Hello, I’ve been having constant issues recently with a lot of instability with wifi where my connection just dies for no apparent reason and sometimes gets completely disconnected from the network and can’t reconnect until whatever service is handling the network is restarted. So far I’ve tried to switch from NetworkManager to iwd which made no real difference. Something to note is that currently tp-link on their website provides the rtl8852BE driver for wifi which is not supported past linux kernel versions over 6.0.0. The driver currently in use is rtw89, from what I understand from the output of lsmod the driver currently in use is rtw89:
rtw89_8852be 12288 0
rtw89_8852b 376832 1 rtw89_8852be
rtw89_pci 86016 1 rtw89_8852be
rtw89_core 688128 2 rtw89_8852b,rtw89_pci
mac80211 1662976 2 rtw89_core,rtw89_pci
cfg80211 1376256 3 rtw89_8852b,rtw89_core,mac80211
I should also note that using lts kernel 6.1.69-1 somehow breaks everything even more with the adapter not being detected at all.
Here is the inxi output:
nik@nik-pc ~ inxi -Fxxz
Kernel: 6.6.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Desktop System: Gigabyte product: B550 GAMING X V2 v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B550 GAMING X V2 v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: FDa date: 07/18/2023
Info: 8-core model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+
rev: 2 cache: L1: 512 KiB L2: 4 MiB L3: 96 MiB
Speed (MHz): avg: 3571 high: 4442 min/max: 2200/4549 boost: enabled cores:
1: 4442 2: 3553 3: 3545 4: 4442 5: 3551 6: 3553 7: 2200 8: 3553 9: 4439
10: 3550 11: 4442 12: 2200 13: 3552 14: 2200 15: 3551 16: 4371
bogomips: 108595
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 pcie: speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 08:00.0
chip-ID: 1002:73df
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung C27F390 res: 1920x1080
dpi: 82 diag: 686mm (27")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
navi22 LLVM 16.0.6 DRM 3.54 6.6.8-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.274 surfaces: xcb,xlib device: 0 type: discrete-gpu
driver: amd device-ID: 1002:73df
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0a:00.4 chip-ID: 1022:1487
Device-3: Kingston HyperX SoloCast
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 bus-ID: 3-3:4 chip-ID: 0951:170f
API: ALSA v: k6.6.8-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: AzureWave
driver: rtw89_8852be v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 04:00.0 chip-ID: 10ec:b852
vendor: Gigabyte driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF: enp5s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-9:3 chip-ID: 13d3:3570
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 2.73 TiB used: 582.9 GiB (20.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 33.9 C
ID-2: /dev/sda vendor: Toshiba model: HDWD220 size: 1.82 TiB
speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 881 GiB used: 420.31 GiB (47.7%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 42.2 C mobo: 27.0 C gpu: amdgpu temp: 42.0 C
mem: 38.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 378 Uptime: 31m Memory: total: 32 GiB available: 31.26 GiB
used: 6.44 GiB (20.6%) Init: systemd v: 255 default: graphical Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: 1290 pm: pacman pkgs: 1279 pm: flatpak
pkgs: 11 Shell: nu running-in: tmux: inxi: 3.3.31
