In the command line I can start the cinnamon desktop with “cinnamon-session” that works but I dont want to type that command every time I logged in and have an open command that command that I can not close.
my .xinitrc in my home directory looks like:
#!/bin/sh
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
sysresources=/etc/X11/xinit/.Xresources
sysmodmap=/etc/X11/xinit/.Xmodmap
# merge in defaults and keymaps
if [ -f $sysresources ]; then
xrdb -merge $sysresources
fi
if [ -f $sysmodmap ]; then
xmodmap $sysmodmap
fi
if [ -f "$userresources" ]; then
xrdb -merge "$userresources"
fi
if [ -f "$usermodmap" ]; then
xmodmap "$usermodmap"
fi
# start some nice programs
if [ -d /etc/X11/xinit/xinitrc.d ] ; then
for f in /etc/X11/xinit/xinitrc.d/?*.sh ; do
[ -x "$f" ] && . "$f"
done
unset f
fi
twm &
xclock -geometry 50x50-1+1 &
xterm -geometry 80x50+494+51 &
xterm -geometry 80x20+494-0 &
exec xterm -geometry 80x66+0+0 -name login
exec cinnamon-session
#dbus-launch --exit-with-session
but to start cinnamon in the .xinitrc does not work.
So anybody any idea?
#!/bin/sh
fi
xmodmap $sysmodmap
fi
fi
fi
done
unset f
fi
twm &
xterm -geometry 80x66+0+0 -name login &
but nothing changed. The same three white command lines. Of course I checked if the .xinitrc files is used so I comment the last lines and then I only get a black screen so the file is used correct.
For educational reason, those things are instances of the xterm terminal emulator.
Since you actually want to start a cinnamon session, you can try that.
Delete the other lines (twm, xclock, xterm) and leave only the exec line.
If it also fails, you might want to try a Display Manager, unless you are willing to learn how to troubleshoot (reading manuals and wiki articles).
