Hi everyone. I’m new to Linux. I have a Macbook air mid 2013 with Broadcom BCM4360 wifi card. The wifi does work and I can connect to networks, but it’s bad.
The wifi is very very slow. On macOS I got 5mb/s but on Linux I have (most of the time) around 200kb/s. The next problem is that the download speed fluctuates, sometimes it’s around 2mb/s, the next second it’s at 100kb/s. Another problem is that it looks like when the wifi is not in active use it just stops working. Like before I start downloading something with pacman I need to turn my wifi on and off and only then it starts to (barely) work.
Are you using the broadcom-wl-dkms package for the WiFi?
You may need to blacklist the other modules also in modprobe.d with a conf file that you create. I’m not familiar with Mac so i don’t know if it has the same folder structure?
