Xrandr: Configure crtc 4 failed when attempting to use second monitor
Greetings,
I recently installed EndeavourOS on a HP Omen en0xxx gaming laptop with a nvidia 1660ti mobile with KDE, and I attempted to use xrandr to enable my second monitor since it isn’t showing up on the gui, and got the error: “xrandr: Configure crtc 4 failed” when running xrandr --auto, since at the time it the second monitor showed up when running xrandr. I found this forum post and installed optimus-manager and switched to hybrid. After that KDE no longer detected the second monitor. I attempted to use xrandr to add a mode for my second monitor following the steps here, but after attempting to do the switch I got the same error message again. This is a fresh install of endeavouros and I do not know what is going wrong. I would appreciate any help.
lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
Subsystem: Hewlett-Packard Company Device 8786
lspci: Unable to load libkmod resources: error -2
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1453
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Subsystem: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller
Kernel driver in use: piix4_smbus
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
Kernel driver in use: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1)
DeviceName: NVIDIA Graphics Device
Kernel driver in use: nouveau
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
01:00.2 USB controller: NVIDIA Corporation TU116 USB 3.1 Host Controller (rev a1)
Kernel driver in use: xhci_hcd
01:00.3 Serial bus controller: NVIDIA Corporation TU116 USB Type-C UCSI Controller (rev a1)
Kernel driver in use: nvidia-gpu
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
DeviceName: OnBoard Enthernets
Kernel driver in use: r8169
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
DeviceName: Intel Wireless LAN + BT
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
Kernel driver in use: iwlwifi
04:00.0 SD Host controller: Genesys Logic, Inc GL9750 SD Host Controller (rev 01)
DeviceName: Realtek PCIE CardReader
Kernel driver in use: sdhci-pci
05:00.0 Non-Volatile memory controller: Sandisk Corp WD Blue SN550 NVMe SSD (rev 01)
Subsystem: Sandisk Corp WD Blue SN550 NVMe SSD
Kernel driver in use: nvme
06:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Subsystem: Samsung Electronics Co Ltd SSD 970 EVO
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c6)
DeviceName: Onboard IGD
Kernel driver in use: amdgpu
07:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Kernel driver in use: ccp
07:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
07:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
07:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
Kernel driver in use: snd_rn_pci_acp3x
07:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
08:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
Kernel driver in use: ahci
08:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
xrandr --verbose
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (0x44) normal (normal left inverted right x axis y axis) 344mm x 194mm
Identifier: 0x42
Timestamp: 2026239
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0009e5df0800000000
251d0104a52213780754a5a7544c9b26
0f505400000001010101010101010101
010101010101988980a0703860403020
360058c21000001a0000000000000000
00000000000000000000000000fe0042
4f452043510a202020202020000000fe
004e5631353646484d2d4e59340a00fd
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
vrr_capable: 0
range: (0, 1)
abm level: 0
range: (0, 4)
max bpc: 16
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
supported: off, on, auto
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CONNECTOR_ID: 78
supported: 78
non-desktop: 0
range: (0, 1)
1920x1080 (0x44) 352.240MHz +HSync -VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 1080 start 1083 end 1089 total 1176 clock 144.00Hz
1920x1080 (0x45) 356.375MHz -HSync +VSync DoubleScan
h: width 1920 start 2080 end 2288 total 2656 skew 0 clock 134.18KHz
v: height 1080 start 1081 end 1084 total 1118 clock 60.01Hz
1920x1080 (0x46) 266.500MHz +HSync -VSync DoubleScan
