Hello guys! I just installed EndeavourOS. On live user my adapter (TL-WN723N) was working fine. But after rebooting into the os it cannot be detected any more.
ip link shows no wireless interface
dmesg | grep usbcore shows r8188eu drivers (on both live and installed os)
inxi -Fxxc0z --no-host :
Kernel: 5.18.5-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: i3 v: 4.20.1 dm: LightDM Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: Gigabyte model: H81M-H v: x.x serial: N/A
UEFI: American Megatrends v: FA date: 07/04/2014
Info: dual core model: Intel Core i3-4170 bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 3273 high: 3699 min/max: 800/3700 cores: 1: 2005
2: 3692 3: 3696 4: 3699 bogomips: 29546
Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel arch: Gen7.5 ports: active: VGA-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:041e
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: intel
unloaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96
Monitor-1: VGA-1 mapped: VGA1 model: Samsung S19D300 res: 1366x768
dpi: 85 diag: 470mm (18.5")
OpenGL: renderer: Mesa Intel HD Graphics 4400 (HSW GT2)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20
Sound Server-1: ALSA v: k5.18.5-arch1-1 running: yes
Sound Server-2: PulseAudio v: 16.0 running: no
Sound Server-3: PipeWire v: 0.3.52 running: no
vendor: Gigabyte driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
IF: enp2s0 state: down mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: N/A bus-ID: 3-7:5 chip-ID: 0bda:8179
Local Storage: total: 931.51 GiB used: 4.94 GiB (0.5%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 915.53 GiB used: 4.94 GiB (0.5%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Processes: 144 Uptime: 1h 39m Memory: 3.72 GiB used: 686.2 MiB (18.0%)
Init: systemd v: 251 default: graphical Compilers: gcc: 12.1.0 Packages:
pacman: 802 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.18
dmesg -rl warn,err,crit
<4>[ 0.103546] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
<4>[ 0.103546] #3
<3>[ 1.468589] usbhid 3-3:1.1: couldn't find an input interrupt endpoint
<4>[ 11.900583] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20211217/utaddress-204)
<4>[ 11.900597] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
<4>[ 11.900602] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20211217/utaddress-204)
<4>[ 11.900606] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
<4>[ 11.900610] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20211217/utaddress-204)
<4>[ 11.900614] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
<4>[ 11.900618] lpc_ich: Resource conflict(s) found affecting gpio_ich
<4>[ 12.312283] at24 0-0050: supply vcc not found, using dummy regulator
<4>[ 12.604772] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
<4>[ 12.617434] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
<3>[ 12.643105] r8188eu 3-7:1.0: _rtw_init_xmit_priv failed
<4>[ 13.896391] kauditd_printk_skb: 4 callbacks suppressed
<4>[ 19.456467] kauditd_printk_skb: 5 callbacks suppressed
<4>[ 24.614561] kauditd_printk_skb: 67 callbacks suppressed
<4>[ 30.864667] kauditd_printk_skb: 6 callbacks suppressed
When I run journalctl -f and connect the adapter:
jun 18 17:01:32 endeavouros kernel: usb 3-7: new high-speed USB device number 7 using xhci_hcd
jun 18 17:01:32 endeavouros kernel: usb 3-7: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
jun 18 17:01:32 endeavouros kernel: usb 3-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
jun 18 17:01:32 endeavouros kernel: usb 3-7: Product: 802.11n NIC
jun 18 17:01:32 endeavouros kernel: usb 3-7: Manufacturer: Realtek
jun 18 17:01:32 endeavouros kernel: usb 3-7: SerialNumber: 00E04C0001
jun 18 17:01:32 endeavouros kernel: Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
jun 18 17:01:32 endeavouros kernel: EEPROM ID = 0x8129
jun 18 17:01:32 endeavouros kernel: r8188eu 3-7:1.0: _rtw_init_xmit_priv failed
jun 18 17:01:32 endeavouros kernel: usb 3-7: reset high-speed USB device number 7 using xhci_hcd
jun 18 17:01:32 endeavouros mtp-probe[2969]: checking bus 3, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7"
jun 18 17:01:32 endeavouros mtp-probe[2969]: bus: 3, device: 7 was not an MTP device
jun 18 17:01:32 endeavouros mtp-probe[2970]: checking bus 3, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7"
jun 18 17:01:32 endeavouros mtp-probe[2970]: bus: 3, device: 7 was not an MTP device
I don’t know what r8188eu 3-7:1.0: _rtw_init_xmit_priv failed means. Any help is welcomed
Thanks!
