I know it’s no biggie but it has been bugging me for a while now. In the panel selection there is a purple tint behind the icons when I mouse over, and -sorry for swearing in church - I’m not I very purple guy, and it goes badly with the rest of my theming. I have looked everywhere [most probably not] in settings but I don’t seem to be able to find how to change that.
Anyone who knows how to solve this extremely important issue?
Start by posting a screenshot
My brain’s iGPU isn’t working right now , can’t imagine
Here is a “screenphoto” as screenshoot doesn’t work in that menu.
I’m referring to the purple behind the icon and “senaste program”.
Go into system settings and see if changing the colors option changes that. I am not at my machine to look but you may be able to change just that color.
Yeah, it should be in colors, but i think it’s based on common Selection background or something like that, so you can’t individually change it
Now i tried i few different, but it doesn’t matter. It stays purple.
Did you reboot? Or log out and back in after the change?
Settings > Appearance > Colors
Click on edit icon of your color set . Then you will see many options under Colors . One of them will solve this . Give these a try Hover Decoration , Selection Bckground
Reboot shouldn’t be necessary with modern KDE though, at least it wasn’t month ago, they’ve made live-apply
Thanks, that was a feature that was good to know. Unfortunately, it didn’t work for the one thing I really wanted to change.
I now, but I did just in case.
One far fetched thought, as Xfce is themed and Plasma supposedly isn’t, but can this be an exception from that rule?
Oh i forgot to mention that your Plasma style must have Follows color scheme under it’s name to actually follow color changes
Sorry, KDE is a mess of settings
Try changing the Plasma theme, some hard code the colors in the SVG files rather than inherit it from the color theme.
…and that did the trick!
Thanks!
I know. The hours I’ve spent searching the settings when I was new to Plasma… and still does, obviously.
…and thanks to klorax too, as he also was right, but I needed that “Follows color scheme”, so solution goes to keybreak.
I just found out I can customize my Plasma style
because of keybreak mentioning it . Thanks @keybreak