h: width 1920 start 1944 end 1960 total 2000 skew 0 clock 133.25KHz
v: height 1080 start 1081 end 1084 total 1111 clock 59.97Hz
1920x1080 (0x47) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1920x1080 (0x48) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1680x1050 (0x49) 352.240MHz +HSync -VSync
h: width 1680 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 1050 start 1083 end 1089 total 1176 clock 144.00Hz
1680x1050 (0x4a) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1680x1050 (0x4b) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1400x1050 (0x4c) 155.800MHz +HSync +VSync
h: width 1400 start 1464 end 1784 total 1912 skew 0 clock 81.49KHz
v: height 1050 start 1052 end 1064 total 1090 clock 74.76Hz
1400x1050 (0x4d) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1600x900 (0x4e) 246.000MHz -HSync +VSync DoubleScan
h: width 1600 start 1728 end 1900 total 2200 skew 0 clock 111.82KHz
v: height 900 start 901 end 904 total 932 clock 59.99Hz
1600x900 (0x4f) 186.500MHz +HSync -VSync DoubleScan
h: width 1600 start 1624 end 1640 total 1680 skew 0 clock 111.01KHz
v: height 900 start 901 end 904 total 926 clock 59.94Hz
1600x900 (0x50) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x51) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1280x1024 (0x52) 352.240MHz +HSync -VSync
h: width 1280 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 1024 start 1083 end 1089 total 1176 clock 144.00Hz
1280x1024 (0x53) 157.500MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 91.15KHz
v: height 1024 start 1025 end 1028 total 1072 clock 85.02Hz
1280x1024 (0x54) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x55) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x56) 352.240MHz +HSync -VSync
h: width 1440 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 900 start 1083 end 1089 total 1176 clock 144.00Hz
1400x900 (0x57) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x58) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1280x960 (0x59) 148.500MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 85.94KHz
v: height 960 start 961 end 964 total 1011 clock 85.00Hz
1280x960 (0x5a) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1440x810 (0x5b) 198.125MHz -HSync +VSync DoubleScan
h: width 1440 start 1548 end 1704 total 1968 skew 0 clock 100.67KHz
v: height 810 start 811 end 814 total 839 clock 60.00Hz
1440x810 (0x5c) 151.875MHz +HSync -VSync DoubleScan
h: width 1440 start 1464 end 1480 total 1520 skew 0 clock 99.92KHz
v: height 810 start 811 end 814 total 833 clock 59.97Hz
1368x768 (0x5d) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x5e) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1280x800 (0x5f) 352.240MHz +HSync -VSync
v: height 800 start 1083 end 1089 total 1176 clock 144.00Hz
1280x800 (0x60) 174.250MHz -HSync +VSync DoubleScan
h: width 1280 start 1380 end 1516 total 1752 skew 0 clock 99.46KHz
v: height 800 start 801 end 804 total 829 clock 59.99Hz
1280x800 (0x61) 134.250MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 98.71KHz
v: height 800 start 801 end 804 total 823 clock 59.97Hz
1280x800 (0x62) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x800 (0x63) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1152x864 (0x64) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x65) 352.240MHz +HSync -VSync
v: height 720 start 1083 end 1089 total 1176 clock 144.00Hz
1280x720 (0x66) 156.125MHz -HSync +VSync DoubleScan
h: width 1280 start 1376 end 1512 total 1744 skew 0 clock 89.52KHz
v: height 720 start 721 end 724 total 746 clock 60.00Hz
1280x720 (0x67) 120.750MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 88.79KHz
v: height 720 start 721 end 724 total 740 clock 59.99Hz
1280x720 (0x68) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x69) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1024x768 (0x6a) 352.240MHz +HSync -VSync
h: width 1024 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 768 start 1083 end 1089 total 1176 clock 144.00Hz
1024x768 (0x6b) 194.020MHz -HSync +VSync DoubleScan
h: width 1024 start 1108 end 1220 total 1416 skew 0 clock 137.02KHz
