Xbox Elite series 2 controller not found by bluetooth
Hi there!
I just switched to EndeavourOS yesterday, and I can’t seem to pair my controller using bluetooth.
I’ve installed bluez, bluez-utils, and the xpadneo package, the controller works via USB, but I can’t seem to connect via bluetooth.
I’ve tried using the terminal to scan for it, I can see it there, but when i try to pair, then it says device unavailable:
Waiting to connect to bluetoothd...[bluetooth]# Agent registered
[bluetooth]# scan on
[bluetooth]# SetDiscoveryFilter success
[bluetooth]# hci0 type 7 discovering on
[bluetooth]# Discovery started
[bluetooth]# [CHG] Controller C8:94:02:16:94:8C Discovering: yes
[bluetooth]# scan off
[bluetooth]# hci0 type 7 discovering off
[bluetooth]# Discovery stopped
[bluetooth]# [CHG] Controller C8:94:02:16:94:8C Discovering: no
[bluetooth]# pair C8:94:02:16:94:8C
Device C8:94:02:16:94:8C not available
The bluetooth service seems to be running fine:
[yom@yomputer ~]$ systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Thu 2024-07-04 21:06:36 CEST; 21min ago
 Invocation: b6517c7898754457bd5302ab8bd124a6
       Docs: man:bluetoothd(8)
   Main PID: 7367 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 38375)
     Memory: 1.1M (peak: 1.7M)
        CPU: 47ms
     CGroup: /system.slice/bluetooth.service
             └─7367 /usr/lib/bluetooth/bluetoothd
The firmware on the controller was updated just a couple days ago while I was still on Windows.
I can pair and connect to other bt devices, and I just tried connecting the controller to a laptop running Linux Mint, which worked right away.
One post I found suggested using the LTS kernel, which didn’t help.
The system is up to date.
There’s several posts on the forum with similar issue, but none of them have a solution.
Does anyone have an idea that could help me figure out whats wrong? Let me know if there’s anything I could add that could help solve this.
Thank you.
Edit: here’s the system information, figured it might be helpful:
Operating System: EndeavourOS
KDE Plasma Version: 6.1.1
KDE Frameworks Version: 6.3.0
Qt Version: 6.7.2
Kernel Version: 6.6.36-1-lts (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 5800X3D 8-Core Processor
Memory: 31,3 GiB of RAM
Graphics Processor: AMD Radeon RX 6900 XT
Manufacturer: ASUS
I also have one.
Xpad package runs it fine wired.
Wireless I needed xpadneo. Admittedly that breaks A LOT. It’s very difficult keeping this controller working on Linux.
I gave up and bought an 8bitdo USB Bluetooth dongle that claimed to work with it on everything including raspberry pi. It always works and works great . Best $20 I spent on my computer.
Ah, I think I saw your post about it in another thread, if I can’t find a solution I might give that a try, thanks :slight_smile:
If you do find a better option, please let me know and I’ll give it a go too.
It drove me nuts for months.
I’m reasonably sure at this point that the bluetooth protocol includes a coin flip somewhere along the line to decide whether or not it’s going to work at all every time it’s invoked.
It would usually connect. But the elite buttons all wouldn’t work. Or they would fit a few and then it was just get stuck shooting or driving left or something. It was all over the place.
I updated my system today and now I can connect the controller to my pc without a problem. Even shows me the battery level.
