Wifi not working TX20U Plus
Hi guys,
I’ve just installed EndeavourOS yesrerday but i can’t get the wifi work.
I use a TP-Link AX1800 Archer TX20U Plus (i know, mistake, but i bought it back when i still was on Windows) connected through USB.
Here is the content of the inxi -Na
*Network:
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 06:00.0
chip-ID: 10ec:8125 class-ID: 0200
Device-2: TP-Link 802.11ac WLAN Adapter driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:5 chip-ID: 2357:013f
class-ID: 0000 serial: 00e04c000001*
It seems the driver isn’t loading.
I tried many things but i just can’t get it work.
I tried to follow this, which worked when i was on Mint :
https://github.com/lwfinger/rtl8852au
During the first part of the tuto, no errors.
Then during the building of the drivers, several errors.
*fatal: destination path ‘rtl8852au’ already exists and is not an empty directory.
/bin/sh: line 1: bc: command not found
#rm -f .symvers.8852au
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/6.13.8-arch1-1/build M=/home/azanore/rtw89-dkms-git/rtl8852au modules
make[1]: Entering directory ‘/usr/lib/modules/6.13.8-arch1-1/build’
make[2]: Entering directory ‘/home/azanore/rtw89-dkms-git/rtl8852au’
CC [M] os_dep/osdep_service_linux.o
In file included from /usr/lib/modules/6.13.8-arch1-1/build/include/linux/module.h:22,
from ././include/basic_types.h:38,
from ././include/drv_types.h:24,
from os_dep/osdep_service_linux.c:16:
os_dep/osdep_service_linux.c: In function ‘openFile’:
os_dep/osdep_service_linux.c:393:26: error: expected ‘,’ or ‘;’ before ‘VFS_internal_I_am_really_a_filesystem_and_am_NOT_a_driver’
393 | MODULE_IMPORT_NS(VFS_internal_I_am_really_a_filesystem_and_am_NOT_a_driver);
/usr/lib/modules/6.13.8-arch1-1/build/include/linux/moduleparam.h:26:61: note: in definition of macro ‘__MODULE_INFO’
26 | = __MODULE_INFO_PREFIX __stringify(tag) “=” info
/usr/lib/modules/6.13.8-arch1-1/build/include/linux/module.h:299:33: note: in expansion of macro ‘MODULE_INFO’
299 | #define MODULE_IMPORT_NS(ns) MODULE_INFO(import_ns, ns)
os_dep/osdep_service_linux.c:393:9: note: in expansion of macro ‘MODULE_IMPORT_NS’
os_dep/osdep_service_linux.c: In function ‘isFileReadable’:
os_dep/osdep_service_linux.c:511:26: error: expected ‘,’ or ‘;’ before ‘VFS_internal_I_am_really_a_filesystem_and_am_NOT_a_driver’
511 | MODULE_IMPORT_NS(VFS_internal_I_am_really_a_filesystem_and_am_NOT_a_driver);
os_dep/osdep_service_linux.c:511:9: note: in expansion of macro ‘MODULE_IMPORT_NS’
make[4]: *** [/usr/lib/modules/6.13.8-arch1-1/build/scripts/Makefile.build:196: os_dep/osdep_service_linux.o] Error 1
make[3]: *** [/usr/lib/modules/6.13.8-arch1-1/build/Makefile:1989: .] Error 2
make[2]: *** [/usr/lib/modules/6.13.8-arch1-1/build/Makefile:251: __sub-make] Error 2
make[2]: Leaving directory ‘/home/azanore/rtw89-dkms-git/rtl8852au’
make[1]: *** [Makefile:251: __sub-make] Error 2
make[1]: Leaving directory ‘/usr/lib/modules/6.13.8-arch1-1/build’
make: *** [Makefile:639: modules] Error 2
[sudo] password for azanore:
install -p -m 644 8852au.ko /lib/modules/6.13.8-arch1-1/kernel/drivers/net/wireless/realtek/rtw89/
install: cannot stat ‘8852au.ko’: No such file or directory
make: *** [Makefile:649: install] Error 1*
I don’t understand what is not working and mean all of those errors. I expect to have some missing files somewhere but i can’t solve this all by myself and i didn’t find any solution. Can you help me to install a driver please ?
Welcome to the forum @Azanore ,
I’m on 6.12.21-1-lts kernel. Tried this:
yay -S rtl8852au-dkms-git
The build seems to be OK.
@eso thank you for welcoming me.
I tried it but i still don’t have any driver active, even after reboot.
networkctl -a
has no wlan0 ?
nmtui
does not see your wifi?
Hello and welcome,
Did you try to load the driver manually ?
sudo modprobe 8852au
No, no wlan0
[azanore@AzaPC ~]$ networkctl -a
systemd-networkd is not running, output might be incomplete.
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback - unmanaged
2 enp6s0 ether - unmanaged
However, nmtui showed something interesting. Obviously, it doesn’t consider Device-2: TP-Link 802.11ac WLAN Adapter driver: N/A type: USB has an hardware.
@vazicebon
I tried that command and receive that error :
modprobe: FATAL: Module 8852au not found in directory /lib/modules/6.13.8-arch1-1
Please notice i’m a simple monkey with a computer. I don’t know much about getting this working, sorry for that.
I do not want to preprocess this for you,
but read post 3,4,5 at least
It doesn’t work. Obviously, the lts packages were missing but I still don’t managed to make it work.
I’m giving up and I don’t want to make you lose more time.
Thank you for your help, I really appreciate what you have done today with me. I’m currently not skilled enough to understand and make it work properly.
I can’t keep my desk in the middle of my apartment so I give up for the moment.
Maybe I’ll give another try another day but I want to be able to use my computer in good condition.
The bc package is a dependency of some Realtek WiFi drivers. Occasionally it is missed as a named dependency in some AUR Realtek driver packages. That may be one of the reasons that your build fails.