v: height 768 start 768 end 770 total 806 clock 85.00Hz
1024x768 (0x6c) 170.240MHz -HSync +VSync DoubleScan
h: width 1024 start 1108 end 1220 total 1416 skew 0 clock 120.23KHz
v: height 768 start 768 end 770 total 801 clock 75.05Hz
1024x768 (0x6d) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x6e) 94.500MHz +HSync +VSync
h: width 1024 start 1072 end 1168 total 1376 skew 0 clock 68.68KHz
v: height 768 start 769 end 772 total 808 clock 85.00Hz
1024x768 (0x6f) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x70) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x71) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1024x768i (0x72) 44.900MHz +HSync +VSync Interlace
h: width 1024 start 1032 end 1208 total 1264 skew 0 clock 35.52KHz
v: height 768 start 768 end 776 total 817 clock 86.96Hz
960x720 (0x73) 170.675MHz -HSync +VSync DoubleScan
h: width 960 start 1036 end 1144 total 1328 skew 0 clock 128.52KHz
v: height 720 start 720 end 722 total 756 clock 85.00Hz
960x720 (0x74) 148.500MHz -HSync +VSync DoubleScan
h: width 960 start 1032 end 1144 total 1320 skew 0 clock 112.50KHz
v: height 720 start 720 end 722 total 750 clock 75.00Hz
960x720 (0x75) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x76) 144.000MHz -HSync +VSync DoubleScan
h: width 928 start 992 end 1104 total 1280 skew 0 clock 112.50KHz
v: height 696 start 696 end 698 total 750 clock 75.00Hz
928x696 (0x77) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x78) 130.500MHz -HSync +VSync DoubleScan
h: width 896 start 944 end 1052 total 1228 skew 0 clock 106.27KHz
v: height 672 start 672 end 674 total 708 clock 75.05Hz
896x672 (0x79) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
1024x576 (0x7a) 98.500MHz -HSync +VSync DoubleScan
h: width 1024 start 1092 end 1200 total 1376 skew 0 clock 71.58KHz
v: height 576 start 577 end 580 total 597 clock 59.95Hz
1024x576 (0x7b) 78.375MHz +HSync -VSync DoubleScan
h: width 1024 start 1048 end 1064 total 1104 skew 0 clock 70.99KHz
v: height 576 start 577 end 580 total 592 clock 59.96Hz
1024x576 (0x7c) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0x7d) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x600 (0x7e) 96.625MHz -HSync +VSync DoubleScan
h: width 960 start 1028 end 1128 total 1296 skew 0 clock 74.56KHz
v: height 600 start 601 end 604 total 622 clock 59.93Hz
960x600 (0x7f) 77.000MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 74.04KHz
v: height 600 start 601 end 604 total 617 clock 60.00Hz
832x624 (0x80) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
960x540 (0x81) 86.500MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1124 total 1288 skew 0 clock 67.16KHz
v: height 540 start 541 end 544 total 560 clock 59.96Hz
960x540 (0x82) 69.250MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 66.59KHz
v: height 540 start 541 end 544 total 555 clock 59.99Hz
960x540 (0x83) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
960x540 (0x84) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
800x600 (0x85) 352.240MHz +HSync -VSync
h: width 800 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 600 start 1083 end 1089 total 1176 clock 144.00Hz
800x600 (0x86) 114.750MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 106.25KHz
v: height 600 start 600 end 602 total 625 clock 85.00Hz
800x600 (0x87) 101.250MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 93.75KHz
v: height 600 start 600 end 602 total 625 clock 75.00Hz
800x600 (0x88) 94.500MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 87.50KHz
v: height 600 start 600 end 602 total 625 clock 70.00Hz
800x600 (0x89) 87.750MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 81.25KHz
v: height 600 start 600 end 602 total 625 clock 65.00Hz
800x600 (0x8a) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0x8b) 56.300MHz +HSync +VSync
h: width 800 start 832 end 896 total 1048 skew 0 clock 53.72KHz
v: height 600 start 601 end 604 total 631 clock 85.14Hz
800x600 (0x8c) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x8d) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x8e) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x8f) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
