wireless USB keyboard / mouse doesn’t wake up the device from sleep. I don’t think being wireless is the case as it uses USB dongle.
$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 002: ID 413c:8126 Dell Computer Corp. Wireless 355 Bluetooth
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
$ grep . /sys/bus/usb/devices/*/power/wakeup
/sys/bus/usb/devices/2-1/power/wakeup:enabled
/sys/bus/usb/devices/4-1/power/wakeup:disabled
/sys/bus/usb/devices/5-2/power/wakeup:disabled
/sys/bus/usb/devices/usb1/power/wakeup:disabled
/sys/bus/usb/devices/usb2/power/wakeup:disabled
/sys/bus/usb/devices/usb3/power/wakeup:disabled
/sys/bus/usb/devices/usb4/power/wakeup:disabled
/sys/bus/usb/devices/usb5/power/wakeup:disabled
below commands solve the problem (based an online guide):
# echo enabled > /sys/bus/usb/devices/5-1/power/wakeup
# echo enabled > /sys/bus/usb/devices/5-2/power/wakeup
# echo enabled > /sys/bus/usb/devices/usb1/power/wakeup
# echo enabled > /sys/bus/usb/devices/usb2/power/wakeup
# echo enabled > /sys/bus/usb/devices/usb3/power/wakeup
# echo enabled > /sys/bus/usb/devices/usb4/power/wakeup
# echo enabled > /sys/bus/usb/devices/usb5/power/wakeup
