Wrong audio driver being loaded. How to blacklist it?
My audio output device - an external USB DAC, sometimes loads with a generic(?) driver instead of the manufacturer driver. I know it’s possible to blacklist certain modules, but I’m not sure how to identify and blacklist a specific driver…
Proper driver: https://linux-hardware.org/?id=usb:262a-1122
Generic driver: https://linux-hardware.org/?id=usb:262a-9027
I think inxi -A should show what drive is being in use:
inxi -A
  Device-1: Intel Cannon Point-LP High Definition Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
  Sound Server-2: PipeWire v: 0.3.43 running: yes
For blacklisting modules:
https://wiki.archlinux.org/title/Blacklist#Blacklisting
Edit: Perhaps inxi -Aa to also get a list of alternative modules for the device if available.
 inxi -Aa
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:9dc8 class-ID: 0403
  Sound Server-2: JACK v: 1.9.20 running: no
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.43 running: yes
That’s a good tip! Here is my output:
$ inxi -Aa
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
  vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
  chip ID: 1002:aae0
  Device-3: JDS Labs Element DAC type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-2:2 chip ID: 262a:1048
  Sound Server: ALSA v: k5.15.13-051513-generic
I’m not seeing “alternate” as in the above example, but it does appear there are three separate entries under “driver” for device #3.
Not sure which one is the generic kernel module. Perhaps snd-usb-audio?
What does
lsmod | grep usb
say?
https://wiki.archlinux.org/title/Kernel_module
Edit:
Kernel Drivers
The device is supported by kernel versions 2.6.14 and newer according to the LKDDb:
Tested Kernels
The following drivers have been loaded in submitted probes:
Driver Kernel
snd_usb_audio 5.4 - 2 probes