840x525 (0x90) 73.125MHz -HSync +VSync DoubleScan
h: width 840 start 892 end 980 total 1120 skew 0 clock 65.29KHz
v: height 525 start 526 end 529 total 544 clock 60.01Hz
840x525 (0x91) 59.500MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.67KHz
v: height 525 start 526 end 529 total 540 clock 59.88Hz
864x486 (0x92) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0x93) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
700x525 (0x94) 77.900MHz +HSync +VSync DoubleScan
h: width 700 start 732 end 892 total 956 skew 0 clock 81.49KHz
v: height 525 start 526 end 532 total 545 clock 74.76Hz
700x525 (0x95) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
800x450 (0x96) 59.125MHz -HSync +VSync DoubleScan
h: width 800 start 848 end 928 total 1056 skew 0 clock 55.99KHz
v: height 450 start 451 end 454 total 467 clock 59.95Hz
800x450 (0x97) 48.750MHz +HSync -VSync DoubleScan
h: width 800 start 824 end 840 total 880 skew 0 clock 55.40KHz
v: height 450 start 451 end 454 total 463 clock 59.82Hz
640x512 (0x98) 78.750MHz +HSync +VSync DoubleScan
h: width 640 start 672 end 752 total 864 skew 0 clock 91.15KHz
v: height 512 start 512 end 514 total 536 clock 85.02Hz
640x512 (0x99) 67.500MHz +HSync +VSync DoubleScan
h: width 640 start 648 end 720 total 844 skew 0 clock 79.98KHz
v: height 512 start 512 end 514 total 533 clock 75.02Hz
640x512 (0x9a) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
700x450 (0x9b) 51.750MHz -HSync +VSync DoubleScan
h: width 700 start 740 end 812 total 924 skew 0 clock 56.01KHz
v: height 450 start 451 end 456 total 467 clock 59.96Hz
700x450 (0x9c) 43.250MHz +HSync -VSync DoubleScan
h: width 700 start 724 end 740 total 780 skew 0 clock 55.45KHz
v: height 450 start 451 end 456 total 463 clock 59.88Hz
640x480 (0x9d) 352.240MHz +HSync -VSync
h: width 640 start 1968 end 2000 total 2080 skew 0 clock 169.35KHz
v: height 480 start 1083 end 1089 total 1176 clock 144.00Hz
640x480 (0x9e) 74.250MHz +HSync +VSync DoubleScan
h: width 640 start 672 end 752 total 864 skew 0 clock 85.94KHz
v: height 480 start 480 end 482 total 505 clock 85.09Hz
640x480 (0x9f) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0xa0) 36.000MHz -HSync -VSync
h: width 640 start 696 end 752 total 832 skew 0 clock 43.27KHz
v: height 480 start 481 end 484 total 509 clock 85.01Hz
640x480 (0xa1) 31.500MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.86KHz
v: height 480 start 489 end 492 total 520 clock 72.81Hz
640x480 (0xa2) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0xa3) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x405 (0xa4) 22.500MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 422 clock 59.51Hz
720x405 (0xa5) 21.750MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 24.72KHz
v: height 405 start 408 end 413 total 419 clock 58.99Hz
720x400 (0xa6) 35.500MHz -HSync +VSync
h: width 720 start 756 end 828 total 936 skew 0 clock 37.93KHz
v: height 400 start 401 end 404 total 446 clock 85.04Hz
684x384 (0xa7) 42.625MHz -HSync +VSync DoubleScan
h: width 684 start 720 end 788 total 892 skew 0 clock 47.79KHz
v: height 384 start 385 end 390 total 399 clock 59.88Hz
684x384 (0xa8) 36.125MHz +HSync -VSync DoubleScan
h: width 684 start 708 end 724 total 764 skew 0 clock 47.28KHz
v: height 384 start 385 end 390 total 395 clock 59.85Hz
640x400 (0xa9) 41.750MHz -HSync +VSync DoubleScan
h: width 640 start 676 end 740 total 840 skew 0 clock 49.70KHz
v: height 400 start 401 end 404 total 415 clock 59.88Hz
640x400 (0xaa) 35.500MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 49.31KHz
v: height 400 start 401 end 404 total 411 clock 59.98Hz
640x400 (0xab) 31.500MHz -HSync +VSync
h: width 640 start 672 end 736 total 832 skew 0 clock 37.86KHz
v: height 400 start 401 end 404 total 445 clock 85.08Hz
576x432 (0xac) 54.000MHz +HSync +VSync DoubleScan
h: width 576 start 608 end 672 total 800 skew 0 clock 67.50KHz
v: height 432 start 432 end 434 total 450 clock 75.00Hz
640x360 (0xad) 37.250MHz -HSync +VSync DoubleScan
h: width 640 start 672 end 736 total 832 skew 0 clock 44.77KHz
v: height 360 start 361 end 364 total 374 clock 59.86Hz
