[1999]: Process 1983 (minecraft-launc) of user 1001 terminated abnormally with signal 6/ABRT, processing...
Sep 01 12:52:05 acefour-1 systemd[1]: Created slice Slice /system/systemd-coredump.
Sep 01 12:52:05 acefour-1 systemd[1]: Started Process Core Dump (PID 1999/UID 0).
Sep 01 12:52:05 acefour-1 systemd-coredump[2000]: [🡕] Process 1983 (minecraft-launc) of user 1001 dumped core.
                                                  Stack trace of thread 1983:
                                                  #0  0x00007f9e7189894c n/a (libc.so.6 + 0x9894c)
                                                  #1  0x00007f9e7183e410 raise (libc.so.6 + 0x3e410)
                                                  #2  0x00007f9e7182557a abort (libc.so.6 + 0x2557a)
                                                  #3  0x00007f9e71c97bf6 _ZN9__gnu_cxx27__verbose_terminate_handlerEv (libstdc++.so.6 + 0x97bf6)
                                                  #4  0x00007f9e71cb1eba _ZN10__cxxabiv111__terminateEPFvvE (libstdc++.so.6 + 0xb1eba)
                                                  #5  0x00007f9e71c97445 __cxa_call_terminate (libstdc++.so.6 + 0x97445)
                                                  #6  0x00007f9e71cb169c __gxx_personality_v0 (libstdc++.so.6 + 0xb169c)
                                                  #7  0x00007f9e71bf4aab _Unwind_RaiseException_Phase2 (libgcc_s.so.1 + 0x21aab)
                                                  #8  0x00007f9e71bf55ca _Unwind_Resume (libgcc_s.so.1 + 0x225ca)
                                                  #9  0x00007f9e6c3339f7 n/a (liblauncher.so + 0x1339f7)
                                                  #10 0x00007f9e6c49b941 n/a (liblauncher.so + 0x29b941)
                                                  #11 0x00007f9e6c49ba8d n/a (liblauncher.so + 0x29ba8d)
                                                  #12 0x00007f9e6c49b012 n/a (liblauncher.so + 0x29b012)
                                                  #13 0x00007f9e6c3df364 n/a (liblauncher.so + 0x1df364)
                                                  #14 0x00007f9e6c3ac484 RunLauncher (liblauncher.so + 0x1ac484)
                                                  #15 0x000055b92e5a1450 n/a (/home/acefour/.minecraft/launcher/minecraft-launcher + 0x1a1450)
                                                  #16 0x000055b92e4458b9 n/a (/home/acefour/.minecraft/launcher/minecraft-launcher + 0x458b9)
                                                  #17 0x000055b92e430f19 n/a (/home/acefour/.minecraft/launcher/minecraft-launcher + 0x30f19)
                                                  #18 0x00007f9e71827675 n/a (libc.so.6 + 0x27675)
                                                  #19 0x00007f9e71827729 __libc_start_main (libc.so.6 + 0x27729)
                                                  #20 0x000055b92e4329ba _start (/home/acefour/.minecraft/launcher/minecraft-launcher + 0x329ba)
                                                  Stack trace of thread 1987:
                                                  #0  0x00007f9e7189f042 n/a (libc.so.6 + 0x9f042)
                                                  #1  0x00007f9e718931ac n/a (libc.so.6 + 0x931ac)
                                                  #2  0x00007f9e7189381c n/a (libc.so.6 + 0x9381c)
                                                  #3  0x00007f9e71895ede pthread_cond_wait (libc.so.6 + 0x95ede)
                                                  #4  0x00007f9e65737cb6 n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x6937cb6)
                                                  #5  0x00007f9e65761913 n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x6961913)
                                                  #6  0x00007f9e656e023c n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x68e023c)
                                                  #7  0x00007f9e6571b42d n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x691b42d)
                                                  #8  0x00007f9e6571aca9 n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x691aca9)
                                                  #9  0x00007f9e6571a94d n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x691a94d)
                                                  #10 0x00007f9e6571a85d n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x691a85d)
                                                  #11 0x00007f9e657384c7 n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x69384c7)
                                                  #12 0x00007f9e718969cb n/a (libc.so.6 + 0x969cb)
                                                  #13 0x00007f9e7191aa0c n/a (libc.so.6 + 0x11aa0c)
                                                  Stack trace of thread 1984:
                                                  #3  0x00007f9e718960e8 pthread_cond_timedwait (libc.so.6 + 0x960e8)
                                                  #4  0x00007f9e65737dde n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x6937dde)
                                                  #5  0x00007f9e6576193d n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x696193d)
                                                  #7  0x00007f9e6571efad n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x691efad)
                                                  #8  0x00007f9e6571f134 n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x691f134)
                                                  #9  0x00007f9e657384c7 n/a (/home/acefour/.minecraft/launcher/libcef.so + 0x69384c7)
                                                  #10 0x00007f9e718969cb n/a (libc.so.6 + 0x969cb)
                                                  #11 0x00007f9e7191aa0c n/a (libc.so.6 + 0x11aa0c)
                                                  Stack trace of thread 1986:
                                                  ELF object binary architecture: AMD x86-64
Sep 01 12:53:35 acefour-1 systemd[1]: systemd-coredump@19-2466-0.service: Consumed 127ms CPU time, 89.5M memory peak.
Sep 01 12:53:45 acefour-1 bluetoothd[952]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Sep 01 12:53:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset succeeded, trying to resume
Sep 01 12:53:46 acefour-1 kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000300000).
Sep 01 12:53:46 acefour-1 kernel: [drm] VRAM is lost due to GPU reset!
