The problem in MPV only happens when OSC is enabled:
The problem with disabling it, is that I loose control about the MPV itself…
Found a solution for this, which is good enough for me…
Created a file /home/user/.config/mpv/input.conf
cycle border
ALT+UP add window-scale 0.05
ALT+DOWN add window-scale -0.05
a script-message osc-visibility never
b script-message osc-visibility auto
When the video has this kind of behavior, I press A and the OSC never shows, and it never causes the problem.
When its a normal video, I just press B and the OSC is ready whenever I hover my mouse over it…
I’ll be using this option since I realized that the CPU usage increases every time it searches for that font… some spikes in CPU usage that I’m not comfortable with…