640x360 (0xae) 31.875MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 44.27KHz
v: height 360 start 361 end 364 total 370 clock 59.83Hz
640x360 (0xaf) 18.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 22.50KHz
v: height 360 start 363 end 368 total 376 clock 59.84Hz
640x360 (0xb0) 17.750MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.19KHz
v: height 360 start 363 end 368 total 374 clock 59.32Hz
640x350 (0xb1) 31.500MHz +HSync -VSync
v: height 350 start 382 end 385 total 445 clock 85.08Hz
512x384 (0xb2) 47.250MHz +HSync +VSync DoubleScan
h: width 512 start 536 end 584 total 688 skew 0 clock 68.68KHz
v: height 384 start 384 end 386 total 404 clock 85.00Hz
512x384 (0xb3) 39.375MHz +HSync +VSync DoubleScan
h: width 512 start 520 end 568 total 656 skew 0 clock 60.02KHz
v: height 384 start 384 end 386 total 400 clock 75.03Hz
512x384 (0xb4) 37.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 664 skew 0 clock 56.48KHz
v: height 384 start 385 end 388 total 403 clock 70.07Hz
512x384 (0xb5) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
512x384i (0xb6) 22.450MHz +HSync +VSync Interlace DoubleScan
h: width 512 start 516 end 604 total 632 skew 0 clock 35.52KHz
v: height 384 start 384 end 388 total 408 clock 87.06Hz
512x288 (0xb7) 23.250MHz -HSync +VSync DoubleScan
h: width 512 start 532 end 580 total 648 skew 0 clock 35.88KHz
v: height 288 start 289 end 292 total 299 clock 60.00Hz
512x288 (0xb8) 21.000MHz +HSync -VSync DoubleScan
h: width 512 start 536 end 552 total 592 skew 0 clock 35.47KHz
v: height 288 start 289 end 292 total 296 clock 59.92Hz
416x312 (0xb9) 28.642MHz -HSync -VSync DoubleScan
h: width 416 start 432 end 464 total 576 skew 0 clock 49.73KHz
v: height 312 start 312 end 314 total 333 clock 74.66Hz
480x270 (0xba) 20.375MHz -HSync +VSync DoubleScan
h: width 480 start 496 end 544 total 608 skew 0 clock 33.51KHz
v: height 270 start 271 end 274 total 281 clock 59.63Hz
480x270 (0xbb) 18.625MHz +HSync -VSync DoubleScan
h: width 480 start 504 end 520 total 560 skew 0 clock 33.26KHz
v: height 270 start 271 end 274 total 278 clock 59.82Hz
400x300 (0xbc) 28.150MHz +HSync +VSync DoubleScan
h: width 400 start 416 end 448 total 524 skew 0 clock 53.72KHz
v: height 300 start 300 end 302 total 315 clock 85.27Hz
400x300 (0xbd) 25.000MHz +HSync +VSync DoubleScan
h: width 400 start 428 end 488 total 520 skew 0 clock 48.08KHz
v: height 300 start 318 end 321 total 333 clock 72.19Hz
400x300 (0xbe) 24.750MHz +HSync +VSync DoubleScan
h: width 400 start 408 end 448 total 528 skew 0 clock 46.88KHz
v: height 300 start 300 end 302 total 312 clock 75.12Hz
400x300 (0xbf) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0xc0) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
432x243 (0xc1) 16.250MHz -HSync +VSync DoubleScan
h: width 432 start 444 end 484 total 536 skew 0 clock 30.32KHz
v: height 243 start 244 end 247 total 253 clock 59.92Hz
432x243 (0xc2) 15.250MHz +HSync -VSync DoubleScan
h: width 432 start 456 end 472 total 512 skew 0 clock 29.79KHz
v: height 243 start 244 end 247 total 250 clock 59.57Hz
320x240 (0xc3) 18.000MHz -HSync -VSync DoubleScan
h: width 320 start 348 end 376 total 416 skew 0 clock 43.27KHz
v: height 240 start 240 end 242 total 254 clock 85.18Hz
320x240 (0xc4) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 332 end 352 total 416 skew 0 clock 37.86KHz
v: height 240 start 244 end 246 total 260 clock 72.81Hz
320x240 (0xc5) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 360 total 420 skew 0 clock 37.50KHz
v: height 240 start 240 end 242 total 250 clock 75.00Hz
320x240 (0xc6) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
360x202 (0xc7) 11.250MHz -HSync +VSync DoubleScan
h: width 360 start 372 end 404 total 448 skew 0 clock 25.11KHz
v: height 202 start 204 end 206 total 211 clock 59.51Hz
360x202 (0xc8) 10.875MHz +HSync -VSync DoubleScan
h: width 360 start 384 end 400 total 440 skew 0 clock 24.72KHz
v: height 202 start 204 end 206 total 209 clock 59.13Hz
360x200 (0xc9) 17.750MHz -HSync +VSync DoubleScan
h: width 360 start 378 end 414 total 468 skew 0 clock 37.93KHz
v: height 200 start 200 end 202 total 223 clock 85.04Hz
320x200 (0xca) 15.750MHz -HSync +VSync DoubleScan
