I just installed the latest version of the operating system but after installation I found out it doesn’t detect the wlan0 device I went to /dev but its not there,even in the live boot CD,i cant connect to wifi using my wlan0, but it works on win10 which i dual booted with this OS,Also i just downloaded the iso yesterday so its latest one, what can cause this?,and any solution?,i’ll have to remove the OS if no solution
First of all, please post the output of inxi -Fxxc0z | eos-sendlog.
Even if i run it ,Am using my phone to reply,how can i post the output here when the OS cant connect ![]()
But in the log,i can see my wireless device there Realtek ***********/*********** Wireless LAN as Device-1 and the driver is rtl819xE ,v:N/A,pcie:,port:c000,lanes:1,speed:2.5GT/s , and device-2 as the ethernet device
Look at this site to get more info
The problem is the PC cant connect to internet at all,sending of logs is null ![]()
Is it possible to send a pic?
so can’t detect them in the live envriment? Man I wouldnt have even installed to be honest without an answer but we all learn some way or another. If you can find the right info someone should be able to talk you through installing the drivers as long as you have something that can connect
Fr man,the live env too cant connect ,dammn,so no solution to this?
Didn’t say this just going to be a little bit of work more than likey. I’m not in a place to help with this further but I think someone might be able tot help you
Alright,its just like arch,so it can be fixed like arch,i’ll like to get to the end of this problem
Pretty much mate, the installer just makes things a lot easier
i used the installer
seems its the iso that got problem
Well if you could figure out how to share some more info people would be able to guide you, Like I said not in a place to find this for you but should be able to find easy enough
Is there no way for you to connect online without a wireless connection?
Can you post the output of these commands?
lsmod | grep 819
Also
modinfo r8192e_pci | grep 8192
Edit: You can try the following and see if it works. I’m taking a guess here.
Create the following file with text editor
/etc/modprobe.d/blacklist.conf
Add
blacklist r8192e_pci
blacklist r8192se_pci
Reboot and see if it works.
Even a phone made picture will be fine here, OP.
Are you not able to connect using a network cable directly to the router?
Or can you plug in your phone and use internet through USB?
