I installed Endeavour and i really like it but i have a question. Should i switch to X11 or stay on Wayland? Wayland feels really good and i tried out X11 and had some issues on it regarding some stutters when i minimize windows and make them fullscreen, but i can easily fix this issue when i turn off the compositor.
So what do you think? Thanks for any replies!
If Wayland works fine for you, then use it. At some point in the future X11 is going away.
Most of the people who are using X11 are doing so because Wayland isn’t working well for their hardware or application.
If so then i will stay on Wayland. I want my window animations without stuttering.
