On the USB installer, when pressing any button on my Logitech K830 wireless keyboard, it automatically logs me out (briefly displaying the boot sequence events where it says [OK] in a list) and sends me back into the login screen each time a key is pressed. I tried it with all the keys.
Using a wired keyboard worked fine.
Also when using the installer, connecting to WiFi I had intermittent problems, where it says couldn’t connect (yes password was correct), and then all of a sudden after a few attempts it connected. Using the built-in WiFi on my ASUS TUF X570 Motherboard.
The XFCE installer I know is still a work in progress, but hopefully these minor things can be fixed ASAP
could you give more info about wifi chipset?
I do have a Logitech K400r with Logitech Unifying Receiver here, will try to get some info in a minute.
Intel Wireless-AC 9260
Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz. Supports MU-MIMO. Supports channel bandwidth: HT20/HT40/HT80/HT160. Up to 1.73Gbps transfer speed
Also even in XFCE Desktop Environment once installed, the keyboard bug persisted. But once I did a -Syuu upgrade and installed the GNOME/GDM & KDE/Plasma Desktop Environment packages, the keyboard bug stopped and I am now able to use it in KDE Plasma and GNOME
Aug 17 09:53:11 archiso kernel: usb 2-6.2.2: new full-speed USB device number 9 using ehci-pci
Aug 17 09:53:11 archiso kernel: usb 2-6.2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
Aug 17 09:53:11 archiso kernel: usb 2-6.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 17 09:53:11 archiso kernel: usb 2-6.2.2: Product: USB Receiver
Aug 17 09:53:11 archiso kernel: usb 2-6.2.2: Manufacturer: Logitech
Aug 17 09:53:11 archiso kernel: logitech-djreceiver 0003:046D:C52B.000B: hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.7-6.2.2/input2
Aug 17 09:53:11 archiso mtp-probe[1532]: checking bus 2, device 9: "/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-6/2-6.2/2-6.2.2"
Aug 17 09:53:11 archiso mtp-probe[1532]: bus: 2, device: 9 was not an MTP device
Aug 17 09:53:11 archiso kernel: input: Logitech K400 as /devices/pci0000:00/0000:00:1d.7/usb2/2-6/2-6.2/2-6.2.2/2-6.2.2:1.2/0003:046D:C52B.000B/0003:046D:4024.000C/input/input36
Aug 17 09:53:11 archiso kernel: logitech-hidpp-device 0003:046D:4024.000C: input,hidraw4: USB HID v1.11 Keyboard [Logitech K400] on usb-0000:00:1d.7-6.2.2/input2:1
Aug 17 09:53:11 archiso kernel: input: Logitech Performance MX as /devices/pci0000:00/0000:00:1d.7/usb2/2-6/2-6.2/2-6.2.2/2-6.2.2:1.2/0003:046D:C52B.000B/0003:046D:101A.000D/input/input37
Aug 17 09:53:11 archiso kernel: logitech-hidpp-device 0003:046D:101A.000D: input,hidraw5: USB HID v1.11 Mouse [Logitech Performance MX] on usb-0000:00:1d.7-6.2.2/input2:2
Aug 17 09:53:12 archiso mtp-probe[1561]: checking bus 2, device 9: "/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-6/2-6.2/2-6.2.2"
Aug 17 09:53:12 archiso mtp-probe[1561]: bus: 2, device: 9 was not an MTP device
Aug 17 09:53:12 archiso systemd-logind[770]: Watching system buttons on /dev/input/event6 (Logitech K400)
hm my one is working without issue here this is the journal output on plugging in the receiver.
i would bet on firmware issue…
journalctl | grep firmware
or
dmesg | grep firmware
would show that.
thats’s odd… would be nice to see the journaloutput on plug in the receiver at your system!
Well after the -Syuu upgrade the WiFi works.
Do you still want me to plug in the receiver and do a journal output?
I can do that later
yes please! and also the grep firmware would give us info if it is may only related to installed linux-firmware package on last ISO and not there anymore on latest packages.
Well this is the WiFi log (not from installer ISO):
Aug 16 19:31:37 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 19:31:37 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 19:31:37 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.7 DEC: 4 VEP: 0 Revision: 17
Aug 16 19:31:37 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 19:31:37 peter-desktop-endeavoros NetworkManager[638]: <info> [1597570297.7380] manager[0x55fb60a220c0]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 19:31:39 peter-desktop-endeavoros systemd[1]: Startup finished in 24.939s (firmware) + 15.684s (loader) + 2.242s (kernel) + 3.171s (userspace) = 46.037s.
