Xbox Controller Light Flashing Over Bluetooth
I am trying to connect my xbox controllers to my machine via bluetooth. They worked on the exact same machine when using Linux Mint, but now they won’t work on EndeavourOS. I’m having the same problem on my laptop, also with EndeavourOS newly installed. I don’t need them to work on my laptop, but I was trying to rule out the bluetooth adapter as the problem.
I have installed xpadneo and xone-dkms, but I don’t think it’s even getting to that point. My controllers are recognized by the bluetooth manager and they show the battery percentage when connected, but the lights on the controllers keeps flashing and none of the inputs work on the computer. I have tested this with two separate xbox controllers. I have also connected a bluetooth headset and my phone over bluetooth to make sure devices can connect and communicate over bluetooth. I haven’t had any problems other than the xbox controllers.
Does anyone have any ideas what I could try next, or what the problem could be? I have included a link per the instructions on the forum for my system specs.
https://0x0.st/8jCy.txt
https://wiki.archlinux.org/title/Gamepad#Xbox_360_controller - says
all four LEDs keep blinking, but controller works. TLP's USB autosuspend is one sure cause of this issue with wireless controllers. See below for fix.