h: width 320 start 336 end 368 total 416 skew 0 clock 37.86KHz
v: height 200 start 200 end 202 total 222 clock 85.27Hz
320x180 (0xcb) 9.000MHz -HSync +VSync DoubleScan
h: width 320 start 332 end 360 total 400 skew 0 clock 22.50KHz
v: height 180 start 181 end 184 total 188 clock 59.84Hz
320x180 (0xcc) 8.875MHz +HSync -VSync DoubleScan
h: width 320 start 344 end 360 total 400 skew 0 clock 22.19KHz
v: height 180 start 181 end 184 total 187 clock 59.32Hz
320x175 (0xcd) 15.750MHz +HSync -VSync DoubleScan
v: height 175 start 191 end 192 total 222 clock 85.27Hz
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x100
Timestamp: 2026239
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
PRIME Synchronization: 1
supported: 0, 1
dithering depth: auto
supported: auto, 6 bpc, 8 bpc
dithering mode: auto
supported: auto, off, static 2x2, dynamic 2x2, temporal
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
supported: auto, off, on
link-status: Good
0 1
CONNECTOR_ID: 101
supported: 101
non-desktop: 0
range: (0, 1)
1920x1080_60.00 (0x7a3) 173.000MHz -HSync +VSync
DP-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x101
Timestamp: 2026239
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
link-status: Good
0 1
CONNECTOR_ID: 103
supported: 103
non-desktop: 0
range: (0, 1)
DP-1-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x102
Timestamp: 2026239
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
link-status: Good
0 1
CONNECTOR_ID: 106
supported: 106
non-desktop: 0
range: (0, 1)
inxi -FAZ
Kernel: 6.1.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=9183dc03-b8d4-48c4-88e0-4659dda865a0 rw rootflags=subvol=@
nowatchdog nvme_load=YES resume=UUID=a3e8acf7-4262-49e2-bedf-737bf729e265
loglevel=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A
serial: Chassis: type: 10 serial:
Mobo: HP model: 8786 v: 22.25 serial: UEFI: AMI
v: F.01 date: 04/15/2020
Battery:
ID-1: BAT0 charge: 56.2 Wh (100.0%) condition: 56.2/56.2 Wh (100.0%)
volts: 12.7 min: 11.6 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: full cycles: 505
Memory:
RAM: total: 14.99 GiB used: 4.36 GiB (29.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1493 high: 2900 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 2900
3: 1400 4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400
12: 1400 13: 1400 14: 1400 15: 1397 16: 1400 bogomips: 92624
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Vulnerabilities:
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl
sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
driver: nouveau v: kernel alternate: nvidia_drm,nvidia non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none bus-ID: 07:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 40.0 C
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
type: USB driver: uvcvideo bus-ID: 3-3:2 chip-ID: 05c8:03df class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: radeonsi,nouveau gpu: amdgpu,nouveau
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
s-diag: 582mm (22.93")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.3-zen1-1-zen) direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.3-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.63 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: down mac:
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel modules: wl pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723
class-ID: 0280
IF: wlan0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
WAN IP:
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Local Storage: total: 2.75 TiB used: 6.63 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: WDBA3V0010BNC-WRSN size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 211210WD temp: 29.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: MZVLB1T0HBLR-000H1
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: rev: HPS0NEXF temp: 31.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Extreme 55AE
size: 931.48 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: rev: 3000 scheme: GPT
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
Message: No optical or floppy data found.
