Hello,
Although in XFCE I have my screens working correctly I have noticed that in the login screen and in qtile they are not. I have tried to fix this using xorg.conf but it does not seem as if that is being obeyed. In xfce I got the displays working using the gui tool for displays. The gpu is nvidia and I am using the proprietary drivers. How can I get the screens do show correctly DP output on left and HDMI on the right?
Section "Monitor"
### Monitor Identity - Typically HDMI-0 or DisplayPort-0
Identifier "HDMI-0"
### Setting Resolution and Modes
## Modeline is usually not required, but you can force resolution with it
Modeline "1360x768" 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync
Option "PreferredMode" "1360x768"
Option "TargetRefresh" "60"
### Positioning the Monitor
## Basic
Option "RightOf" "DP-0"
## Advanced
Option "Position" "1280 0"
EndSection
Section "Monitor"
Identifier "DP-0"
Modeline "1280x1024" 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync
Option "PreferredMode" "1280*1024"
## Basic
Option "LeftOf" "HDMI-0"
## Advanced
Option "Position" "0 0"
EndSection
The above is located in the /etc/X11/xorg.conf.d folder.
Thanks,
Frog
