Wireguard connection via bash script per application?
I would like to use my Wireguard connection for a few applications only e.g. open a SSH connections via konsole also a specific browser (firefox)
is it possible to start these applications via bash script which include connection details to open only with Wireguard connection?
e.g.
konsole.sh
#!/bin/bash
# use wireguard connection
# and do
konsole -e ssh -p 22 user@xxx.xxx.xxx.xxx
https://wiki.archlinux.org/title/WireGuard
According to Arch’s wiki, there is GUI tool (AUR) that you can use to bypass applications.
Never tried it so I can’t confirm if its going to work the way you want.
https://github.com/corrad1nho/qomui
wow thank you!
that could work …
It’s not wireguard exactly, so it might not be exactly what you are looking for, but I use proxychains for stuff like this (ie. irssi connections).
oh I like that!
is there a difference between proxychains and proxychains-ng?
I’m using the “plain” version and have had no issues. I think the -ng is just a fork, but I don’t see any features in it that I’m missing from the plain version.
Edit - I lied, I checked and I’m actually using the -ng version. It’s worked very well for me after the quick initial set up. If you have questions I’m happy to help as much as I can.