ID-1: / raw-size: 914.04 GiB size: 914.04 GiB (100.00%) used: 6.63 GiB (0.7%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: endeavouros
uuid: 9183dc03-b8d4-48c4-88e0-4659dda865a0
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 26E8-0162
ID-3: /home raw-size: 914.04 GiB size: 914.04 GiB (100.00%)
used: 6.63 GiB (0.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: endeavouros uuid: 9183dc03-b8d4-48c4-88e0-4659dda865a0
ID-4: /var/cache raw-size: 914.04 GiB size: 914.04 GiB (100.00%)
ID-5: /var/log raw-size: 914.04 GiB size: 914.04 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16.49 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: a3e8acf7-4262-49e2-bedf-737bf729e265
Unmounted:
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 57CB-CE88
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 937.01 GiB fs: btrfs label: N/A
uuid: 68a8ec22-f354-4803-9d37-38992aa7bc9c
ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 16.56 GiB fs: swap label: swap
uuid: 8fc6e39b-149e-4e2b-a555-ae6d6c647f56
ID-4: /dev/sda1 maj-min: 8:1 size: 931.48 GiB fs: exfat label: Extreme SSD
uuid: EC66-5ED8
USB:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05c8:03df class-ID: 0e02
Device-2: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0029
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: SanDisk Extreme 55AE type: Mass Storage driver: uas
interfaces: 1 rev: 3.2 speed: 10 Gb/s power: 896mA chip-ID: 0781:55ae
class-ID: 0806 serial:
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Primax HP Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0461:4d0f class-ID: 0301
Device-2: 5-2:3 info: Corsair K95 RGB PLATINUM XT Mechanical Gaming
Keyboard type: Keyboard,HID,Mouse driver: hid-generic,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b89 class-ID: 0301
serial:
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 60.1 C mobo: N/A
Fan Speeds (RPM): fan-1: 0 fan-2: 0
GPU: device: nouveau temp: N/A device: amdgpu temp: 39.0 C
Processes: 347 Uptime: 47m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1058
libs: 231 tools: paru,yay Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
Welcome to EndeavourOS. When I was setting up my openbox system I also could not get xrandr to see the other monitor, but arandr worked like a charm and I was able to set up two screens very easily. It may help you out
unfortunately arandr doesn’t seem to work either, it doesn’t detect the other hdmi output. In outputs it only shows the laptop screen.
I will tell you that I am not a Nvidia guy, so I am certainly not an expert on them.
I am not sure if the EndeavourOS Discovery Optimus Manager guide will be helpful.
https://discovery.endeavouros.com/nvidia/optimus-manager-for-nvidia/2021/03/
So prior to running xrandr the KDE GUI did not see the second monitor. Then you ran xrandr and the second monitor was there, but when you did Optimus Manager and hybrid caused KDE to lose the second monitor. Is that correct? The linked discovery article has some KDE settings for Optimus Manager. If you are not in hybrid, but in nvidia or integrated do you see the monitor?
Before installing optimus-manager, the kde gui did detect the detect the second monitor, it just wasn’t able to switch to it. Same thing with xrandr. I switched to hybrid and then both xrandr and kde lost the ability to detect the 2nd monitor through the hdmi port. When attempting to switch to nvidia, optimus said the nvidia driver wasn’t properly installed or something, though I attempted to use endeavouros’ nvidia driver installer. So I guess I will look into that as a possibility. For integrated, it still does not see the second monitor in xrandr, kde gui, or arandr.
Hi,
You seem to be using open source nvidia driver, but you also have proprietary driver which is not used
Also, this part is weird, X loaded the proprietary driver but dri is using the opensource one. So, indeed nvidia drivers are not installed correctly and something is messed up. I would recommend reinstalling/removing nvidia non-free drivers first.