Sep 01 12:53:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
Sep 01 12:53:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 12:53:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 12:53:48 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 12:53:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 12:53:50 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 12:53:51 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 12:53:51 acefour-1 kernel: [drm:psp_v11_0_memory_training [amdgpu]] *ERROR* send training msg failed.
Sep 01 12:53:51 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Failed to process memory training!
Sep 01 12:53:51 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: resume of IP block <psp> failed -62
Sep 01 12:53:51 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset end with ret = -62
Sep 01 12:53:51 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU Recovery Failed: -62
Sep 01 12:53:56 acefour-1 systemd-logind[957]: Power key pressed short.
Sep 01 12:53:56 acefour-1 systemd-logind[957]: Powering off...
Sep 01 12:53:56 acefour-1 systemd-logind[957]: System is powering down.
Messed with so many settings I don’t know which end is up. So, I reinstalled a clean OS with KDE Plasma. Fired up minecraft and graphic tearing was still there. Game ran for a while zooming around and then it finally crapped out. Here was the amdgpu output from the journal
Sep 01 15:09:47 acefour-1 kernel: [drm] amdgpu kernel modesetting enabled.
Sep 01 15:09:47 acefour-1 kernel: amdgpu: Virtual CRAT table created for CPU
Sep 01 15:09:47 acefour-1 kernel: amdgpu: Topology: Add CPU node
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 0 <nv_common>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 1 <gmc_v10_0>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 2 <navi10_ih>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 3 <psp>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 4 <smu>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 5 <dm>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 6 <gfx_v10_0>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 7 <sdma_v5_2>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 8 <vcn_v3_0>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: detected ip block number 9 <jpeg_v3_0>
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
Sep 01 15:09:47 acefour-1 kernel: amdgpu: ATOM BIOS: 113-67L96SSD1-D02
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: vgaarb: deactivate vga console
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: VRAM: 10224M 0x0000008000000000 - 0x000000827EFFFFFF (10224M used)
Sep 01 15:09:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
Sep 01 15:09:47 acefour-1 kernel: [drm] amdgpu: 10224M of VRAM memory ready
Sep 01 15:09:47 acefour-1 kernel: [drm] amdgpu: 32053M of GTT memory ready.
Sep 01 15:09:48 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 0 exp: 80000000
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: STB initialized to 2048 entries
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Loading DMUB firmware via PSP: version=0x02020020
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Found VCN firmware Version ENC: 1.33 DEC: 4 VEP: 0 Revision: 8
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: reserve 0xa00000 from 0x827d000000 for PSP TMR
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000000e, smu fw if version = 0x00000012, smu fw program = 0, version = 0x00413e00 (65.62.0)
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: use vbios provided pptable
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Display Core v3.2.334 initialized on DCN 3.0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] DP-HDMI FRL PCON supported
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x02020020
Sep 01 15:09:49 acefour-1 kernel: snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Sep 01 15:09:49 acefour-1 kernel: amdgpu: HMM registered 10224MB device memory
Sep 01 15:09:49 acefour-1 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Sep 01 15:09:49 acefour-1 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Sep 01 15:09:49 acefour-1 kernel: amdgpu: Virtual CRAT table created for GPU
Sep 01 15:09:49 acefour-1 kernel: amdgpu: Topology: Add dGPU node [0x73df:0x1002]
Sep 01 15:09:49 acefour-1 kernel: kfd kfd: amdgpu: added device 1002:73df
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: SE 2, SH per SE 2, CU per SH 10, active_cu_number 36
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 14 on hub 0
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Using BACO for runtime pm
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: [drm] Registered 6 planes with drm panic
Sep 01 15:09:49 acefour-1 kernel: [drm] Initialized amdgpu 3.64.0 for 0000:03:00.0 on minor 1
Sep 01 15:09:49 acefour-1 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Sep 01 15:09:49 acefour-1 kernel: amdgpu 0000:03:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.1.0 timeout, signaled seq=119790, emitted seq=119792
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Process information: process kwin_wayland pid 1156 thread kwin_wayla:cs0 pid 1203
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.1.0 ring reset
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.1.0 reset failed
Sep 01 15:31:46 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
Sep 01 15:31:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
Sep 01 15:31:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
Sep 01 15:31:47 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
Sep 01 15:31:58 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset succeeded, trying to resume
Sep 01 15:31:58 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
Sep 01 15:31:58 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 15:31:59 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 15:32:00 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 15:32:01 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 15:32:01 acefour-1 plasmashell[1439]: amdgpu: The CS has cancelled because the context is lost. This context is innocent.
Sep 01 15:32:02 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 15:32:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: psp reg (0x16063) wait timed out, mask: 80000000, read: 200000 exp: 80000000
Sep 01 15:32:03 acefour-1 kernel: [drm:psp_v11_0_memory_training [amdgpu]] *ERROR* send training msg failed.
Sep 01 15:32:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Failed to process memory training!
Sep 01 15:32:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: resume of IP block <psp> failed -62
Sep 01 15:32:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset end with ret = -62
Sep 01 15:32:03 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU Recovery Failed: -62
Sep 01 15:32:13 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Sep 01 15:32:14 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Sep 01 15:32:14 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Sep 01 15:32:14 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Sep 01 15:32:14 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.1.0 timeout, signaled seq=119792, emitted seq=119792
Sep 01 15:32:14 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Process information: process kwin_wayland pid 1156 thread kwin_wayla:cs0 pid 1203
Sep 01 15:32:14 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.1.0 ring reset
Sep 01 15:32:14 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.1.0 reset failed
Sep 01 15:32:14 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
This has been reported on CachyOS as well.
I would try https://aur.archlinux.org/packages/linux-amd-git but when you makepkg it errors our cloning the repo from freedesktop. Apparently they are having issues too.
Have you looked in the BIOS under security advanced to see if you can disable PSP?