Aug 16 19:57:40 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 19:57:40 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 19:57:40 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.7 DEC: 4 VEP: 0 Revision: 17
Aug 16 19:57:40 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 19:57:40 peter-desktop-endeavoros NetworkManager[635]: <info> [1597571860.6787] manager[0x560df602d0c0]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 19:57:42 peter-desktop-endeavoros systemd[1]: Startup finished in 24.926s (firmware) + 10.663s (loader) + 2.236s (kernel) + 3.095s (userspace) = 40.922s.
Aug 16 20:05:49 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.7 DEC: 4 VEP: 0 Revision: 17
Aug 16 20:05:49 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 20:05:50 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 20:05:50 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 20:05:50 peter-desktop-endeavoros NetworkManager[879]: <info> [1597572350.7812] manager[0x55f95aead0c0]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 20:05:52 peter-desktop-endeavoros systemd[1]: Startup finished in 22.448s (firmware) + 4.406s (loader) + 2.357s (kernel) + 4.363s (userspace) = 33.575s.
Aug 16 20:07:08 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 20:07:08 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 20:07:08 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.7 DEC: 4 VEP: 0 Revision: 17
Aug 16 20:07:08 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 20:07:08 peter-desktop-endeavoros NetworkManager[686]: <info> [1597572428.6720] manager[0x558b4bddc0c0]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 20:07:10 peter-desktop-endeavoros systemd[1]: Startup finished in 22.361s (firmware) + 3.093s (loader) + 2.233s (kernel) + 3.349s (userspace) = 31.038s.
Aug 16 20:13:27 peter-desktop-endeavoros NetworkManager[686]: <info> [1597572807.6912] manager: kernel firmware directory '/lib/firmware' changed
Aug 16 20:17:35 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 16 20:17:35 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 20:17:35 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 20:17:35 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 20:17:36 peter-desktop-endeavoros NetworkManager[843]: <info> [1597573056.1056] manager[0x564402cea030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 20:17:38 peter-desktop-endeavoros systemd[1]: Startup finished in 22.355s (firmware) + 3.149s (loader) + 2.272s (kernel) + 3.874s (userspace) = 31.652s.
Aug 16 20:33:53 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 20:33:53 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 20:33:53 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 16 20:33:53 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 20:33:53 peter-desktop-endeavoros NetworkManager[638]: <info> [1597574033.6827] manager[0x55a260356030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 20:33:55 peter-desktop-endeavoros systemd[1]: Startup finished in 22.922s (firmware) + 3.373s (loader) + 2.354s (kernel) + 2.555s (userspace) = 31.206s.
Aug 16 21:13:03 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Loaded firmware version: 46.8902351f.0 9260-th-b0-jf-b0-46.ucode
Aug 16 21:32:15 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 21:32:15 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 21:32:15 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 16 21:32:15 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 21:32:15 peter-desktop-endeavoros NetworkManager[695]: <info> [1597577535.8539] manager[0x55ff468d5030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 21:32:17 peter-desktop-endeavoros systemd[1]: Startup finished in 22.451s (firmware) + 3.262s (loader) + 2.260s (kernel) + 3.407s (userspace) = 31.382s.
Aug 16 21:35:47 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 21:35:47 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 21:35:47 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 16 21:35:47 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 21:35:47 peter-desktop-endeavoros NetworkManager[692]: <info> [1597577747.7154] manager[0x55d6d0b63030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 21:35:49 peter-desktop-endeavoros systemd[1]: Startup finished in 22.442s (firmware) + 2.213s (loader) + 2.282s (kernel) + 3.050s (userspace) = 29.989s.
Aug 16 21:53:29 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 16 21:53:29 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 21:53:30 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 21:53:30 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 21:53:30 peter-desktop-endeavoros NetworkManager[903]: <info> [1597578810.5153] manager[0x563938c11030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 21:53:32 peter-desktop-endeavoros systemd[1]: Startup finished in 22.443s (firmware) + 3.320s (loader) + 2.252s (kernel) + 3.903s (userspace) = 31.920s.
Aug 16 21:58:28 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 21:58:28 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 21:58:28 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 16 21:58:28 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 21:58:29 peter-desktop-endeavoros NetworkManager[754]: <info> [1597579109.0575] manager[0x5586fb296030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 21:58:31 peter-desktop-endeavoros systemd[1]: Startup finished in 22.815s (firmware) + 5.552s (loader) + 2.374s (kernel) + 3.609s (userspace) = 34.352s.
Aug 16 22:09:45 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 16 22:09:45 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 16 22:09:45 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 16 22:09:45 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 16 22:09:45 peter-desktop-endeavoros NetworkManager[674]: <info> [1597579785.7500] manager[0x55a6d4d18030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 16 22:09:47 peter-desktop-endeavoros systemd[1]: Startup finished in 22.431s (firmware) + 3.037s (loader) + 2.303s (kernel) + 3.082s (userspace) = 30.855s.
