Here is @sandman screen grab from the 2021 Discovery post on AKM.
Now here is mine, I can’t scroll to the botton to get to the buttons, nor can I move the contents by resizing the window. I can however, tab down through the checkboxes, but it does not display the cancel or execute buttons, so there is no way to know if I am on it when I hit enter.
btw, I am on Gnome 43
Thankyou for the correction @pebcak
Here’s what it look like here (on Xfce):
Everything seems to work as well.
Do you have a Gnome 43 spun up to test it?
It’s fine on my end on GNOME 43
My currently running kernel is:
uname -r
6.0.7-zen1-1-zen
but it is not marked with a * (see the picture in the previous post).
What are the terminal commands to set zen as default?
I use grub-btrfs si it’s added to the grub splash menu.
It was a long time ago that I used grub-btrfs so I don’t quite remember how it handles setting up the Grub boot menu. If it uses the /etc/default/grub so have a look at this thread:
Edit /etc/default/grub, set GRUB_DEFAULT to the ordinal number for zen.
You may need to set also GRUB_DISABLE_SUBMENU=y.
BTW, what does these commands show you:
cat /proc/cmdline
inxi -Saz
In Plasma there are some windows that doesn’t fit the screen on resolutions lower or equal than 768px height. But you can move the window by pressing ALT and drag the mouse. I guess it’ll work on Gnome too.
BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=068e39a0-d042-44a0-a576-43603368da7e rw rootflags=subvol=@ resume=UUID=3cf15e8d-b58b-4fde-9523-2709b9b223c5 loglevel=3 nowatchdog nvme_load=YES
Kernel: 5.15.76-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
nvme_load=YES
Desktop: GNOME v: 43.0 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
It’s an Arch install using BTRFS and systemd-boot with EnOS’ repo enabled:
cat /proc/cmdline
initrd=\arch-gnome\intel-ucode.img initrd=\arch-gnome\initramfs-linux-zen.img rw root=UUID=1d9646ea-0edf-423b-85a7-88a429c6314b rootflags=subvol=@arch-gnome-root resume=UUID=204b749a-eb7e-4b61-850e-f7a82da8c988 lsm=landlock,lockdown,yama,integrity,apparmor,bpf nowatchdog zswap.enabled=0 ipv6.disable_ipv6=1
inxi -Saz
Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: initrd=\arch-gnome\intel-ucode.img
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Distro: Arch Linux
Thanks guys!
I’ll check this as soon as possible this weekend.
Maybe this will help…
inxi -FAZ
Host: eos-22 Kernel: 5.15.76-1-lts arch: x86_64 bits: 64 Desktop: GNOME
v: 43.0 Distro: EndeavourOS
Type: Laptop System: Acer product: Aspire ES1-571 v: V1.00
serial: <superuser required>
Mobo: Acer model: Aspire ES1-571 v: V1.00 serial: <superuser required>
UEFI: Insyde v: 1.00 date: 01/04/2016
Info: dual core model: Intel Core i3-5005U bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 1595 min/max: 500/1900 cores: 1: 1596 2: 1596 3: 1596
4: 1594
Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
Device-2: Realtek Acer 640 × 480 laptop camera type: USB driver: uvcvideo
Display: wayland server: X.Org v: 22.1.5 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: gpu: i915 resolution: 1366x768~60Hz
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2)
Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio
Sound API: ALSA v: k5.15.76-1-lts running: yes
Sound Server-1: PipeWire v: 0.3.59 running: yes
driver: r8169
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: 30:65:ec:99:91:e5
Device-2: Broadcom BCM43142 802.11b/g/n driver: wl
IF: wlan0 state: down mac: b6:59:be:58:55:94
Bluetooth:
Device-1: Lite-On BCM43142A0 type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: disabled
Local Storage: total: 494.88 GiB used: 85.75 GiB (17.3%)
ID-1: /dev/sda vendor: Hitachi model: HTS547550A9E384 size: 465.76 GiB
ID-2: /dev/sdc type: USB vendor: SanDisk model: Cruzer Glide
ID-1: / size: 456.66 GiB used: 78.67 GiB (17.2%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 608 KiB (0.2%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 456.66 GiB used: 78.67 GiB (17.2%) fs: btrfs
dev: /dev/sda2
ID-4: /var/log size: 456.66 GiB used: 78.67 GiB (17.2%) fs: btrfs
dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.8 GiB used: 1.2 GiB (13.7%)
dev: /dev/sda3
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 327 Uptime: 10h 46m Memory: 7.68 GiB used: 6.28 GiB (81.7%)
Shell: Bash inxi: 3.3.23
Yad has some problems with wayland, maybe that causes your issue.
Does it work better with xorg?
This is in xorg. As you can see I can resize the window width, so I managed to check the zen kernel and headers, and then I went by your screen and tabbed 4 times and hit enter and I seem to have been on the execute button, so it installed zen. I cannot resize the height, so I cannot see the buttons.
In my case, I usually use two finger scroll, but the content does not scroll.
I will soon release a new version of akm. It should fix showing the currently running kernel. Not sure if it affects the other problem though, because so far I haven’t been able to reproduce it here.
What tests can I run for you that may help to identify the cause?
I am back on Wayland and won’t need AKM for now I have zen kernel as default.
Someone else must be seeing this, even though my Gnome setup is heavily customized, so let me know.
