I am a Linux newbie. I recently switched to the purple side of Linux from Windows 10.
Now, I am facing a situation with my WiFi speed. Speedtest is showing above 100+ Mbps upload/download speed via LAN.
But, in WiFi, it’s a mere 8+ Mbps speed for download, and 20+ Mbps speed for upload.
Following is my system information.
sudo dmesg | grep iwl
[sudo] password for bineeth:
[ 9.010730] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 9.186151] iwlwifi 0000:01:00.0: loaded firmware version 36.ca7b901d.0 8265-36.ucode op_mode iwlmvm
[ 9.596829] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 9.657391] iwlwifi 0000:01:00.0: base HW address: 40:ec:99:c5:a0:ee
[ 9.732525] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
I’ve also tried connecting my system to the Mobile network. And there, I am getting a reasonable download speed of 14+ Mbps via WiFi.
I think, this has to do something with the iwlwifi driver.
Based on my network card configuration, I believe my system is supposed to use firmware iwlwifi-3168-22.ucode.
I’ve tried removing the higher versions. And I could see the system is picking iwlwifi-3168-22.ucode firmware in the boot log (Note: In dmesg output, firmware version 36.x is loaded. That’s because I re-installed the OS today, I tried switching firmware before that).
But, still no luck. Can someone help me to solve this, please?
Others have reported the same issue with this chip. Here is all the info on iwlwifi. There is some good info there if you read through it. It has all the firmware links also.
I would suggest you try some of the suggestions on the Arch wiki page also. You can also set it to run one band or the other. Sometimes that is a problem. There is also bluetooth co-exist which can have an effect on it. You’ll have to try some things and experiment.
It’s not the fast boot in the Bios. It’s the fast start up Windows just to make sure. But i can tell you that that chip is known to have this problem. You can try different firmware. I gave you the links. There isn’t much else i can do to help.
Hi @ricklinux, thanks again for the suggestion.
I tried this today. And the following was the result.
Band 5.0 GHz, Mode: 802.11g:
bineeth@Workstation-10SRCT01WW ~]$ speedtest
Retrieving speedtest.net configuration...
Testing from BSNL (117.216.24.161)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Keralavision Broadband (Trivandrum) [4.66 km]: 31.795 ms
Testing download speed................................................................................
Download: 8.88 Mbit/s
Testing upload speed......................................................................................................
Upload: 6.26 Mbit/s
Band 5.0 GHz, Mode: 802.11 b/g/n mix:
[bineeth@Workstation-10SRCT01WW ~]$ speedtest
Hosted by Jtel (Nagercoil) [61.17 km]: 64.074 ms
Download: 13.28 Mbit/s
Upload: 3.34 Mbit/s
And via LAN:
Hosted by Keralavision Broadband (Trivandrum) [4.66 km]: 28.979 ms
Download: 122.96 Mbit/s
Upload: 102.18 Mbit/s
I remember that I’ve got around 85.0+ Mbps download and 35.0+ upload speed via WiFi, during the first days of my installation.
And I think, this problem happened after I’ve done an update.
I don’t remember exactly when that happened.
But, I think it should be after 14th August (I used to update my OS only on Saturday).
I’ve never faced this kind of issue in Windows.
I am not complaining. I know that this is not the fault of Endeavour (or Linux).
I assume there should be some extra tweaks in Intel’s Windows driver, that’s not present in Linux counterpart.
As @jonathon say’s look at the pacman log and on or around the date in question and see what packages were updated. You can always use downgrade to downgrade a suspected update to a previous version. It’s not a limitation of Linux but it could be the module (driver) or firmware or another package that affects the WiFi in some way. i.e. Bluetooth
You can only check and see what you think it might be based on that date and try downgrading it.
Edit: You are not the first one with that Intel chip to have the same issue. It’s well documented on Arch and other sites.
bineeth@Workstation-10SRCT01WW ~]$ eos-pacdiff
Starting pacdiff & diffuse as root ...
Root Password: ==> pacsave file found for /etc/iptables/iptables.rules
:: (V)iew, (S)kip, (R)emove pacsave, (O)verwrite with pacsave, (Q)uit: [v/s/r/o/q] s
==> pacsave file found for /etc/iptables/ip6tables.rules
==> pacnew file found for /etc/pacman.d/mirrorlist
:: (V)iew, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/s/r/o/q] s
I think I can safely ignore iptables related changes, as I am using Nftables now.
I can’t find anything related to iwlwifi.