Aug 17 10:28:43 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Loaded firmware version: 46.8902351f.0 9260-th-b0-jf-b0-46.ucode
Aug 17 14:13:39 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 17 14:13:39 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 17 14:13:39 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 17 14:13:39 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 17 14:13:39 peter-desktop-endeavoros NetworkManager[709]: <info> [1597637619.7908] manager[0x55a249932030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 17 14:13:41 peter-desktop-endeavoros systemd[1]: Startup finished in 22.379s (firmware) + 4.529s (loader) + 2.291s (kernel) + 3.409s (userspace) = 32.609s.
Aug 17 14:13:43 peter-desktop-endeavoros xow[713]: what(): Failed to load firmware
Aug 17 14:18:53 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 17 14:18:53 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 17 14:18:53 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 17 14:18:53 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 17 14:18:53 peter-desktop-endeavoros NetworkManager[684]: <info> [1597637933.8891] manager[0x557a80bcb030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 17 14:18:55 peter-desktop-endeavoros systemd[1]: Startup finished in 22.398s (firmware) + 9.890s (loader) + 2.370s (kernel) + 3.413s (userspace) = 38.071s.
Aug 17 14:18:57 peter-desktop-endeavoros xow[688]: what(): Failed to load firmware
Aug 17 14:29:10 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 17 14:29:10 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 17 14:29:10 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 17 14:29:10 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 17 14:29:10 peter-desktop-endeavoros NetworkManager[703]: <info> [1597638550.8124] manager[0x559003206030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 17 14:29:12 peter-desktop-endeavoros systemd[1]: Startup finished in 22.435s (firmware) + 2.918s (loader) + 2.335s (kernel) + 3.263s (userspace) = 30.952s.
Aug 17 14:29:14 peter-desktop-endeavoros xow[707]: what(): Failed to load firmware
Aug 17 14:36:14 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 17 14:36:14 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 17 14:36:14 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 17 14:36:14 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 17 14:36:14 peter-desktop-endeavoros NetworkManager[695]: <info> [1597638974.7560] manager[0x55f130917030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 17 14:36:16 peter-desktop-endeavoros systemd[1]: Startup finished in 22.473s (firmware) + 2.809s (loader) + 2.327s (kernel) + 3.314s (userspace) = 30.925s.
Aug 17 14:36:18 peter-desktop-endeavoros xow[699]: what(): Failed to load firmware
Aug 17 14:47:39 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 17 14:47:39 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 17 14:47:39 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 17 14:47:39 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 17 14:47:39 peter-desktop-endeavoros NetworkManager[659]: <info> [1597639659.7046] manager[0x55b7d3551030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 17 14:47:40 peter-desktop-endeavoros systemd[1]: Startup finished in 22.460s (firmware) + 4.840s (loader) + 2.270s (kernel) + 2.255s (userspace) = 31.826s.
Aug 17 14:47:41 peter-desktop-endeavoros xow[668]: what(): Failed to load firmware
Aug 17 17:00:24 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
Aug 17 17:00:24 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Aug 17 17:00:24 peter-desktop-endeavoros kernel: [drm] Found VCN firmware Version ENC: 1.9 DEC: 5 VEP: 0 Revision: 0
Aug 17 17:00:24 peter-desktop-endeavoros kernel: [drm] PSP loading VCN firmware
Aug 17 17:00:24 peter-desktop-endeavoros NetworkManager[703]: <info> [1597647624.7311] manager[0x5605dfcd8030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 17 17:00:26 peter-desktop-endeavoros systemd[1]: Startup finished in 27.984s (firmware) + 3.416s (loader) + 2.268s (kernel) + 3.212s (userspace) = 36.882s.
Aug 17 17:00:28 peter-desktop-endeavoros xow[707]: what(): Failed to load firmware
Aug 17 17:54:08 peter-desktop-endeavoros kernel: iwlwifi 0000:06:00.0: Loaded firmware version: 46.8902351f.0 9260-th-b0-jf-b0-46.ucode
Did you just want me to do a journalctrl log in the current system or on the installer ISO?
if you have the time from ISO would be nice to compare them both.
there is a command to pastebin logs directly:
journalctl | grep firmware | curl -F 'f:1=<-' ix.io
this will crate a pastebin on ix.io and gives you a url to that.
Ok I will try make time for the ISO installer bug report but no guarantees sorry. I have been flat out with work.
I can definitely provide you with a bug report from the current working system of the wireless keyboard though if you want?
If you have time no rush! the output from installed system is already very helpful to investigate on that BUG!!
