I’m new to EOS and I’m having an issue with OBS. There is no Window Capture option in OBS. I searched for a solution and tried the steps in this forum post to install Pipewire.
I also saw this discussion and tried running OBS as root. The Window Capture option appeared when running as root, but I want it to work with a normal user.
I tried installing xdg-desktop-portal-gnome, but the Window Capture option still doesn’t show up for a normal user. Does anyone know how to fix this issue?
Thank you, I have tried it, but the menu still doesn’t show when I open it again. I tried rebooting, and after I logged in, my DE just showed [pic 1] and I couldn’t do anything.
So, I modified it. In my /etc/environment there was QT_QPA_PLATFORMTHEME=qt5ct but it was commented out. I tried many combinations between this and what you suggested, and it finally succeeded when I just inserted QT_QPA_PLATFORMTHEME=qt5ct and export QT_QPA_PLATFORM=xcb.
Now the menu appears and it works, but I have a question: is this the correct approach to solve this problem?
