Not sure if this should be officially “Solution checked” or if this is just left as is until the next kernel update for verification?
Good question!
Actually there are probably many threads out there (on many forums) that are just waiting for some upstream or external solution.
So its your choice.
Well, with 5.10.7 Xorg stops crashing at login but the YAD window still appears. So sticking with the LTS for now, it seems something doesn’t like something on my computer.
Is it so that the small yad window appears at login for a very short time and then disappears?
Yep, it closes by itself.
Do you have anything in this folder:
ls -la ~/.cache/sessions
bgeek @ ~
total 8
drwxrwxr-x 1 bgeek bgeek 174 14 jan 17.04 ./
drwxrwxr-x 1 bgeek bgeek 340 13 jan 18.06 ../
drwxrwxr-x 1 bgeek bgeek 22 11 jan 09.12 thumbs-endeavour-xfce:0/
-rw-rw-r-- 1 bgeek bgeek 2756 11 jan 09.21 xfce4-session-endeavour-xfce:0
-rw-rw-r-- 1 bgeek bgeek 2655 11 jan 09.12 xfce4-session-endeavour-xfce:0.bak
You could delete those files (xfce4-session-*) and see what happens after re-login…
I have nothing in that folder.
INTERESTING. Yes the message disappeared.
Now the only question is why the frakk did the saved sessions get there to begin with since I never had that checkbox well… checked, and why did the message disappear when I switched to the LTS.
(Interesting trivia: The 5.10.6 kernel seemed to boot noticeable quicker than the 5.4 lts, BUT the 5.10.7 does not. Not sure what that means).
So… the yad window does no more appear?
Exactly. Emptying the
~/.cache/sessions
folder solved it. (Formatting this nicely for an easy to find “solution” checkbox
Moving this to the Xfce forum since it seems to be an Xfce specific problem.
I don’t really know the insider stuff of xfce4, but as far as I know, the only way to have those session files there is by using the session save feature.
And the time stamps are quite recent…
But I recommend to check a couple of times after rebooting if the files still exist there.
Just did two reboots with 3 min waiting in between. Seems to hold up now. Thanks for the assistance, as usual.
@anon53396576 laugh as much as you want
The fact that the message did not show up when switching to the LTS despite not emptying the sessions folder is still weird.
Sorry wasn’t laughing at that. I find it amusing that you have the inexplicable habit of self solving posts
Actually I didn’t, this time
I just made a well formatted post that’s easy to find for the Solution checkbox.
Edit: And no, I did not mean to mark your post as a solution
Stumbling on the mouse button
I removed it…
Hi! Just wanted to let you know that this issue seems to be back on KDE. I have installed EndeavourOS on my PC about half a year ago. After it was upgraded to Ganymede I stared to see that YAD-popup. I do have session saving enabled and welcome screen displayed at start.
Some technical details:
Operating System: EndeavourOS
KDE Plasma Version: 6.5.4
KDE Frameworks Version: 6.21.0
Qt Version: 6.10.1
Kernel Version: 6.18.3-arch1-1 (64-bit)
Graphics Platform: Wayland
Hello @pilkjaer and welcome to the
forum. It’s great that you’re participating, but this topic is five years old. Please start a new one with your specific problem.