This shows the igpu is in use only.
second display connector could be wired to the nvidia gpu ??
It is reported currently that zen kernel has issues with nvidia drivers…
i see nouveau driver (open-source) is in use not the propritary Nvidia driver.
And welcome @Nfox18212 at the purple side :enos:
/ moved this as it is not a BUG /
From xrandr manual:
–auto
For connected but disabled outputs, this will enable them using their first preferred mode (or, something close to 96dpi if they have no preferred mode). For disconnected but enabled outputs, this will disable them.
Secondly, @jake99 comments are really to the point :wink: :+1:
IMHO, if you want to troubleshoot this problem, you should uninstall optimus-manager and clean /etc/X11/xorg.conf.d/ folder (except from the keyboard conf file).
Also, if you need any help with this, you should post Xorg logs (at a web pastebin service) and post xrandr info (in code format, else it is really difficult to read them) here, after doing any tests.
that’s fine, i just didn’t know what else to flair this post other than a bug. thank you for your help.
okay so I am a little confused on the process of uninstalling any of the drivers since I attempted to install it through nvidia-inst instead of pacman, and when looking for any of the package names like nvidia it wasn’t there. So I tried removing it through dkms and I am still confused.
[root@YoRHa nfox]# dkms status
nvidia/525.78.01, 6.1.4-arch1-1, x86_64: installed
[root@YoRHa nfox]# dkms remove -m nvidia -v 525.78.01
Module nvidia 525.78.01 is not installed for kernel 6.1.4-zen2-1-zen (x86_64). Skipping...
Module nvidia 525.78.01 is not built for kernel 6.1.4-zen2-1-zen (x86_64). Skipping...
What am I doing wrong?
Hey, check the wiki about nvidia-inst https://discovery.endeavouros.com/nvidia/new-nvidia-driver-installer-nvidia-inst/2022/03/
If nvidia-inst is executed e.g. with option --nouveau, it will remove conflicting packages like the nvidia drivers, and then install the nouveau driver. A similar idea is used with all options that need to take care of conflicting packages and/or certain settings: conflicting stuff will be removed first, and then the new packages/settings will be installed.
Running nvidia-inst --nouveau should do what you need.
For other stuff @petsam gave you a good overview what you need to do.
Installing the novueau drivers did not seem to do the trick, and I did clear out /etc/X11/xorg.conf.d and I uninstalled optimus-manager. I also ran xrandr --listmonitors and the second monitor did not show up. Here is xrandr --verbose:
xrandr- --verbose
Identifier: 0x42
Timestamp: 7134
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
filter:
EDID:
vrr_capable: 0
range: (0, 1)
abm level: 0
range: (0, 4)
max bpc: 16
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
0 1
CONNECTOR_ID: 78
supported: 78
non-desktop: 0
range: (0, 1)
Identifier: 0x100
Timestamp: 7134
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
link-status: Good
0 1
CONNECTOR_ID: 101
supported: 101
non-desktop: 0
range: (0, 1)
1920x1080_60.00 (0x774) 173.000MHz -HSync +VSync
Identifier: 0x101
Timestamp: 7134
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
link-status: Good
0 1
CONNECTOR_ID: 103
supported: 103
non-desktop: 0
range: (0, 1)
Identifier: 0x102
Timestamp: 7134
Subpixel: unknown
Clones:
CRTCs: 4 5 6 7
filter:
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
link-status: Good
0 1
CONNECTOR_ID: 106
supported: 106
non-desktop: 0
range: (0, 1)
Additionally, I have not gotten the “configure crtc 4” error when running xrandr --auto or some variation of that since I started using the integrated graphics I think, the command just doesn’t seem to have any impact. Is there any other logs I should post or forum/wiki posts I should be looking at to help try to narrow down the issue, or should I just install the nvidia drivers now?
Update, the second monitor works now. After the noveau drivers where installed and the computer rebooted, it worked. I’ll keep an eye on it to see if anything changes before marking this as solved though.
Great glad to hear
