Hello,
my screen is right now in very low resolution in KDE. After an update I see the following problems in kernel log and don’t have a clue how to fix this.
Hope someone can help.
Jul 09 16:47:06 ixidion-eos kernel: [drm] amdgpu kernel modesetting enabled.
Jul 09 16:47:06 ixidion-eos kernel: amdgpu: Virtual CRAT table created for CPU
Jul 09 16:47:06 ixidion-eos kernel: amdgpu: Topology: Add CPU node
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: enabling device (0006 -> 0007)
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 0 <nv_common>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 1 <gmc_v10_0>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 2 <navi10_ih>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 3 <psp>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 4 <smu>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 5 <dm>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 6 <gfx_v10_0>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 7 <sdma_v5_2>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 8 <vcn_v3_0>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: detected ip block number 9 <jpeg_v3_0>
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: Fetched VBIOS from VFCT
Jul 09 16:47:06 ixidion-eos kernel: amdgpu: ATOM BIOS: 113-V399MECH-1OC
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: Direct firmware load for amdgpu/navy_flounder_sos.bin failed with error -2
Jul 09 16:47:06 ixidion-eos kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* early_init of IP block <psp> failed -19
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: Direct firmware load for amdgpu/navy_flounder_smc.bin failed with error -2
Jul 09 16:47:06 ixidion-eos kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* early_init of IP block <smu> failed -19
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: Direct firmware load for amdgpu/navy_flounder_dmcub.bin failed with error -2
Jul 09 16:47:06 ixidion-eos kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* early_init of IP block <dm> failed -19
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: Direct firmware load for amdgpu/navy_flounder_pfp.bin failed with error -2
Jul 09 16:47:06 ixidion-eos kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* early_init of IP block <gfx_v10_0> failed -19
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: Direct firmware load for amdgpu/navy_flounder_sdma.bin failed with error -2
Jul 09 16:47:06 ixidion-eos kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* early_init of IP block <sdma_v5_2> failed -19
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: Direct firmware load for amdgpu/navy_flounder_vcn.bin failed with error -2
Jul 09 16:47:06 ixidion-eos kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* early_init of IP block <vcn_v3_0> failed -19
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: Fatal error during GPU init
Jul 09 16:47:06 ixidion-eos kernel: amdgpu 0000:2b:00.0: amdgpu: amdgpu: finishing device.
