I’ll dump a bunch of information here before I describe the problem:
Hardware information:
https://clbin.com/OFD2b
Boot log:
https://clbin.com/v7b2f
ip link (I am using usb tethering with my iPhone):
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp0s20u2c4i2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether 8a:19:08:02:f6:9b brd ff:ff:ff:ff:ff:ff
rfkill list (wifi isn’t even showing up):
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
NetworkManager is active and running
ping 8.8.8.8:
ping: connect: Network is unreachable
Onto the actual post:
Wifi isn’t working in the live environment or after installation. After I click on the wifi button on the bottom bar, I can not select any networks. Wifi has worked on every other distro I tried, including Arch (although I used iwd for Arch), so I’m not sure why it refuses to work on EOS.
