Greetings!
I recently made a thread about a different issue, the suggested solution was to downgrade, which I did and the previous problem was solved.
Should this be of any help here’s the link to the thread:
However, starting yesterday I’ve had connection issues that were occasionally solved by a reboot.
After the downgrade it seems to be worse, and the connection is missing each time I reboot.
I’m now connected with a wireless usb pen, which works, but it’s not optimal, I’d rather use my wired connection.
In the thread linked above I was told to check the page: https://discovery.endeavouros.com/network/r8168-workaround/2021/03/
I did and uninstalled r8168, which sadly didn’t help.
Should it be useful, here’s the output for
inxi -anN
and for
systemctl status NetworkManager
raccoon@trash ~ inxi -anN
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full
mac: 2c:f0:5d:21:e1:4e
Device-2: D-Link System DWA-140 RangeBooster N Adapter(rev.B2) [Ralink
RT3072]
type: USB driver: rt2800usb bus-ID: 3-1:4 chip-ID: 07d1:3c0a class-ID: 0000
serial: 1.0
IF: wlan0 state: up mac: 1c:af:f7:75:86:f0
Device-3: SteelSeries ApS Arctis 7 wireless adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-3.4:5 chip-ID: 1038:1260
class-ID: 0300
raccoon@trash ~ systemctl status NetworkManager
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
└─NetworkManager-ovs.conf
Active: active (running) since Mon 2022-05-30 14:39:14 CEST; 14min ago
Docs: man:NetworkManager(8)
Main PID: 837 (NetworkManager)
Tasks: 3 (limit: 38440)
Memory: 13.5M
CPU: 1.721s
CGroup: /system.slice/NetworkManager.service
└─837 /usr/bin/NetworkManager --no-daemon
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9426] device (enp39s0): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9649] dhcp4 (enp39s0): canceled DHCP transaction
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9649] dhcp4 (enp39s0): activation: beginning transaction (timeout in 45 seconds)
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9649] dhcp4 (enp39s0): state changed no lease
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9650] dhcp6 (enp39s0): canceled DHCP transaction
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9650] dhcp6 (enp39s0): activation: beginning transaction (timeout in 45 seconds)
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9650] dhcp6 (enp39s0): state changed no lease
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9712] policy: set 'Martin Router King' (wlan0) as default for IPv4 routing and DNS
mag 30 14:47:29 trash NetworkManager[837]: <info> [1653914849.9715] audit: op="statistics" interface="enp39s0" ifindex=2 args="0" pid=1445 uid=1000 result="success"
mag 30 14:47:34 trash NetworkManager[837]: <info> [1653914854.3800] audit: op="statistics" interface="wlan0" ifindex=3 args="0" pid=1445 uid=1000 result="success"
